drivers/usb/class/cdc-acm.c | 2 +-
drivers/usb/class/cdc-wdm.c | 2 +-
drivers/usb/class/usblp.c | 2 +-
drivers/usb/class/usbtmc.c | 2 +-
drivers/usb/wusbcore/cbaf.c | 2 +-
5 files changed, 5 insertions(+), 5 deletions(-)
diff --git a/drivers/usb/class/cdc-acm.c b/drivers/usb/class/cdc-acm.c
index 95f29a2..5155ff2 100644
--- a/drivers/usb/class/cdc-acm.c
+++ b/drivers/usb/class/cdc-acm.c
@@ -1489,7 +1489,7 @@ static int acm_reset_resume(struct usb_interface *intf)
* USB driver structure.
-static struct usb_device_id acm_ids[] = {
+static const struct usb_device_id acm_ids[] = {
/* quirky and broken devices */
{ USB_DEVICE(0x0870, 0x0001), /* Metricom GS Modem */
.driver_info = NO_UNION_NORMAL, /* has no union descriptor */
diff --git a/drivers/usb/class/cdc-wdm.c b/drivers/usb/class/cdc-wdm.c
index 3e564bf..18aafcb 100644
--- a/drivers/usb/class/cdc-wdm.c
+++ b/drivers/usb/class/cdc-wdm.c
@@ -31,7 +31,7 @@
#define DRIVER_AUTHOR "Oliver Neukum"
#define DRIVER_DESC "USB Abstract Control Model driver for USB WCM Device Management"
-static struct usb_device_id wdm_ids[] = {
+static const struct usb_device_id wdm_ids[] = {
.match_flags = USB_DEVICE_ID_MATCH_INT_CLASS |
USB_DEVICE_ID_MATCH_INT_SUBCLASS,
diff --git a/drivers/usb/class/usblp.c b/drivers/usb/class/usblp.c
index 9d8ec72..93b5f85 100644
--- a/drivers/usb/class/usblp.c
+++ b/drivers/usb/class/usblp.c
@@ -1390,7 +1390,7 @@ static int usblp_resume(struct usb_interface *intf)
return r;
-static struct usb_device_id usblp_ids [] = {
+static const struct usb_device_id usblp_ids[] = {
{ USB_DEVICE_INFO(7, 1, 1) },
{ USB_DEVICE_INFO(7, 1, 2) },
{ USB_DEVICE_INFO(7, 1, 3) },
diff --git a/drivers/usb/class/usbtmc.c b/drivers/usb/class/usbtmc.c
index 7c5f4e3..8588c09 100644
--- a/drivers/usb/class/usbtmc.c
+++ b/drivers/usb/class/usbtmc.c
@@ -48,7 +48,7 @@
#define USBTMC_MAX_READS_TO_CLEAR_BULK_IN 100
-static struct usb_device_id usbtmc_devices[] = {
+static const struct usb_device_id usbtmc_devices[] = {
{ USB_INTERFACE_INFO(USB_CLASS_APP_SPEC, 3, 0), },
{ USB_INTERFACE_INFO(USB_CLASS_APP_SPEC, 3, 1), },
{ 0, } /* terminating entry */
diff --git a/drivers/usb/wusbcore/cbaf.c b/drivers/usb/wusbcore/cbaf.c
index 25eae40..51a8e0d 100644
--- a/drivers/usb/wusbcore/cbaf.c
+++ b/drivers/usb/wusbcore/cbaf.c
@@ -641,7 +641,7 @@ static void cbaf_disconnect(struct usb_interface *iface)
kzfree(cbaf);
-static struct usb_device_id cbaf_id_table[] = {
+static const struct usb_device_id cbaf_id_table[] = {
{ USB_INTERFACE_INFO(0xef, 0x03, 0x01), },
