unicore32/irq: Prepare puv3_gpio_handler for irq argument removal
Author: Thomas Gleixner <tglx@linutronix.de>
The irq argument of most interrupt flow handlers is unused or merily
used instead of a local variable. The handlers which need the irq
argument can retrieve the irq number from the irq descriptor.
Search and update was done with coccinelle and the invaluable help of
Julia Lawall.
Signed-off-by: Thomas Gleixner
Cc: Julia Lawall
Cc: Guan Xuetao
arch/unicore32/kernel/irq.c | 5 ++---
1 file changed, 2 insertions(+), 3 deletions(-)
diff --git a/arch/unicore32/kernel/irq.c b/arch/unicore32/kernel/irq.c
index 0be5ccd..c53729d 100644
--- a/arch/unicore32/kernel/irq.c
+++ b/arch/unicore32/kernel/irq.c
@@ -112,10 +112,9 @@ static struct irq_chip puv3_low_gpio_chip = {
* irq_controller_lock held, and IRQs disabled. Decode the IRQ
* and call the handler.
-static void
-puv3_gpio_handler(unsigned int irq, struct irq_desc *desc)
+static void puv3_gpio_handler(unsigned int __irq, struct irq_desc *desc)
- unsigned int mask;
+ unsigned int mask, irq;
mask = readl(GPIO_GEDR);
do { |
-static void
do {
