[UM]: Fix use of skb after netif_rx
Recently, Wang Chen submitted a patch
(d30f53aeb31d453a5230f526bea592af07944564) to move a call to netif_rx(skb)
after a subsequent reference to skb, because netif_rx may call kfree_skb on
its argument.  The same problem occurs in some other drivers as well.
This was found using the following semantic match.
(http://www.emn.fr/x-info/coccinelle/)
expression skb, e,e1;
 netif_rx(skb);
 netif_rx_ni(skb);
  ... when != skb = e
  skb = e1
* skb
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
 arch/um/drivers/net_kern.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/arch/um/drivers/net_kern.c b/arch/um/drivers/net_kern.c
index 73681f1..3c6c44c 100644
--- a/arch/um/drivers/net_kern.c
+++ b/arch/um/drivers/net_kern.c
@@ -98,10 +98,10 @@ static int uml_net_rx(struct net_device *dev)
 	if (pkt_len > 0) {
 		skb_trim(skb, pkt_len);
 		skb->protocol = (*lp->protocol)(skb);
-		netif_rx(skb);
 		lp->stats.rx_bytes += skb->len;
 		lp->stats.rx_packets++;
+		netif_rx(skb);
 		return pkt_len;
 	if (pkt_len > 0) {
-		netif_rx(skb);
+		netif_rx(skb);
 		return pkt_len;
