uli526x: fix misspelling of current function in string
Author: Julia Lawall <julia.lawall@lip6.fr>
Replace a misspelled function name by %s and then __func__.
This was done using Coccinelle, including the use of Levenshtein distance,
as proposed by Rasmus Villemoes.
Signed-off-by: Julia Lawall
Signed-off-by: David S. Miller
drivers/net/ethernet/dec/tulip/uli526x.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/dec/tulip/uli526x.c b/drivers/net/ethernet/dec/tulip/uli526x.c
index 4061f9b..1c5916b 100644
--- a/drivers/net/ethernet/dec/tulip/uli526x.c
+++ b/drivers/net/ethernet/dec/tulip/uli526x.c
@@ -1837,7 +1837,7 @@ static int __init uli526x_init_module(void)
static void __exit uli526x_cleanup_module(void)
- ULI526X_DBUG(0, "uli526x_clean_module() ", debug);
+ ULI526X_DBUG(0, "uli526x_cleanup_module() ", debug);
pci_unregister_driver(&uli526x_driver);
