uio: uio_fsl_elbc_gpcm: Use module_platform_driver
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Use module_platform_driver for drivers whose init and exit functions
only register and unregister, respectively.
A simplified version of the Coccinelle semantic patch that performs
this transformation is as follows:
@a@
identifier f, x;
-static f(...) { return platform_driver_register(&x); }
@b depends on a@
identifier e, a.x;
-static e(...) { platform_driver_unregister(&x); }
@c depends on a && b@
identifier a.f;
declarer name module_init;
-module_init(f);
@d depends on a && b && c@
identifier b.e, a.x;
declarer name module_exit;
declarer name module_platform_driver;
-module_exit(e);
+module_platform_driver(x);
Signed-off-by: Vaishali Thakkar
 drivers/uio/uio_fsl_elbc_gpcm.c | 14 +-------------
 1 file changed, 1 insertion(+), 13 deletions(-)
diff --git a/drivers/uio/uio_fsl_elbc_gpcm.c b/drivers/uio/uio_fsl_elbc_gpcm.c
index b6cac91..2bcf80c 100644
--- a/drivers/uio/uio_fsl_elbc_gpcm.c
+++ b/drivers/uio/uio_fsl_elbc_gpcm.c
@@ -480,19 +480,7 @@ static struct platform_driver uio_fsl_elbc_gpcm_driver = {
 	.probe = uio_fsl_elbc_gpcm_probe,
 	.remove = uio_fsl_elbc_gpcm_remove,
-static int __init uio_fsl_elbc_gpcm_init(void)
-	return platform_driver_register(&uio_fsl_elbc_gpcm_driver);
-static void __exit uio_fsl_elbc_gpcm_exit(void)
-	platform_driver_unregister(&uio_fsl_elbc_gpcm_driver);
-module_init(uio_fsl_elbc_gpcm_init);
-module_exit(uio_fsl_elbc_gpcm_exit);
+module_platform_driver(uio_fsl_elbc_gpcm_driver);
 MODULE_LICENSE("GPL");
 MODULE_AUTHOR("John Ogness <john.ogness@linutronix.de>");
BtrLinux
Privacy Overview
