UBI: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Set the return variable to an error code as done elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Reviewed-by: Richard Weinberger
 drivers/mtd/ubi/attach.c | 4 +++-
 drivers/mtd/ubi/build.c  | 4 +++-
 2 files changed, 6 insertions(+), 2 deletions(-)
diff --git a/drivers/mtd/ubi/attach.c b/drivers/mtd/ubi/attach.c
index 33bb1f2..6f27d9a 100644
--- a/drivers/mtd/ubi/attach.c
+++ b/drivers/mtd/ubi/attach.c
@@ -1453,8 +1453,10 @@ int ubi_attach(struct ubi_device *ubi, int force_scan)
 		struct ubi_attach_info *scan_ai;
 		scan_ai = alloc_ai("ubi_ckh_aeb_slab_cache");
-		if (!scan_ai)
+		if (!scan_ai) {
+			err = -ENOMEM;
 			goto out_wl;
 		err = scan_all(ubi, scan_ai, 0);
 		if (err) {
diff --git a/drivers/mtd/ubi/build.c b/drivers/mtd/ubi/build.c
index e05dc62..57deae9 100644
--- a/drivers/mtd/ubi/build.c
+++ b/drivers/mtd/ubi/build.c
@@ -1245,8 +1245,10 @@ static int __init ubi_init(void)
 	ubi_wl_entry_slab = kmem_cache_create("ubi_wl_entry_slab",
 					      sizeof(struct ubi_wl_entry),
 					      0, 0, NULL);
-	if (!ubi_wl_entry_slab)
+	if (!ubi_wl_entry_slab) {
+		err = -ENOMEM;
 		goto out_dev_unreg;
 	err = ubi_debugfs_init();
 	if (err)
BtrLinux
Privacy Overview
