TTY: synclink: replace bitmasks add operation with OR operation.
Author: Alexandru Juncu <alexj@rosedu.org>
Found with coccinelle, manually fixed and verified.
Signed-off-by: Alexandru Juncu
 drivers/tty/synclink.c | 130 ++++++++++++++++++++++++-------------------------
 1 file changed, 65 insertions(+), 65 deletions(-)
diff --git a/drivers/tty/synclink.c b/drivers/tty/synclink.c
index 8eaf1ab..e1ce141 100644
--- a/drivers/tty/synclink.c
+++ b/drivers/tty/synclink.c
@@ -577,22 +577,22 @@ struct mgsl_struct {
 #define SICR_RXC_ACTIVE			BIT15
 #define SICR_RXC_INACTIVE		BIT14
-#define SICR_RXC			(BIT15+BIT14)
+#define SICR_RXC			(BIT15|BIT14)
 #define SICR_TXC_ACTIVE			BIT13
 #define SICR_TXC_INACTIVE		BIT12
-#define SICR_TXC			(BIT13+BIT12)
+#define SICR_TXC			(BIT13|BIT12)
 #define SICR_RI_ACTIVE			BIT11
 #define SICR_RI_INACTIVE		BIT10
-#define SICR_RI				(BIT11+BIT10)
+#define SICR_RI				(BIT11|BIT10)
 #define SICR_DSR_ACTIVE			BIT9
 #define SICR_DSR_INACTIVE		BIT8
-#define SICR_DSR			(BIT9+BIT8)
+#define SICR_DSR			(BIT9|BIT8)
 #define SICR_DCD_ACTIVE			BIT7
 #define SICR_DCD_INACTIVE		BIT6
-#define SICR_DCD			(BIT7+BIT6)
+#define SICR_DCD			(BIT7|BIT6)
 #define SICR_CTS_ACTIVE			BIT5
 #define SICR_CTS_INACTIVE		BIT4
-#define SICR_CTS			(BIT5+BIT4)
+#define SICR_CTS			(BIT5|BIT4)
 #define SICR_RCC_UNDERFLOW		BIT3
 #define SICR_DPLL_NO_SYNC		BIT2
 #define SICR_BRG1_ZERO			BIT1
@@ -1161,7 +1161,7 @@ static void mgsl_isr_receive_status( struct mgsl_struct *info )
 	u16 status = usc_InReg( info, RCSR );
-	if ( debug_level >= DEBUG_LEVEL_ISR )
+	if ( debug_level >= DEBUG_LEVEL_ISR )
 		printk("%s(%d):mgsl_isr_receive_status status=%04X\n",
 			__FILE__,__LINE__,status);
@@ -1181,7 +1181,7 @@ static void mgsl_isr_receive_status( struct mgsl_struct *info )
  			(usc_InReg(info, RICR) & ~RXSTATUS_ABORT_RECEIVED));
-	if (status & (RXSTATUS_EXITED_HUNT + RXSTATUS_IDLE_RECEIVED)) {
+	if (status & (RXSTATUS_EXITED_HUNT | RXSTATUS_IDLE_RECEIVED)) {
 		if (status & RXSTATUS_EXITED_HUNT)
 			info->icount.exithunt++;
 		if (status & RXSTATUS_IDLE_RECEIVED)
@@ -1463,21 +1463,21 @@ static void mgsl_isr_receive_data( struct mgsl_struct *info )
 		/* get the status of the received byte */
 		status = usc_InReg(info, RCSR);
-		if ( status & (RXSTATUS_FRAMING_ERROR + RXSTATUS_PARITY_ERROR +
-				RXSTATUS_OVERRUN + RXSTATUS_BREAK_RECEIVED) )
+		if ( status & (RXSTATUS_FRAMING_ERROR | RXSTATUS_PARITY_ERROR |
+				RXSTATUS_OVERRUN | RXSTATUS_BREAK_RECEIVED) )
 			usc_UnlatchRxstatusBits(info,RXSTATUS_ALL);
 		icount->rx++;
 		flag = 0;
-				RXSTATUS_OVERRUN + RXSTATUS_BREAK_RECEIVED) ) {
-			printk("rxerr=%04X\n",status);
+				RXSTATUS_OVERRUN | RXSTATUS_BREAK_RECEIVED) ) {
+			printk("rxerr=%04X\n",status);
 			/* update error statistics */
 			if ( status & RXSTATUS_BREAK_RECEIVED ) {
-				status &= ~(RXSTATUS_FRAMING_ERROR + RXSTATUS_PARITY_ERROR);
+				status &= ~(RXSTATUS_FRAMING_ERROR | RXSTATUS_PARITY_ERROR);
 				icount->brk++;
-			} else if (status & RXSTATUS_PARITY_ERROR)
+			} else if (status & RXSTATUS_PARITY_ERROR)
 				icount->parity++;
 			else if (status & RXSTATUS_FRAMING_ERROR)
 				icount->frame++;
@@ -1488,7 +1488,7 @@ static void mgsl_isr_receive_data( struct mgsl_struct *info )
 				icount->overrun++;
-			/* discard char if tty control flags say so */
+			/* discard char if tty control flags say so */
 			if (status & info->ignore_status_mask)
 				continue;
@@ -1545,8 +1545,8 @@ static void mgsl_isr_misc( struct mgsl_struct *info )
 		usc_EnableReceiver(info,DISABLE_UNCONDITIONAL);
 		usc_DmaCmd(info, DmaCmd_ResetRxChannel);
 		usc_UnlatchRxstatusBits(info, RXSTATUS_ALL);
-		usc_ClearIrqPendingBits(info, RECEIVE_DATA + RECEIVE_STATUS);
-		usc_DisableInterrupts(info, RECEIVE_DATA + RECEIVE_STATUS);
+		usc_ClearIrqPendingBits(info, RECEIVE_DATA | RECEIVE_STATUS);
+		usc_DisableInterrupts(info, RECEIVE_DATA | RECEIVE_STATUS);
 		/* schedule BH handler to restart receiver */
 		info->pending_bh |= BH_RECEIVE;
@@ -1595,7 +1595,7 @@ static void mgsl_isr_receive_dma( struct mgsl_struct *info )
 	u16 status;
 	/* clear interrupt pending and IUS bit for Rx DMA IRQ */
-	usc_OutDmaReg( info, CDIR, BIT9+BIT1 );
+	usc_OutDmaReg( info, CDIR, BIT9 | BIT1 );
 	/* Read the receive DMA status to identify interrupt type. */
 	/* This also clears the status bits. */
@@ -1639,7 +1639,7 @@ static void mgsl_isr_transmit_dma( struct mgsl_struct *info )
 	u16 status;
 	/* clear interrupt pending and IUS bit for Tx DMA IRQ */
-	usc_OutDmaReg(info, CDIR, BIT8+BIT0 );
+	usc_OutDmaReg(info, CDIR, BIT8 | BIT0 );
 	/* Read the transmit DMA status to identify interrupt type. */
@@ -1832,8 +1832,8 @@ static void shutdown(struct mgsl_struct * info)
 	usc_DisableMasterIrqBit(info);
 	usc_stop_receiver(info);
 	usc_stop_transmitter(info);
-	usc_DisableInterrupts(info,RECEIVE_DATA + RECEIVE_STATUS +
-		TRANSMIT_DATA + TRANSMIT_STATUS + IO_PIN + MISC );
+	usc_DisableInterrupts(info,RECEIVE_DATA | RECEIVE_STATUS |
+		TRANSMIT_DATA | TRANSMIT_STATUS | IO_PIN | MISC );
 	usc_DisableDmaInterrupts(info,DICR_MASTER + DICR_TRANSMIT + DICR_RECEIVE);
 	/* Disable DMAEN (Port 7, Bit 14) */
@@ -1886,7 +1886,7 @@ static void mgsl_program_hw(struct mgsl_struct *info)
 	info->ri_chkcount = 0;
 	info->dsr_chkcount = 0;
-	usc_EnableStatusIrqs(info,SICR_CTS+SICR_DSR+SICR_DCD+SICR_RI);
+	usc_EnableStatusIrqs(info,SICR_CTS+SICR_DSR+SICR_DCD+SICR_RI);
 	usc_EnableInterrupts(info, IO_PIN);
 	usc_get_serial_signals(info);
@@ -2773,7 +2773,7 @@ static int mgsl_wait_event(struct mgsl_struct * info, int __user * mask_ptr)
 		if (!waitqueue_active(&info->event_wait_q)) {
 			/* disable enable exit hunt mode/idle rcvd IRQs */
 			usc_OutReg(info, RICR, usc_InReg(info,RICR) &
-				~(RXSTATUS_EXITED_HUNT + RXSTATUS_IDLE_RECEIVED));
+				~(RXSTATUS_EXITED_HUNT | RXSTATUS_IDLE_RECEIVED));
 		spin_unlock_irqrestore(&info->irq_spinlock,flags);
@@ -3092,7 +3092,7 @@ static void mgsl_close(struct tty_struct *tty, struct file * filp)
 		printk("%s(%d):mgsl_close(%s) entry, count=%d\n",
 			 __FILE__,__LINE__, info->device_name, info->port.count);
-	if (tty_port_close_start(&info->port, tty, filp) == 0)
+	if (tty_port_close_start(&info->port, tty, filp) == 0)
 		goto cleanup;
 	mutex_lock(&info->port.mutex);
@@ -4297,7 +4297,7 @@ static struct mgsl_struct* mgsl_allocate_device(void)
 		spin_lock_init(&info->irq_spinlock);
 		spin_lock_init(&info->netlock);
 		memcpy(&info->params,&default_params,sizeof(MGSL_PARAMS));
-		info->idle_mode = HDLC_TXIDLE_FLAGS;
+		info->idle_mode = HDLC_TXIDLE_FLAGS;
 		info->num_tx_dma_buffers = 1;
 		info->num_tx_holding_buffers = 0;
@@ -4722,7 +4722,7 @@ static void usc_set_sdlc_mode( struct mgsl_struct *info )
 		else if ( info->params.flags & HDLC_FLAG_UNDERRUN_FLAG )
 			RegValue |= BIT15;
 		else if ( info->params.flags & HDLC_FLAG_UNDERRUN_CRC )
-			RegValue |= BIT15 + BIT14;
+			RegValue |= BIT15 | BIT14;
 		if ( info->params.preamble != HDLC_PREAMBLE_PATTERN_NONE )
@@ -4763,11 +4763,11 @@ static void usc_set_sdlc_mode( struct mgsl_struct *info )
 	switch ( info->params.encoding ) {
 	case HDLC_ENCODING_NRZB:               RegValue |= BIT13; break;
 	case HDLC_ENCODING_NRZI_MARK:          RegValue |= BIT14; break;
-	case HDLC_ENCODING_NRZI_SPACE:	       RegValue |= BIT14 + BIT13; break;
+	case HDLC_ENCODING_NRZI_SPACE:	       RegValue |= BIT14 | BIT13; break;
 	case HDLC_ENCODING_BIPHASE_MARK:       RegValue |= BIT15; break;
-	case HDLC_ENCODING_BIPHASE_SPACE:      RegValue |= BIT15 + BIT13; break;
-	case HDLC_ENCODING_BIPHASE_LEVEL:      RegValue |= BIT15 + BIT14; break;
-	case HDLC_ENCODING_DIFF_BIPHASE_LEVEL: RegValue |= BIT15 + BIT14 + BIT13; break;
+	case HDLC_ENCODING_BIPHASE_SPACE:      RegValue |= BIT15 | BIT13; break;
+	case HDLC_ENCODING_BIPHASE_LEVEL:      RegValue |= BIT15 | BIT14; break;
+	case HDLC_ENCODING_DIFF_BIPHASE_LEVEL: RegValue |= BIT15 | BIT14 | BIT13; break;
 	if ( (info->params.crc_type & HDLC_CRC_MASK) == HDLC_CRC_16_CCITT )
@@ -4838,15 +4838,15 @@ static void usc_set_sdlc_mode( struct mgsl_struct *info )
-		RegValue |= BIT9 + BIT8;
+		RegValue |= BIT9 | BIT8;
 	else if ( (info->params.crc_type & HDLC_CRC_MASK) == HDLC_CRC_32_CCITT )
 		RegValue |= ( BIT12 | BIT10 | BIT9 | BIT8);
@@ -4957,7 +4957,7 @@ static void usc_set_sdlc_mode( struct mgsl_struct *info )
 	RegValue = 0x0000;
-	if ( info->params.flags & (HDLC_FLAG_RXC_DPLL + HDLC_FLAG_TXC_DPLL) ) {
+	if ( info->params.flags & (HDLC_FLAG_RXC_DPLL | HDLC_FLAG_TXC_DPLL) ) {
 		u32 XtalSpeed;
 		u32 DpllDivisor;
 		u16 Tc;
@@ -5019,7 +5019,7 @@ static void usc_set_sdlc_mode( struct mgsl_struct *info )
 		case HDLC_ENCODING_BIPHASE_SPACE: RegValue |= BIT9; break;
-		case HDLC_ENCODING_DIFF_BIPHASE_LEVEL: RegValue |= BIT9 + BIT8; break;
+		case HDLC_ENCODING_DIFF_BIPHASE_LEVEL: RegValue |= BIT9 | BIT8; break;
@@ -5056,8 +5056,8 @@ static void usc_set_sdlc_mode( struct mgsl_struct *info )
 	/* enable Master Interrupt Enable bit (MIE) */
 	usc_EnableMasterIrqBit( info );
-	usc_ClearIrqPendingBits( info, RECEIVE_STATUS + RECEIVE_DATA +
-				TRANSMIT_STATUS + TRANSMIT_DATA + MISC);
+	usc_ClearIrqPendingBits( info, RECEIVE_STATUS | RECEIVE_DATA |
+				TRANSMIT_STATUS | TRANSMIT_DATA | MISC);
 	/* arm RCC underflow interrupt */
 	usc_OutReg(info, SICR, (u16)(usc_InReg(info,SICR) | BIT3));
@@ -5175,14 +5175,14 @@ static void usc_set_sdlc_mode( struct mgsl_struct *info )
 	switch ( info->params.preamble_length ) {
 	case HDLC_PREAMBLE_LENGTH_16BITS: RegValue |= BIT10; break;
 	case HDLC_PREAMBLE_LENGTH_32BITS: RegValue |= BIT11; break;
-	case HDLC_PREAMBLE_LENGTH_64BITS: RegValue |= BIT11 + BIT10; break;
+	case HDLC_PREAMBLE_LENGTH_64BITS: RegValue |= BIT11 | BIT10; break;
 	switch ( info->params.preamble ) {
-	case HDLC_PREAMBLE_PATTERN_FLAGS: RegValue |= BIT8 + BIT12; break;
+	case HDLC_PREAMBLE_PATTERN_FLAGS: RegValue |= BIT8 | BIT12; break;
 	case HDLC_PREAMBLE_PATTERN_ONES:  RegValue |= BIT8; break;
 	case HDLC_PREAMBLE_PATTERN_10:    RegValue |= BIT9; break;
-	case HDLC_PREAMBLE_PATTERN_01:    RegValue |= BIT9 + BIT8; break;
+	case HDLC_PREAMBLE_PATTERN_01:    RegValue |= BIT9 | BIT8; break;
 	usc_OutReg( info, CCR, RegValue );
@@ -5221,7 +5221,7 @@ static void usc_enable_loopback(struct mgsl_struct *info, int enable)
 	if (enable) {
 		/* blank external TXD output */
-		usc_OutReg(info,IOCR,usc_InReg(info,IOCR) | (BIT7+BIT6));
+		usc_OutReg(info,IOCR,usc_InReg(info,IOCR) | (BIT7 | BIT6));
 		/* Clock mode Control Register (CMCR)
@@ -5260,7 +5260,7 @@ static void usc_enable_loopback(struct mgsl_struct *info, int enable)
 		outw( 0x0300, info->io_base + CCAR );
 	} else {
 		/* enable external TXD output */
-		usc_OutReg(info,IOCR,usc_InReg(info,IOCR) & ~(BIT7+BIT6));
+		usc_OutReg(info,IOCR,usc_InReg(info,IOCR) & ~(BIT7 | BIT6));
 		/* clear Internal Data loopback mode */
 		info->loopback_bits = 0;
@@ -5447,13 +5447,13 @@ static void usc_process_rxoverrun_sync( struct mgsl_struct *info )
 		usc_OutDmaReg( info, NRARU, (u16)(phys_addr >> 16) );
 		usc_UnlatchRxstatusBits( info, RXSTATUS_ALL );
-		usc_ClearIrqPendingBits( info, RECEIVE_DATA + RECEIVE_STATUS );
+		usc_ClearIrqPendingBits( info, RECEIVE_DATA | RECEIVE_STATUS );
 		usc_EnableInterrupts( info, RECEIVE_STATUS );
 		/* 1. Arm End of Buffer (EOB) Receive DMA Interrupt (BIT2 of RDIAR) */
 		/* 2. Enable Receive DMA Interrupts (BIT1 of DICR) */
-		usc_OutDmaReg( info, RDIAR, BIT3 + BIT2 );
+		usc_OutDmaReg( info, RDIAR, BIT3 | BIT2 );
 		usc_OutDmaReg( info, DICR, (u16)(usc_InDmaReg(info,DICR) | BIT1) );
 		usc_DmaCmd( info, DmaCmd_InitRxChannel );
 		if ( info->params.flags & HDLC_FLAG_AUTO_DCD )
@@ -5488,8 +5488,8 @@ static void usc_stop_receiver( struct mgsl_struct *info )
 	usc_DmaCmd( info, DmaCmd_ResetRxChannel );
-	usc_DisableInterrupts( info, RECEIVE_DATA + RECEIVE_STATUS );
+	usc_DisableInterrupts( info, RECEIVE_DATA | RECEIVE_STATUS );
@@ -5536,13 +5536,13 @@ static void usc_start_receiver( struct mgsl_struct *info )
@@ -5551,7 +5551,7 @@ static void usc_start_receiver( struct mgsl_struct *info )
 			usc_EnableReceiver(info,ENABLE_UNCONDITIONAL);
 	} else {
 		usc_EnableInterrupts(info, RECEIVE_DATA);
 		usc_RTCmd( info, RTCmd_PurgeRxFifo );
@@ -5925,7 +5925,7 @@ static void usc_set_async_mode( struct mgsl_struct *info )
 	RegValue = 0;
 	if ( info->params.data_bits != 8 )
-		RegValue |= BIT4+BIT3+BIT2;
+		RegValue |= BIT4 | BIT3 | BIT2;
 	if ( info->params.parity != ASYNC_PARITY_NONE ) {
 		RegValue |= BIT5;
@@ -5982,7 +5982,7 @@ static void usc_set_async_mode( struct mgsl_struct *info )
 	RegValue = 0;
 		RegValue |= BIT5;
@@ -6129,7 +6129,7 @@ static void usc_loopback_frame( struct mgsl_struct *info )
 	/* WAIT FOR RECEIVE COMPLETE */
 	for (i=0 ; i<1000 ; i++)
-		if (usc_InReg( info, RCSR ) & (BIT8 + BIT4 + BIT3 + BIT1))
+		if (usc_InReg( info, RCSR ) & (BIT8 | BIT4 | BIT3 | BIT1))
 			break;
@@ -6579,8 +6579,8 @@ static bool mgsl_get_rx_frame(struct mgsl_struct *info)
 	status = info->rx_buffer_list[EndIndex].status;
-	if ( status & (RXSTATUS_SHORT_FRAME + RXSTATUS_OVERRUN +
-			RXSTATUS_CRC_ERROR + RXSTATUS_ABORT) ) {
+	if ( status & (RXSTATUS_SHORT_FRAME | RXSTATUS_OVERRUN |
+			RXSTATUS_CRC_ERROR | RXSTATUS_ABORT) ) {
 		if ( status & RXSTATUS_SHORT_FRAME )
 			info->icount.rxshort++;
 		else if ( status & RXSTATUS_ABORT )
@@ -6762,8 +6762,8 @@ static bool mgsl_get_raw_rx_frame(struct mgsl_struct *info)
 		status = info->rx_buffer_list[CurrentIndex].status;
@@ -6899,7 +6899,7 @@ static void mgsl_load_tx_dma_buffer(struct mgsl_struct *info,
 		/* set CMR:13 to start transmit when
 		 * next GoAhead (abort) is received
-	 	info->cmr_value |= BIT13;
+	 	info->cmr_value |= BIT13;
 	/* begin loading the frame in the next available tx dma
@@ -7278,7 +7278,7 @@ static bool mgsl_dma_test( struct mgsl_struct *info )
 		/* WAIT FOR TRANSMIT COMPLETE */
@@ -7292,7 +7292,7 @@ static bool mgsl_dma_test( struct mgsl_struct *info )
 		status = usc_InReg( info, TCSR );
-		while ( !(status & (BIT6+BIT5+BIT4+BIT2+BIT1)) ) {
+		while ( !(status & (BIT6 | BIT5 | BIT4 | BIT2 | BIT1)) ) {
 			if (time_after(jiffies, EndTime)) {
 				rc = false;
 				break;
@@ -7307,7 +7307,7 @@ static bool mgsl_dma_test( struct mgsl_struct *info )
 	if ( rc ){
 		/* CHECK FOR TRANSMIT ERRORS */
-		if ( status & (BIT5 + BIT1) )
+		if ( status & (BIT5 | BIT1) )
 			rc = false;
@@ -7333,7 +7333,7 @@ static bool mgsl_dma_test( struct mgsl_struct *info )
 		/* CHECK FOR RECEIVE ERRORS */
 		status = info->rx_buffer_list[0].status;
-		if ( status & (BIT8 + BIT3 + BIT1) ) {
+		if ( status & (BIT8 | BIT3 | BIT1) ) {
 			/* receive error has occurred */
 			rc = false;
 		} else {
@@ -7605,7 +7605,7 @@ static void usc_loopmode_send_done( struct mgsl_struct * info )
  	info->loopmode_send_done_requested = false;
  	/* clear CMR:13 to 0 to start echoing RxData to TxData */
- 	info->cmr_value &= ~BIT13;
+ 	info->cmr_value &= ~BIT13;
  	usc_OutReg(info, CMR, info->cmr_value);
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
