TTY: serial: move the dereference below the NULL test
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
The dereference should be moved below the NULL test.
spatch with a semantic match is used to found this.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
 drivers/tty/serial/ioc3_serial.c | 3 ++-
 drivers/tty/serial/ioc4_serial.c | 3 ++-
 2 files changed, 4 insertions(+), 2 deletions(-)
diff --git a/drivers/tty/serial/ioc3_serial.c b/drivers/tty/serial/ioc3_serial.c
index 758ff310..5ac5289 100644
--- a/drivers/tty/serial/ioc3_serial.c
+++ b/drivers/tty/serial/ioc3_serial.c
@@ -1120,13 +1120,14 @@ static inline int do_read(struct uart_port *the_port, char *buf, int len)
 	struct ioc3_port *port = get_ioc3_port(the_port);
 	struct ring *inring;
 	struct ring_entry *entry;
-	struct port_hooks *hooks = port->ip_hooks;
+	struct port_hooks *hooks;
 	int byte_num;
 	char *sc;
 	int loop_counter;
 	BUG_ON(!(len >= 0));
 	BUG_ON(!port);
+	hooks = port->ip_hooks;
 	/* There is a nasty timing issue in the IOC3. When the rx_timer
 	 * expires or the rx_high condition arises, we take an interrupt.
diff --git a/drivers/tty/serial/ioc4_serial.c b/drivers/tty/serial/ioc4_serial.c
index cc5aca7..3e7da10 100644
--- a/drivers/tty/serial/ioc4_serial.c
+++ b/drivers/tty/serial/ioc4_serial.c
@@ -2069,13 +2069,14 @@ static inline int do_read(struct uart_port *the_port, unsigned char *buf,
 	struct ioc4_port *port = get_ioc4_port(the_port, 0);
-	struct hooks *hooks = port->ip_hooks;
+	struct hooks *hooks;
 	int byte_num;
 	char *sc;
 	int loop_counter;
 	BUG_ON(!port);
 	/* There is a nasty timing issue in the IOC4. When the rx_timer
BtrLinux
Privacy Overview
