tty: ioc4_serial.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
CC: Pat Gefre
CC: Jiri Slaby
drivers/tty/serial/ioc4_serial.c | 9 ++++++---
1 file changed, 6 insertions(+), 3 deletions(-)
diff --git a/drivers/tty/serial/ioc4_serial.c b/drivers/tty/serial/ioc4_serial.c
index aa28209..e5c42fe 100644
--- a/drivers/tty/serial/ioc4_serial.c
+++ b/drivers/tty/serial/ioc4_serial.c
@@ -1011,7 +1011,8 @@ static irqreturn_t ioc4_intr(int irq, void *arg)
for (xx = 0; xx < num_intrs; xx++) {
intr_info = &soft->is_intr_type[intr_type].is_intr_info[xx];
- if ((this_mir = this_ir & intr_info->sd_bits)) {
+ this_mir = this_ir & intr_info->sd_bits;
+ if (this_mir) {
/* Disable owned interrupts, call handler */
handled++;
write_ireg(soft, intr_info->sd_bits, IOC4_W_IEC,
@@ -2865,10 +2866,12 @@ ioc4_serial_attach_one(struct ioc4_driver_data *idd)
/* register port with the serial core - 1 rs232, 1 rs422 */
- if ((ret = ioc4_serial_core_attach(idd->idd_pdev, PROTO_RS232)))
+ ret = ioc4_serial_core_attach(idd->idd_pdev, PROTO_RS232);
+ if (ret)
goto out4;
- if ((ret = ioc4_serial_core_attach(idd->idd_pdev, PROTO_RS422)))
+ ret = ioc4_serial_core_attach(idd->idd_pdev, PROTO_RS422);
+ if (ret)
goto out5;
Num_of_ioc4_cards++; |
+ if (this_mir) {
handled++;
+ if (ret)
goto out4;
+ if (ret)
goto out5;
