tty-hvsi_lib: Deletion of an unnecessary check before the function call “tty_kref_put”
Author: Markus Elfring <elfring@users.sourceforge.net>
The tty_kref_put() function tests whether its argument is NULL and then
returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
 drivers/tty/hvc/hvsi_lib.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/tty/hvc/hvsi_lib.c b/drivers/tty/hvc/hvsi_lib.c
index 7ae6c29..a270f04 100644
--- a/drivers/tty/hvc/hvsi_lib.c
+++ b/drivers/tty/hvc/hvsi_lib.c
@@ -405,8 +405,7 @@ void hvsilib_close(struct hvsi_priv *pv, struct hvc_struct *hp)
 		hvsi_send_close(pv);
-	if (pv->tty)
-		tty_kref_put(pv->tty);
+	tty_kref_put(pv->tty);
 	pv->tty = NULL;
