TTY: fix misspelling of current function in string
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Replace the last argument of serial_paranoia_check by the actual function
name.
This was done using Coccinelle, including the use of Levenshtein distance,
as proposed by Rasmus Villemoes.
Signed-off-by: Julia Lawall
drivers/tty/amiserial.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/tty/amiserial.c b/drivers/tty/amiserial.c
index d9f85f9..b2d7600 100644
--- a/drivers/tty/amiserial.c
+++ b/drivers/tty/amiserial.c
@@ -931,7 +931,7 @@ static void rs_send_xchar(struct tty_struct *tty, char ch)
struct serial_state *info = tty->driver_data;
unsigned long flags;
- if (serial_paranoia_check(info, tty->name, "rs_send_char"))
+ if (serial_paranoia_check(info, tty->name, "rs_send_xchar"))
return;
info->x_char = ch; |
return;
info->x_char = ch;
