tty: consolemap.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
CC: Jiri Slaby
CC: Takashi Iwai
CC: Imre Deak
 drivers/tty/vt/consolemap.c | 60 ++++++++++++++++++++++++++++-----------------
 1 file changed, 37 insertions(+), 23 deletions(-)
diff --git a/drivers/tty/vt/consolemap.c b/drivers/tty/vt/consolemap.c
index 59b25e0..c8c91f0 100644
--- a/drivers/tty/vt/consolemap.c
+++ b/drivers/tty/vt/consolemap.c
@@ -261,19 +261,22 @@ u16 inverse_translate(struct vc_data *conp, int glyph, int use_unicode)
 	int m;
 	if (glyph < 0 || glyph >= MAX_GLYPH)
 		return 0;
-	else if (!(p = *conp->vc_uni_pagedir_loc))
-		return glyph;
-	else if (use_unicode) {
-		if (!p->inverse_trans_unicode)
+	else {
+		p = *conp->vc_uni_pagedir_loc;
+		if (!p)
 			return glyph;
-		else
-			return p->inverse_trans_unicode[glyph];
-	} else {
-		m = inv_translate[conp->vc_num];
-		if (!p->inverse_translations[m])
-			return glyph;
-		else
-			return p->inverse_translations[m][glyph];
+		else if (use_unicode) {
+			if (!p->inverse_trans_unicode)
+				return glyph;
+			else
+				return p->inverse_trans_unicode[glyph];
+			} else {
+			m = inv_translate[conp->vc_num];
+			if (!p->inverse_translations[m])
+				return glyph;
+			else
+				return p->inverse_translations[m][glyph];
 EXPORT_SYMBOL_GPL(inverse_translate);
@@ -397,7 +400,8 @@ static void con_release_unimap(struct uni_pagedir *p)
 	if (p == dflt) dflt = NULL;
 	for (i = 0; i < 32; i++) {
-		if ((p1 = p->uni_pgdir[i]) != NULL) {
+		p1 = p->uni_pgdir[i];
+		if (p1 != NULL) {
 			for (j = 0; j < 32; j++)
 				kfree(p1[j]);
 			kfree(p1);
@@ -473,14 +477,16 @@ con_insert_unipair(struct uni_pagedir *p, u_short unicode, u_short fontpos)
 	int i, n;
 	u16 **p1, *p2;
-	if (!(p1 = p->uni_pgdir[n = unicode >> 11])) {
+	p1 = p->uni_pgdir[n = unicode >> 11];
+	if (!p1) {
 		p1 = p->uni_pgdir[n] = kmalloc(32*sizeof(u16 *), GFP_KERNEL);
 		if (!p1) return -ENOMEM;
 			p1[i] = NULL;
-	if (!(p2 = p1[n = (unicode >> 6) & 0x1f])) {
+	p2 = p1[n = (unicode >> 6) & 0x1f];
+	if (!p2) {
 		p2 = p1[n] = kmalloc(64*sizeof(u16), GFP_KERNEL);
 		if (!p2) return -ENOMEM;
 		memset(p2, 0xff, 64*sizeof(u16)); /* No glyphs for the characters (yet) */
@@ -569,10 +575,12 @@ int con_set_unimap(struct vc_data *vc, ushort ct, struct unipair __user *list)
 		 * entries from "p" (old) to "q" (new).
 		l = 0;		/* unicode value */
-		for (i = 0; i < 32; i++)
-		if ((p1 = p->uni_pgdir[i]))
-			for (j = 0; j < 32; j++)
-			if ((p2 = p1[j])) {
+		for (i = 0; i < 32; i++) {
+		if (p1)
+			for (j = 0; j < 32; j++) {
+			p2 = p1[j];
+			if (p2) {
 				for (k = 0; k < 64; k++, l++)
 				if (p2[k] != 0xffff) {
@@ -593,9 +601,11 @@ int con_set_unimap(struct vc_data *vc, ushort ct, struct unipair __user *list)
 				/* Account for row of 64 empty entries */
 				l += 64;
 		else
 			/* Account for empty table */
 			l += 32 * 64;
 		 * Finished copying font table, set vc_uni_pagedir to new table
@@ -735,10 +745,12 @@ int con_get_unimap(struct vc_data *vc, ushort ct, ushort __user *uct, struct uni
 	ect = 0;
 	if (*vc->vc_uni_pagedir_loc) {
 		p = *vc->vc_uni_pagedir_loc;
-			if ((p2 = *(p1++)))
+		if (p1)
+			p2 = *(p1++);
+			if (p2)
 				for (k = 0; k < 64; k++) {
 					if (*p2 < MAX_GLYPH && ect++ < ct) {
 						__put_user((u_short)((i<<11)+(j<<6)+k),
@@ -749,6 +761,8 @@ int con_get_unimap(struct vc_data *vc, ushort ct, ushort __user *uct, struct uni
 					p2++;
 	__put_user(ect, uct);
 	console_unlock();
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
