tty: 68328serial.c: move assignment out of if () block
Author: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
We should not be doing assignments within an if () block
so fix up the code to not do this.
change was created using Coccinelle.
CC: Jiri Slaby
 drivers/tty/serial/68328serial.c | 3 ++-
 1 file changed, 2 insertions(+), 1 deletion(-)
diff --git a/drivers/tty/serial/68328serial.c b/drivers/tty/serial/68328serial.c
index 5dc9c4b..748c18f 100644
--- a/drivers/tty/serial/68328serial.c
+++ b/drivers/tty/serial/68328serial.c
@@ -508,7 +508,8 @@ static void change_speed(struct m68k_serial *info, struct tty_struct *tty)
 	int	i;
 	cflag = tty->termios.c_cflag;
-	if (!(port = info->port))
+	port = info->port;
+	if (!port)
 		return;
 	ustcnt = uart->ustcnt;
BtrLinux
Privacy Overview
