tracing: kernel/trace/trace.c: introduce missing kfree()
Impact: fix memory leak
Error handling code following a kzalloc should free the allocated data.
The semantic match that finds the problem is as follows:
(http://www.emn.fr/x-info/coccinelle/)
@r exists@
local idexpression x;
statement S;
expression E;
identifier f,l;
position p1,p2;
expression *ptr != NULL;
if ((x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...)) == NULL) S
x@p1 = \(kmalloc\|kzalloc\|kcalloc\)(...);
if (x == NULL) S
<... when != x
     when != if (...) { <+...x...+> }
x->f = E
 return \(0\|<+...x...+>\|ptr\);
 return@p2 ...;
@script:python@
p1 << r.p1;
p2 << r.p2;
print "* file: %s kmalloc %s return %s" % (p1[0].file,p1[0].line,p2[0].line)
Signed-off-by: Julia Lawall
Signed-off-by: Steven Rostedt
Signed-off-by: Ingo Molnar
 kernel/trace/trace.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/kernel/trace/trace.c b/kernel/trace/trace.c
index 697eda3..d86e325 100644
--- a/kernel/trace/trace.c
+++ b/kernel/trace/trace.c
@@ -1936,6 +1936,7 @@ __tracing_open(struct inode *inode, struct file *file, int *ret)
 			ring_buffer_read_finish(iter->buffer_iter[cpu]);
 	mutex_unlock(&trace_types_lock);
+	kfree(iter);
 	return ERR_PTR(-ENOMEM);
+	kfree(iter);
