ti-soc-thermal: Delete an unnecessary check before the function call “cpufreq_cooling_unregister”
Author: Markus Elfring <elfring@users.sourceforge.net>
The cpufreq_cooling_unregister() function tests whether its argument is NULL
and then returns immediately. Thus the test around the call is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Eduardo Valentin
drivers/thermal/ti-soc-thermal/ti-thermal-common.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/thermal/ti-soc-thermal/ti-thermal-common.c b/drivers/thermal/ti-soc-thermal/ti-thermal-common.c
index 3fb054a..a38c175 100644
--- a/drivers/thermal/ti-soc-thermal/ti-thermal-common.c
+++ b/drivers/thermal/ti-soc-thermal/ti-thermal-common.c
@@ -429,7 +429,7 @@ int ti_thermal_unregister_cpu_cooling(struct ti_bandgap *bgp, int id)
data = ti_bandgap_get_sensor_data(bgp, id);
- if (data && data->cool_dev)
+ if (data)
cpufreq_cooling_unregister(data->cool_dev);
return 0; |
+ if (data)
return 0;
