thermal: int3403: Delete a check before thermal_zone_device_unregister()
Author: Markus Elfring <elfring@users.sourceforge.net>
The thermal_zone_device_unregister() function tests whether its argument
is NULL and then returns immediately. Thus the test around the call
is not needed.
This issue was detected by using the Coccinelle software.
Signed-off-by: Markus Elfring
Signed-off-by: Zhang Rui
 drivers/thermal/int340x_thermal/int3403_thermal.c | 3 +--
 1 file changed, 1 insertion(+), 2 deletions(-)
diff --git a/drivers/thermal/int340x_thermal/int3403_thermal.c b/drivers/thermal/int340x_thermal/int3403_thermal.c
index 6e9fb62..790b8f6 100644
--- a/drivers/thermal/int340x_thermal/int3403_thermal.c
+++ b/drivers/thermal/int340x_thermal/int3403_thermal.c
@@ -293,8 +293,7 @@ static int int3403_sensor_add(struct int3403_priv *priv)
 	return 0;
  err_free_obj:
-	if (obj->tzone)
-		thermal_zone_device_unregister(obj->tzone);
+	thermal_zone_device_unregister(obj->tzone);
 	return result;
BtrLinux
Privacy Overview
