Thermal: fix platform_no_drv_owner.cocci warnings
Author: Wu Fengguang <fengguang.wu@intel.com>
drivers/thermal/int340x_thermal/int3403_thermal.c:468:3-8: No need to set .owner here. The core will do it.
 Remove .owner field if calls are used which set it automatically
Generated by: scripts/coccinelle/api/platform_no_drv_owner.cocci
Signed-off-by: Fengguang Wu
Acked-by: Zhang Rui
Signed-off-by: Zhang Rui
 drivers/thermal/int340x_thermal/int3403_thermal.c | 1 -
 1 file changed, 1 deletion(-)
diff --git a/drivers/thermal/int340x_thermal/int3403_thermal.c b/drivers/thermal/int340x_thermal/int3403_thermal.c
index 790b8f6..1bfa6a6 100644
--- a/drivers/thermal/int340x_thermal/int3403_thermal.c
+++ b/drivers/thermal/int340x_thermal/int3403_thermal.c
@@ -470,7 +470,6 @@ static struct platform_driver int3403_driver = {
 	.remove = int3403_remove,
 	.driver = {
 		.name = "int3403 thermal",
-		.owner  = THIS_MODULE,
 		.acpi_match_table = int3403_device_ids,
BtrLinux
Privacy Overview
