thermal: exynos: fix error return code
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Set the return variable to an error code as done elsewhere in the function.
A simplified version of the semantic match that finds this problem is as
follows: (http://coccinelle.lip6.fr/)
if@p1 (\(ret < 0\|ret != 0\))
 { ... return ret; }
ret@p1 = 0
... when != ret = e1
    when != &ret
*if(...)
  ... when != ret = e2
      when forall
 return ret;
Signed-off-by: Julia Lawall
Reviewed-by: Jingoo Han
Signed-off-by: Zhang Rui
 drivers/thermal/samsung/exynos_tmu.c | 1 +
 1 file changed, 1 insertion(+)
diff --git a/drivers/thermal/samsung/exynos_tmu.c b/drivers/thermal/samsung/exynos_tmu.c
index 32f38b9..0d96a51 100644
--- a/drivers/thermal/samsung/exynos_tmu.c
+++ b/drivers/thermal/samsung/exynos_tmu.c
@@ -205,6 +205,7 @@ static int exynos_tmu_initialize(struct platform_device *pdev)
 skip_calib_data:
 	if (pdata->max_trigger_level > MAX_THRESHOLD_LEVS) {
 		dev_err(&pdev->dev, "Invalid max trigger level\n");
+		ret = -EINVAL;
 		goto out;
BtrLinux
Privacy Overview
