target: remove unneeded array
Author: Julia Lawall <Julia.Lawall@lip6.fr>
Delete a local array that is only used to be initialized by memset.
A semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
identifier x;
type T;
... when any
-T x[...];
<+... when != x
- memset(x,...);
Signed-off-by: Julia Lawall
Signed-off-by: Nicholas Bellinger
 drivers/target/target_core_pr.c | 7 ++-----
 1 file changed, 2 insertions(+), 5 deletions(-)
diff --git a/drivers/target/target_core_pr.c b/drivers/target/target_core_pr.c
index 9f93b82..f91b6a1 100644
--- a/drivers/target/target_core_pr.c
+++ b/drivers/target/target_core_pr.c
@@ -1429,14 +1429,12 @@ core_scsi3_decode_spec_i_port(
 	struct target_core_fabric_ops *tmp_tf_ops;
 	unsigned char *buf;
 	unsigned char *ptr, *i_str = NULL, proto_ident, tmp_proto_ident;
-	char *iport_ptr = NULL, dest_iport[64], i_buf[PR_REG_ISID_ID_LEN];
+	char *iport_ptr = NULL, i_buf[PR_REG_ISID_ID_LEN];
 	sense_reason_t ret;
 	u32 tpdl, tid_len = 0;
 	int dest_local_nexus;
 	u32 dest_rtpi = 0;
-	memset(dest_iport, 0, 64);
 	local_se_deve = se_sess->se_node_acl->device_list[cmd->orig_fe_lun];
 	 * Allocate a struct pr_transport_id_holder and setup the
@@ -3059,7 +3057,7 @@ core_scsi3_emulate_pro_register_and_move(struct se_cmd *cmd, u64 res_key,
 	struct t10_reservation *pr_tmpl = &dev->t10_pr;
 	unsigned char *buf;
 	unsigned char *initiator_str;
 	u32 tid_len, tmp_tid_len;
 	int new_reg = 0, type, scope, matching_iname;
 	sense_reason_t ret;
@@ -3071,7 +3069,6 @@ core_scsi3_emulate_pro_register_and_move(struct se_cmd *cmd, u64 res_key,
 		return TCM_LOGICAL_UNIT_COMMUNICATION_FAILURE;
 	memset(i_buf, 0, PR_REG_ISID_ID_LEN);
 	se_tpg = se_sess->se_tpg;
 	tf_ops = se_tpg->se_tpg_tfo;
BtrLinux
Privacy Overview
