target: move the dereference below the NULL test
Author: Wei Yongjun <yongjun_wei@trendmicro.com.cn>
The dereference should be moved below the NULL test.
spatch with a semantic match is used to found this.
(http://coccinelle.lip6.fr/)
Signed-off-by: Wei Yongjun
Signed-off-by: Nicholas Bellinger
 drivers/target/target_core_pr.c | 10 ++++++----
 1 file changed, 6 insertions(+), 4 deletions(-)
diff --git a/drivers/target/target_core_pr.c b/drivers/target/target_core_pr.c
index 3f8aac3..8c323a9 100644
--- a/drivers/target/target_core_pr.c
+++ b/drivers/target/target_core_pr.c
@@ -197,10 +197,10 @@ int target_scsi2_reservation_release(struct se_cmd *cmd)
 	struct se_device *dev = cmd->se_dev;
 	struct se_session *sess = cmd->se_sess;
-	struct se_portal_group *tpg = sess->se_tpg;
+	struct se_portal_group *tpg;
 	int ret = 0, rc;
-	if (!sess || !tpg)
+	if (!sess || !sess->se_tpg)
 		goto out;
 	rc = target_check_scsi2_reservation_conflict(cmd);
 	if (rc == 1)
@@ -228,6 +228,7 @@ int target_scsi2_reservation_release(struct se_cmd *cmd)
 		dev->dev_res_bin_isid = 0;
 		dev->dev_flags &= ~DF_SPC2_RESERVATIONS_WITH_ISID;
+	tpg = sess->se_tpg;
 	pr_debug("SCSI-2 Released reservation for %s LUN: %u ->"
 		" MAPPED LUN: %u for %s\n", tpg->se_tpg_tfo->get_fabric_name(),
 		cmd->se_lun->unpacked_lun, cmd->se_deve->mapped_lun,
@@ -245,7 +246,7 @@ int target_scsi2_reservation_reserve(struct se_cmd *cmd)
 	int ret = 0, rc;
 	if ((cmd->t_task_cdb[1] & 0x01) &&
@@ -260,7 +261,7 @@ int target_scsi2_reservation_reserve(struct se_cmd *cmd)
 	 * This is currently the case for target_core_mod passthrough struct se_cmd
 	 * ops
 		goto out;
 	if (rc == 1)
@@ -272,6 +273,7 @@ int target_scsi2_reservation_reserve(struct se_cmd *cmd)
 	ret = 0;
 	spin_lock(&dev->dev_reservation_lock);
 	if (dev->dev_reserved_node_acl &&
 	   (dev->dev_reserved_node_acl != sess->se_node_acl)) {
BtrLinux
Privacy Overview
