stmmac: fix noderef.cocci warnings
Author: Wu Fengguang <fengguang.wu@intel.com>
drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c:115:15-21: ERROR: application of sizeof to pointer
sizeof when applied to a pointer typed expression gives the size of
the pointer
Generated by: scripts/coccinelle/misc/noderef.cocci
CC: Giuseppe Cavallaro
Signed-off-by: Fengguang Wu
Signed-off-by: David S. Miller
drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c b/drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
index 69ccf48..9cf181f 100644
--- a/drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
+++ b/drivers/net/ethernet/stmicro/stmmac/stmmac_platform.c
@@ -112,7 +112,7 @@ static struct stmmac_axi *stmmac_axi_setup(struct platform_device *pdev)
if (!np)
return NULL;
- axi = kzalloc(sizeof(axi), GFP_KERNEL);
+ axi = kzalloc(sizeof(*axi), GFP_KERNEL);
if (!axi)
return ERR_PTR(-ENOMEM); |
if (!np)
return NULL;
if (!axi)
