Staging:wlan-ng:Merged two lines into one
Author: Bhumika Goyal <bhumirks@gmail.com>
The last two lines of these functions are compressed into one.
Also removed the variable ret as it is now not used.
Found using coccinelle:
expression e, ret;
-ret =
+return
     e;
-return ret;
Signed-off-by: Bhumika Goyal
 drivers/staging/wlan-ng/hfa384x_usb.c | 20 ++++----------------
 1 file changed, 4 insertions(+), 16 deletions(-)
diff --git a/drivers/staging/wlan-ng/hfa384x_usb.c b/drivers/staging/wlan-ng/hfa384x_usb.c
index 682de77..fda8a95 100644
--- a/drivers/staging/wlan-ng/hfa384x_usb.c
+++ b/drivers/staging/wlan-ng/hfa384x_usb.c
@@ -1012,7 +1012,6 @@ int hfa384x_cmd_initialize(hfa384x_t *hw)
 int hfa384x_cmd_disable(hfa384x_t *hw, u16 macport)
-	int result = 0;
 	hfa384x_metacmd_t cmd;
 	cmd.cmd = HFA384x_CMD_CMDCODE_SET(HFA384x_CMDCODE_DISABLE) |
@@ -1021,9 +1020,7 @@ int hfa384x_cmd_disable(hfa384x_t *hw, u16 macport)
 	cmd.parm1 = 0;
 	cmd.parm2 = 0;
-	result = hfa384x_docmd_wait(hw, &cmd);
-	return result;
+	return hfa384x_docmd_wait(hw, &cmd);
@@ -1048,7 +1045,6 @@ int hfa384x_cmd_disable(hfa384x_t *hw, u16 macport)
 int hfa384x_cmd_enable(hfa384x_t *hw, u16 macport)
-	int result = 0;
 	cmd.cmd = HFA384x_CMD_CMDCODE_SET(HFA384x_CMDCODE_ENABLE) |
@@ -1057,9 +1053,7 @@ int hfa384x_cmd_enable(hfa384x_t *hw, u16 macport)
 	cmd.parm1 = 0;
 	cmd.parm2 = 0;
-	return result;
@@ -1093,7 +1087,6 @@ int hfa384x_cmd_enable(hfa384x_t *hw, u16 macport)
 int hfa384x_cmd_monitor(hfa384x_t *hw, u16 enable)
-	int result = 0;
 	cmd.cmd = HFA384x_CMD_CMDCODE_SET(HFA384x_CMDCODE_MONITOR) |
@@ -1102,9 +1095,7 @@ int hfa384x_cmd_monitor(hfa384x_t *hw, u16 enable)
 	cmd.parm1 = 0;
 	cmd.parm2 = 0;
-	return result;
@@ -1148,7 +1139,6 @@ int hfa384x_cmd_monitor(hfa384x_t *hw, u16 enable)
 int hfa384x_cmd_download(hfa384x_t *hw, u16 mode, u16 lowaddr,
 			 u16 highaddr, u16 codelen)
-	int result = 0;
 	pr_debug("mode=%d, lowaddr=0x%04x, highaddr=0x%04x, codelen=%d\n",
@@ -1161,9 +1151,7 @@ int hfa384x_cmd_download(hfa384x_t *hw, u16 mode, u16 lowaddr,
 	cmd.parm1 = highaddr;
 	cmd.parm2 = codelen;
-	return result;
BtrLinux
Privacy Overview
