staging:media: Removed assignments from if statements.
Author: Chi Pham <fempsci@gmail.com>
The following coccinelle script found the match:
@simple@
expression E1, E2;
statement S1, S2;
+ E1 = E2;
if (
- (E1 = E2)
+ E1
S1 else S2
@left@
expression E0, E1, E2;
statement S0, S1;
- if ((E1 = E2) < E0)
+ E1 = E2;
+ if (E1 < E0)
S1
Signed-off-by: Chi Pham
 drivers/staging/media/sn9c102/sn9c102_core.c      | 76 +++++++++++++++--------
 drivers/staging/media/sn9c102/sn9c102_hv7131d.c   | 15 +++--
 drivers/staging/media/sn9c102/sn9c102_hv7131r.c   | 15 +++--
 drivers/staging/media/sn9c102/sn9c102_ov7630.c    | 24 ++++---
 drivers/staging/media/sn9c102/sn9c102_ov7660.c    | 24 ++++---
 drivers/staging/media/sn9c102/sn9c102_pas106b.c   | 18 ++++--
 drivers/staging/media/sn9c102/sn9c102_pas202bcb.c | 15 +++--
 7 files changed, 124 insertions(+), 63 deletions(-)
diff --git a/drivers/staging/media/sn9c102/sn9c102_core.c b/drivers/staging/media/sn9c102/sn9c102_core.c
index 7be25b0..71f594f 100644
--- a/drivers/staging/media/sn9c102/sn9c102_core.c
+++ b/drivers/staging/media/sn9c102/sn9c102_core.c
@@ -158,8 +158,8 @@ sn9c102_request_buffers(struct sn9c102_device* cam, u32 count,
 	cam->nbuffers = count;
 	while (cam->nbuffers > 0) {
-		if ((buff = vmalloc_32_user(cam->nbuffers *
-					    PAGE_ALIGN(imagesize))))
+		buff = vmalloc_32_user(cam->nbuffers * PAGE_ALIGN(imagesize));
+		if (buff)
 			break;
 		cam->nbuffers--;
@@ -1121,7 +1121,8 @@ static ssize_t sn9c102_show_val(struct device* cd,
 		return -ENODEV;
-	if ((val = sn9c102_read_reg(cam, cam->sysfs.reg)) < 0) {
+	val = sn9c102_read_reg(cam, cam->sysfs.reg);
+	if (val < 0) {
 		mutex_unlock(&sn9c102_sysfs_lock);
 		return -EIO;
@@ -1256,7 +1257,8 @@ static ssize_t sn9c102_show_i2c_val(struct device* cd,
 		return -ENOSYS;
-	if ((val = sn9c102_i2c_read(cam, cam->sysfs.i2c_reg)) < 0) {
+	val = sn9c102_i2c_read(cam, cam->sysfs.i2c_reg);
+	if (val < 0) {
 		return -EIO;
@@ -1440,27 +1442,35 @@ static int sn9c102_create_sysfs(struct sn9c102_device* cam)
 	struct device *dev = &(cam->v4ldev->dev);
 	int err = 0;
-	if ((err = device_create_file(dev, &dev_attr_reg)))
+	err = device_create_file(dev, &dev_attr_reg);
+	if (err)
 		goto err_out;
-	if ((err = device_create_file(dev, &dev_attr_val)))
+	err = device_create_file(dev, &dev_attr_val);
+	if (err)
 		goto err_reg;
-	if ((err = device_create_file(dev, &dev_attr_frame_header)))
+	err = device_create_file(dev, &dev_attr_frame_header);
+	if (err)
 		goto err_val;
 	if (cam->sensor.sysfs_ops) {
-		if ((err = device_create_file(dev, &dev_attr_i2c_reg)))
+		err = device_create_file(dev, &dev_attr_i2c_reg);
+		if (err)
 			goto err_frame_header;
-		if ((err = device_create_file(dev, &dev_attr_i2c_val)))
+		err = device_create_file(dev, &dev_attr_i2c_val);
+		if (err)
 			goto err_i2c_reg;
 	if (cam->bridge == BRIDGE_SN9C101 || cam->bridge == BRIDGE_SN9C102) {
-		if ((err = device_create_file(dev, &dev_attr_green)))
+		err = device_create_file(dev, &dev_attr_green);
+		if (err)
 			goto err_i2c_val;
 	} else {
-		if ((err = device_create_file(dev, &dev_attr_blue)))
+		err = device_create_file(dev, &dev_attr_blue);
+		if (err)
 			goto err_i2c_val;
-		if ((err = device_create_file(dev, &dev_attr_red)))
+		err = device_create_file(dev, &dev_attr_red);
+		if (err)
 			goto err_blue;
@@ -1684,11 +1694,13 @@ static int sn9c102_init(struct sn9c102_device* cam)
 	else
 		DBG(3, "Uncompressed video format is active");
-	if (s->set_crop)
-		if ((err = s->set_crop(cam, rect))) {
+	if (s->set_crop) {
+		err = s->set_crop(cam, rect);
+		if (err) {
 			DBG(3, "set_crop() failed");
 			return err;
 	if (s->set_ctrl) {
 		for (i = 0; i < ARRAY_SIZE(s->qctrl); i++)
@@ -1835,7 +1847,8 @@ static int sn9c102_open(struct file *filp)
 		cam->state &= ~DEV_MISCONFIGURED;
-	if ((err = sn9c102_start_transfer(cam)))
+	err = sn9c102_start_transfer(cam);
+	if (err)
 		goto out;
 	filp->private_data = cam;
@@ -2308,7 +2321,8 @@ sn9c102_vidioc_s_ctrl(struct sn9c102_device* cam, void __user * arg)
 	if (i == ARRAY_SIZE(s->qctrl))
 		return -EINVAL;
-	if ((err = s->set_ctrl(cam, &ctrl)))
+	err = s->set_ctrl(cam, &ctrl);
+	if (err)
 		return err;
 	s->_qctrl[i].default_value = ctrl.value;
@@ -2416,9 +2430,11 @@ sn9c102_vidioc_s_crop(struct sn9c102_device* cam, void __user * arg)
 	} else
 		scale = 1;
-	if (cam->stream == STREAM_ON)
-		if ((err = sn9c102_stream_interrupt(cam)))
+	if (cam->stream == STREAM_ON) {
+		err = sn9c102_stream_interrupt(cam);
+		if (err)
 			return err;
 	if (copy_to_user(arg, &crop, sizeof(crop))) {
 		cam->stream = stream;
@@ -2672,9 +2688,11 @@ sn9c102_vidioc_try_s_fmt(struct sn9c102_device* cam, unsigned int cmd,
 				return -EBUSY;
+		if (err)
 			return err;
 	if (copy_to_user(arg, &format, sizeof(format))) {
@@ -2746,9 +2764,11 @@ sn9c102_vidioc_s_jpegcomp(struct sn9c102_device* cam, void __user * arg)
 	if (jc.quality != 0 && jc.quality != 1)
 		return -EINVAL;
+		if (err)
 			return err;
 	err += sn9c102_set_compression(cam, &jc);
 	if (err) { /* atomic, no rollback in ioctl() */
@@ -2794,9 +2814,11 @@ sn9c102_vidioc_reqbufs(struct sn9c102_device* cam, void __user * arg)
 			return -EBUSY;
+		if (err)
 			return err;
 	sn9c102_empty_framequeues(cam);
@@ -2974,9 +2996,11 @@ sn9c102_vidioc_streamoff(struct sn9c102_device* cam, void __user * arg)
 	if (type != V4L2_BUF_TYPE_VIDEO_CAPTURE || cam->io != IO_MMAP)
 		return -EINVAL;
+		if (err)
 			return err;
diff --git a/drivers/staging/media/sn9c102/sn9c102_hv7131d.c b/drivers/staging/media/sn9c102/sn9c102_hv7131d.c
index 2dce5c9..4680721 100644
--- a/drivers/staging/media/sn9c102/sn9c102_hv7131d.c
+++ b/drivers/staging/media/sn9c102/sn9c102_hv7131d.c
@@ -53,27 +53,32 @@ static int hv7131d_get_ctrl(struct sn9c102_device* cam,
 		return 0;
 	case V4L2_CID_RED_BALANCE:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x31)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x31);
+		if (ctrl->value < 0)
 			return -EIO;
 		ctrl->value = 0x3f - (ctrl->value & 0x3f);
 		return 0;
 	case V4L2_CID_BLUE_BALANCE:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x33)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x33);
 			return -EIO;
 		return 0;
 	case SN9C102_V4L2_CID_GREEN_BALANCE:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x32)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x32);
 			return -EIO;
 		return 0;
 	case SN9C102_V4L2_CID_RESET_LEVEL:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x30)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x30);
 			return -EIO;
 		ctrl->value &= 0x3f;
 		return 0;
 	case SN9C102_V4L2_CID_PIXEL_BIAS_VOLTAGE:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x34)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x34);
 			return -EIO;
 		ctrl->value &= 0x07;
 		return 0;
diff --git a/drivers/staging/media/sn9c102/sn9c102_hv7131r.c b/drivers/staging/media/sn9c102/sn9c102_hv7131r.c
index 4295887..26a9111 100644
--- a/drivers/staging/media/sn9c102/sn9c102_hv7131r.c
+++ b/drivers/staging/media/sn9c102/sn9c102_hv7131r.c
@@ -142,26 +142,31 @@ static int hv7131r_get_ctrl(struct sn9c102_device* cam,
 	switch (ctrl->id) {
 	case V4L2_CID_GAIN:
 			return -EIO;
 		return 0;
 			return -EIO;
 		ctrl->value = ctrl->value & 0x3f;
 		return 0;
 			return -EIO;
 		return 0;
 			return -EIO;
 		return 0;
 	case V4L2_CID_BLACK_LEVEL:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x01)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x01);
 			return -EIO;
 		ctrl->value = (ctrl->value & 0x08) ? 1 : 0;
 		return 0;
diff --git a/drivers/staging/media/sn9c102/sn9c102_ov7630.c b/drivers/staging/media/sn9c102/sn9c102_ov7630.c
index 803712c..d3a1bd8 100644
--- a/drivers/staging/media/sn9c102/sn9c102_ov7630.c
+++ b/drivers/staging/media/sn9c102/sn9c102_ov7630.c
@@ -260,7 +260,8 @@ static int ov7630_get_ctrl(struct sn9c102_device* cam,
 	switch (ctrl->id) {
 	case V4L2_CID_EXPOSURE:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x10)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x10);
 			return -EIO;
 		break;
@@ -280,37 +281,44 @@ static int ov7630_get_ctrl(struct sn9c102_device* cam,
 		break;
 		break;
 	case V4L2_CID_GAIN:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x00)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x00);
 			return -EIO;
 		break;
 	case V4L2_CID_DO_WHITE_BALANCE:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x0c)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x0c);
 			return -EIO;
 		break;
 	case V4L2_CID_WHITENESS:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x0d)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x0d);
 			return -EIO;
 		break;
 	case V4L2_CID_AUTOGAIN:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x13)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x13);
 			return -EIO;
 		ctrl->value &= 0x01;
 		break;
 	case V4L2_CID_VFLIP:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x75)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x75);
 			return -EIO;
 		ctrl->value = (ctrl->value & 0x80) ? 1 : 0;
 		break;
 	case SN9C102_V4L2_CID_GAMMA:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x14)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x14);
 			return -EIO;
 		ctrl->value = (ctrl->value & 0x02) ? 1 : 0;
 		break;
 	case SN9C102_V4L2_CID_BAND_FILTER:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x2d)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x2d);
 			return -EIO;
 		break;
diff --git a/drivers/staging/media/sn9c102/sn9c102_ov7660.c b/drivers/staging/media/sn9c102/sn9c102_ov7660.c
index 7977795..530157a 100644
--- a/drivers/staging/media/sn9c102/sn9c102_ov7660.c
+++ b/drivers/staging/media/sn9c102/sn9c102_ov7660.c
@@ -278,41 +278,49 @@ static int ov7660_get_ctrl(struct sn9c102_device* cam,
 	switch (ctrl->id) {
 			return -EIO;
 		break;
-		if ((ctrl->value = sn9c102_read_reg(cam, 0x02)) < 0)
+		ctrl->value = sn9c102_read_reg(cam, 0x02);
 			return -EIO;
 		ctrl->value = (ctrl->value & 0x04) ? 1 : 0;
 		break;
-		if ((ctrl->value = sn9c102_read_reg(cam, 0x05)) < 0)
+		ctrl->value = sn9c102_read_reg(cam, 0x05);
 			return -EIO;
 		ctrl->value &= 0x7f;
 		break;
-		if ((ctrl->value = sn9c102_read_reg(cam, 0x06)) < 0)
+		ctrl->value = sn9c102_read_reg(cam, 0x06);
 			return -EIO;
 		break;
-		if ((ctrl->value = sn9c102_read_reg(cam, 0x07)) < 0)
+		ctrl->value = sn9c102_read_reg(cam, 0x07);
 			return -EIO;
 		break;
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x3b)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x3b);
 			return -EIO;
 		ctrl->value &= 0x08;
 		break;
 	case V4L2_CID_GAIN:
 			return -EIO;
 		ctrl->value &= 0x1f;
 		break;
 			return -EIO;
 		break;
diff --git a/drivers/staging/media/sn9c102/sn9c102_pas106b.c b/drivers/staging/media/sn9c102/sn9c102_pas106b.c
index 81cd969..47bd82d 100644
--- a/drivers/staging/media/sn9c102/sn9c102_pas106b.c
+++ b/drivers/staging/media/sn9c102/sn9c102_pas106b.c
@@ -62,32 +62,38 @@ static int pas106b_get_ctrl(struct sn9c102_device* cam,
 		return 0;
 			return -EIO;
 		return 0;
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x09)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x09);
 			return -EIO;
 		return 0;
 	case V4L2_CID_GAIN:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x0e)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x0e);
 			return -EIO;
 		return 0;
 	case V4L2_CID_CONTRAST:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x0f)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x0f);
 			return -EIO;
 		return 0;
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x0a)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x0a);
 			return -EIO;
 		ctrl->value = (ctrl->value & 0x1f) << 1;
 		return 0;
 	case SN9C102_V4L2_CID_DAC_MAGNITUDE:
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x08)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x08);
 			return -EIO;
 		ctrl->value &= 0xf8;
 		return 0;
diff --git a/drivers/staging/media/sn9c102/sn9c102_pas202bcb.c b/drivers/staging/media/sn9c102/sn9c102_pas202bcb.c
index 2e86fdc..cbfacc2 100644
--- a/drivers/staging/media/sn9c102/sn9c102_pas202bcb.c
+++ b/drivers/staging/media/sn9c102/sn9c102_pas202bcb.c
@@ -92,27 +92,32 @@ static int pas202bcb_get_ctrl(struct sn9c102_device* cam,
 		return 0;
 			return -EIO;
 		ctrl->value &= 0x0f;
 		return 0;
-		if ((ctrl->value = sn9c102_i2c_read(cam, 0x07)) < 0)
+		ctrl->value = sn9c102_i2c_read(cam, 0x07);
 			return -EIO;
 		return 0;
 	case V4L2_CID_GAIN:
 			return -EIO;
 		return 0;
 			return -EIO;
 		return 0;
 			return -EIO;
 		return 0;
 	default:
