staging/lustre: remove CFS_MODULE_PARM
Author: Peng Tao <bergwolf@gmail.com>
Patch generated by coccinelle:
@generic_type@
declarer name CFS_MODULE_PARM;
declarer name module_param;
declarer name MODULE_PARM_DESC;
expression E1, E2, E3, E4;
type t;
-CFS_MODULE_PARM(E1, E2, t, E3, E4);
+module_param(E1, t, E3);
+MODULE_PARM_DESC(E1, E4);
@charp@
expression E1, E2, E3, E4, E5;
-CFS_MODULE_PARM(E1, E2, E3, E4, E5);
+module_param(E1, E3, E4);
+MODULE_PARM_DESC(E1, E5);
With manual modification to remove CFS_MODULE_PARM definition and
fix up checkpatch.pl warnnings.
Cc: Andreas Dilger
Signed-off-by: Peng Tao
 .../lustre/include/linux/libcfs/linux/kp30.h       |   7 --
 .../lustre/lnet/klnds/o2iblnd/o2iblnd_modparams.c  |  96 +++++++++---------
 .../lustre/lnet/klnds/socklnd/socklnd_modparams.c  | 112 ++++++++++-----------
 drivers/staging/lustre/lnet/lnet/acceptor.c        |  16 +--
 drivers/staging/lustre/lnet/lnet/api-ni.c          |  16 +--
 drivers/staging/lustre/lnet/lnet/lib-move.c        |   4 +-
 drivers/staging/lustre/lnet/lnet/lib-ptl.c         |   4 +-
 drivers/staging/lustre/lnet/lnet/module.c          |   4 +-
 drivers/staging/lustre/lnet/lnet/router.c          |  44 ++++----
 drivers/staging/lustre/lnet/selftest/brw_test.c    |   7 +-
 drivers/staging/lustre/lnet/selftest/framework.c   |   8 +-
 drivers/staging/lustre/lnet/selftest/ping_test.c   |   3 +-
 drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c    |   8 +-
 drivers/staging/lustre/lustre/ldlm/ldlm_request.c  |   4 +-
 drivers/staging/lustre/lustre/libcfs/debug.c       |  42 ++++----
 drivers/staging/lustre/lustre/libcfs/hash.c        |   4 +-
 .../staging/lustre/lustre/libcfs/linux/linux-cpu.c |   6 +-
 drivers/staging/lustre/lustre/llite/lloop.c        |   3 +-
 .../lustre/lustre/obdclass/lprocfs_status.c        |   4 +-
 drivers/staging/lustre/lustre/obdclass/lu_object.c |   4 +-
 drivers/staging/lustre/lustre/ptlrpc/pinger.c      |   3 +-
 drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c     |   8 +-
 drivers/staging/lustre/lustre/ptlrpc/service.c     |  26 ++---
 23 files changed, 216 insertions(+), 217 deletions(-)
diff --git a/drivers/staging/lustre/include/linux/libcfs/linux/kp30.h b/drivers/staging/lustre/include/linux/libcfs/linux/kp30.h
index ba14c31..8cab09c 100644
--- a/drivers/staging/lustre/include/linux/libcfs/linux/kp30.h
+++ b/drivers/staging/lustre/include/linux/libcfs/linux/kp30.h
@@ -70,13 +70,6 @@
 #include <linux/libcfs/linux/portals_compat25.h>
-/* Module parameter support */
-#define CFS_MODULE_PARM(name, t, type, perm, desc) \
-	module_param(name, type, perm);\
-	MODULE_PARM_DESC(name, desc)
 # define LI_POISON 0x5a5a5a5a
diff --git a/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_modparams.c b/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_modparams.c
index cc291d0..cefdfb6 100644
--- a/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_modparams.c
+++ b/drivers/staging/lustre/lnet/klnds/o2iblnd/o2iblnd_modparams.c
@@ -41,95 +41,95 @@
 #include "o2iblnd.h"
 static int service = 987;
-CFS_MODULE_PARM(service, "i", int, 0444,
-		"service number (within RDMA_PS_TCP)");
+module_param(service, int, 0444);
+MODULE_PARM_DESC(service, "service number (within RDMA_PS_TCP)");
 static int cksum = 0;
-CFS_MODULE_PARM(cksum, "i", int, 0644,
-		"set non-zero to enable message (not RDMA) checksums");
+module_param(cksum, int, 0644);
+MODULE_PARM_DESC(cksum, "set non-zero to enable message (not RDMA) checksums");
 static int timeout = 50;
-CFS_MODULE_PARM(timeout, "i", int, 0644,
-		"timeout (seconds)");
+module_param(timeout, int, 0644);
+MODULE_PARM_DESC(timeout, "timeout (seconds)");
 /* Number of threads in each scheduler pool which is percpt,
  * we will estimate reasonable value based on CPUs if it's set to zero. */
 static int nscheds;
-CFS_MODULE_PARM(nscheds, "i", int, 0444,
-		"number of threads in each scheduler pool");
+module_param(nscheds, int, 0444);
+MODULE_PARM_DESC(nscheds, "number of threads in each scheduler pool");
 /* NB: this value is shared by all CPTs, it can grow at runtime */
 static int ntx = 512;
-CFS_MODULE_PARM(ntx, "i", int, 0444,
-		"# of message descriptors allocated for each pool");
+module_param(ntx, int, 0444);
+MODULE_PARM_DESC(ntx, "# of message descriptors allocated for each pool");
 /* NB: this value is shared by all CPTs */
 static int credits = 256;
-CFS_MODULE_PARM(credits, "i", int, 0444,
-		"# concurrent sends");
+module_param(credits, int, 0444);
+MODULE_PARM_DESC(credits, "# concurrent sends");
 static int peer_credits = 8;
-CFS_MODULE_PARM(peer_credits, "i", int, 0444,
-		"# concurrent sends to 1 peer");
+module_param(peer_credits, int, 0444);
+MODULE_PARM_DESC(peer_credits, "# concurrent sends to 1 peer");
 static int peer_credits_hiw = 0;
-CFS_MODULE_PARM(peer_credits_hiw, "i", int, 0444,
-		"when eagerly to return credits");
+module_param(peer_credits_hiw, int, 0444);
+MODULE_PARM_DESC(peer_credits_hiw, "when eagerly to return credits");
 static int peer_buffer_credits = 0;
-CFS_MODULE_PARM(peer_buffer_credits, "i", int, 0444,
-		"# per-peer router buffer credits");
+module_param(peer_buffer_credits, int, 0444);
+MODULE_PARM_DESC(peer_buffer_credits, "# per-peer router buffer credits");
 static int peer_timeout = 180;
-CFS_MODULE_PARM(peer_timeout, "i", int, 0444,
-		"Seconds without aliveness news to declare peer dead (<=0 to disable)");
+module_param(peer_timeout, int, 0444);
+MODULE_PARM_DESC(peer_timeout, "Seconds without aliveness news to declare peer dead (<=0 to disable)");
 static char *ipif_name = "ib0";
-CFS_MODULE_PARM(ipif_name, "s", charp, 0444,
-		"IPoIB interface name");
+module_param(ipif_name, charp, 0444);
+MODULE_PARM_DESC(ipif_name, "IPoIB interface name");
 static int retry_count = 5;
-CFS_MODULE_PARM(retry_count, "i", int, 0644,
-		"Retransmissions when no ACK received");
+module_param(retry_count, int, 0644);
+MODULE_PARM_DESC(retry_count, "Retransmissions when no ACK received");
 static int rnr_retry_count = 6;
-CFS_MODULE_PARM(rnr_retry_count, "i", int, 0644,
-		"RNR retransmissions");
+module_param(rnr_retry_count, int, 0644);
+MODULE_PARM_DESC(rnr_retry_count, "RNR retransmissions");
 static int keepalive = 100;
-CFS_MODULE_PARM(keepalive, "i", int, 0644,
-		"Idle time in seconds before sending a keepalive");
+module_param(keepalive, int, 0644);
+MODULE_PARM_DESC(keepalive, "Idle time in seconds before sending a keepalive");
 static int ib_mtu = 0;
-CFS_MODULE_PARM(ib_mtu, "i", int, 0444,
-		"IB MTU 256/512/1024/2048/4096");
+module_param(ib_mtu, int, 0444);
+MODULE_PARM_DESC(ib_mtu, "IB MTU 256/512/1024/2048/4096");
 static int concurrent_sends = 0;
-CFS_MODULE_PARM(concurrent_sends, "i", int, 0444,
-		"send work-queue sizing");
+module_param(concurrent_sends, int, 0444);
+MODULE_PARM_DESC(concurrent_sends, "send work-queue sizing");
 static int map_on_demand = 0;
-CFS_MODULE_PARM(map_on_demand, "i", int, 0444,
-		"map on demand");
+module_param(map_on_demand, int, 0444);
+MODULE_PARM_DESC(map_on_demand, "map on demand");
 static int fmr_pool_size = 512;
-CFS_MODULE_PARM(fmr_pool_size, "i", int, 0444,
-		"size of fmr pool on each CPT (>= ntx / 4)");
+module_param(fmr_pool_size, int, 0444);
+MODULE_PARM_DESC(fmr_pool_size, "size of fmr pool on each CPT (>= ntx / 4)");
 static int fmr_flush_trigger = 384;
-CFS_MODULE_PARM(fmr_flush_trigger, "i", int, 0444,
-		"# dirty FMRs that triggers pool flush");
+module_param(fmr_flush_trigger, int, 0444);
+MODULE_PARM_DESC(fmr_flush_trigger, "# dirty FMRs that triggers pool flush");
 static int fmr_cache = 1;
-CFS_MODULE_PARM(fmr_cache, "i", int, 0444,
-		"non-zero to enable FMR caching");
+module_param(fmr_cache, int, 0444);
+MODULE_PARM_DESC(fmr_cache, "non-zero to enable FMR caching");
 static int pmr_pool_size = 512;
-CFS_MODULE_PARM(pmr_pool_size, "i", int, 0444,
-		"size of MR cache pmr pool on each CPT");
+module_param(pmr_pool_size, int, 0444);
+MODULE_PARM_DESC(pmr_pool_size, "size of MR cache pmr pool on each CPT");
  * 0: disable failover
@@ -137,17 +137,17 @@ CFS_MODULE_PARM(pmr_pool_size, "i", int, 0444,
  * 2: force to failover (for debug)
 static int dev_failover = 0;
-CFS_MODULE_PARM(dev_failover, "i", int, 0444,
-	       "HCA failover for bonding (0 off, 1 on, other values reserved)");
+module_param(dev_failover, int, 0444);
+MODULE_PARM_DESC(dev_failover, "HCA failover for bonding (0 off, 1 on, other values reserved)");
 static int require_privileged_port = 0;
-CFS_MODULE_PARM(require_privileged_port, "i", int, 0644,
-		"require privileged port when accepting connection");
+module_param(require_privileged_port, int, 0644);
+MODULE_PARM_DESC(require_privileged_port, "require privileged port when accepting connection");
 static int use_privileged_port = 1;
-CFS_MODULE_PARM(use_privileged_port, "i", int, 0644,
-		"use privileged port when initiating connection");
+module_param(use_privileged_port, int, 0644);
+MODULE_PARM_DESC(use_privileged_port, "use privileged port when initiating connection");
 kib_tunables_t kiblnd_tunables = {
 	.kib_dev_failover	   = &dev_failover,
diff --git a/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_modparams.c b/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_modparams.c
index 9f4c64e..54c0019 100644
--- a/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_modparams.c
+++ b/drivers/staging/lustre/lnet/klnds/socklnd/socklnd_modparams.c
@@ -22,123 +22,123 @@
 #include "socklnd.h"
 static int sock_timeout = 50;
-CFS_MODULE_PARM(sock_timeout, "i", int, 0644,
-		"dead socket timeout (seconds)");
+module_param(sock_timeout, int, 0644);
+MODULE_PARM_DESC(sock_timeout, "dead socket timeout (seconds)");
 /* Number of daemons in each thread pool which is percpt,
  * we will estimate reasonable value based on CPUs if it's not set. */
 static unsigned int nscheds;
-		"# scheduler daemons in each pool while starting");
+MODULE_PARM_DESC(nscheds, "# scheduler daemons in each pool while starting");
 static int nconnds = 4;
-CFS_MODULE_PARM(nconnds, "i", int, 0444,
-		"# connection daemons while starting");
+module_param(nconnds, int, 0444);
+MODULE_PARM_DESC(nconnds, "# connection daemons while starting");
 static int nconnds_max = 64;
-CFS_MODULE_PARM(nconnds_max, "i", int, 0444,
-		"max # connection daemons");
+module_param(nconnds_max, int, 0444);
+MODULE_PARM_DESC(nconnds_max, "max # connection daemons");
 static int min_reconnectms = 1000;
-CFS_MODULE_PARM(min_reconnectms, "i", int, 0644,
-		"min connection retry interval (mS)");
+module_param(min_reconnectms, int, 0644);
+MODULE_PARM_DESC(min_reconnectms, "min connection retry interval (mS)");
 static int max_reconnectms = 60000;
-CFS_MODULE_PARM(max_reconnectms, "i", int, 0644,
-		"max connection retry interval (mS)");
+module_param(max_reconnectms, int, 0644);
+MODULE_PARM_DESC(max_reconnectms, "max connection retry interval (mS)");
 # define DEFAULT_EAGER_ACK 0
 static int eager_ack = DEFAULT_EAGER_ACK;
-CFS_MODULE_PARM(eager_ack, "i", int, 0644,
-		"send tcp ack packets eagerly");
+module_param(eager_ack, int, 0644);
+MODULE_PARM_DESC(eager_ack, "send tcp ack packets eagerly");
 static int typed_conns = 1;
-CFS_MODULE_PARM(typed_conns, "i", int, 0444,
-		"use different sockets for bulk");
+module_param(typed_conns, int, 0444);
+MODULE_PARM_DESC(typed_conns, "use different sockets for bulk");
 static int min_bulk = (1<<10);
-CFS_MODULE_PARM(min_bulk, "i", int, 0644,
-		"smallest 'large' message");
+module_param(min_bulk, int, 0644);
+MODULE_PARM_DESC(min_bulk, "smallest 'large' message");
 # define DEFAULT_BUFFER_SIZE 0
 static int tx_buffer_size = DEFAULT_BUFFER_SIZE;
-CFS_MODULE_PARM(tx_buffer_size, "i", int, 0644,
-		"socket tx buffer size (0 for system default)");
+module_param(tx_buffer_size, int, 0644);
+MODULE_PARM_DESC(tx_buffer_size, "socket tx buffer size (0 for system default)");
 static int rx_buffer_size = DEFAULT_BUFFER_SIZE;
-CFS_MODULE_PARM(rx_buffer_size, "i", int, 0644,
-		"socket rx buffer size (0 for system default)");
+module_param(rx_buffer_size, int, 0644);
+MODULE_PARM_DESC(rx_buffer_size, "socket rx buffer size (0 for system default)");
 static int nagle = 0;
-CFS_MODULE_PARM(nagle, "i", int, 0644,
-		"enable NAGLE?");
+module_param(nagle, int, 0644);
+MODULE_PARM_DESC(nagle, "enable NAGLE?");
 static int round_robin = 1;
-CFS_MODULE_PARM(round_robin, "i", int, 0644,
-		"Round robin for multiple interfaces");
+module_param(round_robin, int, 0644);
+MODULE_PARM_DESC(round_robin, "Round robin for multiple interfaces");
 static int keepalive = 30;
-		"# seconds before send keepalive");
+MODULE_PARM_DESC(keepalive, "# seconds before send keepalive");
 static int keepalive_idle = 30;
-CFS_MODULE_PARM(keepalive_idle, "i", int, 0644,
-		"# idle seconds before probe");
+module_param(keepalive_idle, int, 0644);
+MODULE_PARM_DESC(keepalive_idle, "# idle seconds before probe");
 #define DEFAULT_KEEPALIVE_COUNT  5
 static int keepalive_count = DEFAULT_KEEPALIVE_COUNT;
-CFS_MODULE_PARM(keepalive_count, "i", int, 0644,
-		"# missed probes == dead");
+module_param(keepalive_count, int, 0644);
+MODULE_PARM_DESC(keepalive_count, "# missed probes == dead");
 static int keepalive_intvl = 5;
-CFS_MODULE_PARM(keepalive_intvl, "i", int, 0644,
-		"seconds between probes");
+module_param(keepalive_intvl, int, 0644);
+MODULE_PARM_DESC(keepalive_intvl, "seconds between probes");
 static int enable_csum = 0;
-CFS_MODULE_PARM(enable_csum, "i", int, 0644,
-		"enable check sum");
+module_param(enable_csum, int, 0644);
+MODULE_PARM_DESC(enable_csum, "enable check sum");
 static int inject_csum_error = 0;
-CFS_MODULE_PARM(inject_csum_error, "i", int, 0644,
-		"set non-zero to inject a checksum error");
+module_param(inject_csum_error, int, 0644);
+MODULE_PARM_DESC(inject_csum_error, "set non-zero to inject a checksum error");
 static int nonblk_zcack = 1;
-CFS_MODULE_PARM(nonblk_zcack, "i", int, 0644,
-		"always send ZC-ACK on non-blocking connection");
+module_param(nonblk_zcack, int, 0644);
+MODULE_PARM_DESC(nonblk_zcack, "always send ZC-ACK on non-blocking connection");
 static unsigned int zc_min_payload = (16 << 10);
-CFS_MODULE_PARM(zc_min_payload, "i", int, 0644,
-		"minimum payload size to zero copy");
+module_param(zc_min_payload, int, 0644);
+MODULE_PARM_DESC(zc_min_payload, "minimum payload size to zero copy");
 static unsigned int zc_recv = 0;
-CFS_MODULE_PARM(zc_recv, "i", int, 0644,
-		"enable ZC recv for Chelsio driver");
+module_param(zc_recv, int, 0644);
+MODULE_PARM_DESC(zc_recv, "enable ZC recv for Chelsio driver");
 static unsigned int zc_recv_min_nfrags = 16;
-CFS_MODULE_PARM(zc_recv_min_nfrags, "i", int, 0644,
-		"minimum # of fragments to enable ZC recv");
+module_param(zc_recv_min_nfrags, int, 0644);
+MODULE_PARM_DESC(zc_recv_min_nfrags, "minimum # of fragments to enable ZC recv");
 #if SOCKNAL_VERSION_DEBUG
 static int protocol = 3;
-CFS_MODULE_PARM(protocol, "i", int, 0644,
-		"protocol version");
+module_param(protocol, int, 0644);
+MODULE_PARM_DESC(protocol, "protocol version");
 #endif
 ksock_tunables_t ksocknal_tunables;
diff --git a/drivers/staging/lustre/lnet/lnet/acceptor.c b/drivers/staging/lustre/lnet/lnet/acceptor.c
index 92c60a7..cb2ecd7 100644
--- a/drivers/staging/lustre/lnet/lnet/acceptor.c
+++ b/drivers/staging/lustre/lnet/lnet/acceptor.c
@@ -64,14 +64,14 @@ lnet_accept_magic(__u32 magic, __u32 constant)
 static char *accept = "secure";
-CFS_MODULE_PARM(accept, "s", charp, 0444,
-		"Accept connections (secure|all|none)");
-CFS_MODULE_PARM(accept_port, "i", int, 0444,
-		"Acceptor's port (same on all nodes)");
-CFS_MODULE_PARM(accept_backlog, "i", int, 0444,
-		"Acceptor's listen backlog");
-CFS_MODULE_PARM(accept_timeout, "i", int, 0644,
-		"Acceptor's timeout (seconds)");
+module_param(accept, charp, 0444);
+MODULE_PARM_DESC(accept, "Accept connections (secure|all|none)");
+module_param(accept_port, int, 0444);
+MODULE_PARM_DESC(accept_port, "Acceptor's port (same on all nodes)");
+module_param(accept_backlog, int, 0444);
+MODULE_PARM_DESC(accept_backlog, "Acceptor's listen backlog");
+module_param(accept_timeout, int, 0644);
+MODULE_PARM_DESC(accept_timeout, "Acceptor's timeout (seconds)");
 static char *accept_type;
diff --git a/drivers/staging/lustre/lnet/lnet/api-ni.c b/drivers/staging/lustre/lnet/lnet/api-ni.c
index 160a429..5719959 100644
--- a/drivers/staging/lustre/lnet/lnet/api-ni.c
+++ b/drivers/staging/lustre/lnet/lnet/api-ni.c
@@ -45,20 +45,20 @@ EXPORT_SYMBOL(the_lnet);
 static char *ip2nets = "";
-CFS_MODULE_PARM(ip2nets, "s", charp, 0444,
-		"LNET network <- IP table");
+module_param(ip2nets, charp, 0444);
+MODULE_PARM_DESC(ip2nets, "LNET network <- IP table");
 static char *networks = "";
-CFS_MODULE_PARM(networks, "s", charp, 0444,
-		"local networks");
+module_param(networks, charp, 0444);
+MODULE_PARM_DESC(networks, "local networks");
 static char *routes = "";
-CFS_MODULE_PARM(routes, "s", charp, 0444,
-		"routes to non-local networks");
+module_param(routes, charp, 0444);
+MODULE_PARM_DESC(routes, "routes to non-local networks");
 static int rnet_htable_size = LNET_REMOTE_NETS_HASH_DEFAULT;
-CFS_MODULE_PARM(rnet_htable_size, "i", int, 0444,
-		"size of remote network hash table");
+module_param(rnet_htable_size, int, 0444);
+MODULE_PARM_DESC(rnet_htable_size, "size of remote network hash table");
 char *
 lnet_get_routes(void)
diff --git a/drivers/staging/lustre/lnet/lnet/lib-move.c b/drivers/staging/lustre/lnet/lnet/lib-move.c
index b6f8ad3..2d61113 100644
--- a/drivers/staging/lustre/lnet/lnet/lib-move.c
+++ b/drivers/staging/lustre/lnet/lnet/lib-move.c
@@ -43,8 +43,8 @@
 #include <linux/lnet/lib-lnet.h>
 static int local_nid_dist_zero = 1;
-CFS_MODULE_PARM(local_nid_dist_zero, "i", int, 0444,
-		"Reserved");
+module_param(local_nid_dist_zero, int, 0444);
+MODULE_PARM_DESC(local_nid_dist_zero, "Reserved");
 int
 lnet_fail_nid(lnet_nid_t nid, unsigned int threshold)
diff --git a/drivers/staging/lustre/lnet/lnet/lib-ptl.c b/drivers/staging/lustre/lnet/lnet/lib-ptl.c
index 9b9e7d3..6fffd5e 100644
--- a/drivers/staging/lustre/lnet/lnet/lib-ptl.c
+++ b/drivers/staging/lustre/lnet/lnet/lib-ptl.c
@@ -40,8 +40,8 @@
 /* NB: add /proc interfaces in upcoming patches */
 int	portal_rotor	= LNET_PTL_ROTOR_HASH_RT;
-CFS_MODULE_PARM(portal_rotor, "i", int, 0644,
-		"redirect PUTs to different cpu-partitions");
+module_param(portal_rotor, int, 0644);
+MODULE_PARM_DESC(portal_rotor, "redirect PUTs to different cpu-partitions");
 static int
 lnet_ptl_match_type(unsigned int index, lnet_process_id_t match_id,
diff --git a/drivers/staging/lustre/lnet/lnet/module.c b/drivers/staging/lustre/lnet/lnet/module.c
index 6db8774..3bd42a4 100644
--- a/drivers/staging/lustre/lnet/lnet/module.c
+++ b/drivers/staging/lustre/lnet/lnet/module.c
@@ -38,8 +38,8 @@
 static int config_on_load;
-CFS_MODULE_PARM(config_on_load, "i", int, 0444,
-		"configure network at module load");
+module_param(config_on_load, int, 0444);
+MODULE_PARM_DESC(config_on_load, "configure network at module load");
 static struct mutex lnet_config_mutex;
diff --git a/drivers/staging/lustre/lnet/lnet/router.c b/drivers/staging/lustre/lnet/lnet/router.c
index a326ce0..80b5ed1 100644
--- a/drivers/staging/lustre/lnet/lnet/router.c
+++ b/drivers/staging/lustre/lnet/lnet/router.c
@@ -34,25 +34,25 @@
 #define LNET_NRB_LARGE		(LNET_NRB_LARGE_MIN * 4)
 static char *forwarding = "";
-CFS_MODULE_PARM(forwarding, "s", charp, 0444,
-		"Explicitly enable/disable forwarding between networks");
+module_param(forwarding, charp, 0444);
+MODULE_PARM_DESC(forwarding, "Explicitly enable/disable forwarding between networks");
 static int tiny_router_buffers;
-CFS_MODULE_PARM(tiny_router_buffers, "i", int, 0444,
-		"# of 0 payload messages to buffer in the router");
+module_param(tiny_router_buffers, int, 0444);
+MODULE_PARM_DESC(tiny_router_buffers, "# of 0 payload messages to buffer in the router");
 static int small_router_buffers;
-CFS_MODULE_PARM(small_router_buffers, "i", int, 0444,
-		"# of small (1 page) messages to buffer in the router");
+module_param(small_router_buffers, int, 0444);
+MODULE_PARM_DESC(small_router_buffers, "# of small (1 page) messages to buffer in the router");
 static int large_router_buffers;
-CFS_MODULE_PARM(large_router_buffers, "i", int, 0444,
-		"# of large messages to buffer in the router");
+module_param(large_router_buffers, int, 0444);
+MODULE_PARM_DESC(large_router_buffers, "# of large messages to buffer in the router");
-		"# router buffer credits per peer");
+MODULE_PARM_DESC(peer_buffer_credits, "# router buffer credits per peer");
 static int auto_down = 1;
-CFS_MODULE_PARM(auto_down, "i", int, 0444,
-		"Automatically mark peers down on comms error");
+module_param(auto_down, int, 0444);
+MODULE_PARM_DESC(auto_down, "Automatically mark peers down on comms error");
 int
 lnet_peer_buffer_credits(lnet_ni_t *ni)
@@ -81,24 +81,24 @@ lnet_peer_buffer_credits(lnet_ni_t *ni)
 #endif
 static int check_routers_before_use = 0;
-CFS_MODULE_PARM(check_routers_before_use, "i", int, 0444,
-		"Assume routers are down and ping them before use");
+module_param(check_routers_before_use, int, 0444);
+MODULE_PARM_DESC(check_routers_before_use, "Assume routers are down and ping them before use");
 static int avoid_asym_router_failure = 1;
-CFS_MODULE_PARM(avoid_asym_router_failure, "i", int, 0644,
-		"Avoid asymmetrical router failures (0 to disable)");
+module_param(avoid_asym_router_failure, int, 0644);
+MODULE_PARM_DESC(avoid_asym_router_failure, "Avoid asymmetrical router failures (0 to disable)");
 static int dead_router_check_interval = 60;
-CFS_MODULE_PARM(dead_router_check_interval, "i", int, 0644,
-		"Seconds between dead router health checks (<= 0 to disable)");
+module_param(dead_router_check_interval, int, 0644);
+MODULE_PARM_DESC(dead_router_check_interval, "Seconds between dead router health checks (<= 0 to disable)");
 static int live_router_check_interval = 60;
-CFS_MODULE_PARM(live_router_check_interval, "i", int, 0644,
-		"Seconds between live router health checks (<= 0 to disable)");
+module_param(live_router_check_interval, int, 0644);
+MODULE_PARM_DESC(live_router_check_interval, "Seconds between live router health checks (<= 0 to disable)");
 static int router_ping_timeout = 50;
-CFS_MODULE_PARM(router_ping_timeout, "i", int, 0644,
-		"Seconds to wait for the reply to a router health query");
+module_param(router_ping_timeout, int, 0644);
+MODULE_PARM_DESC(router_ping_timeout, "Seconds to wait for the reply to a router health query");
 int
 lnet_peers_start_down(void)
diff --git a/drivers/staging/lustre/lnet/selftest/brw_test.c b/drivers/staging/lustre/lnet/selftest/brw_test.c
index b7613c8..3f8020c 100644
--- a/drivers/staging/lustre/lnet/selftest/brw_test.c
+++ b/drivers/staging/lustre/lnet/selftest/brw_test.c
@@ -41,11 +41,12 @@
 #include "selftest.h"
 static int brw_srv_workitems = SFW_TEST_WI_MAX;
-CFS_MODULE_PARM(brw_srv_workitems, "i", int, 0644, "# BRW server workitems");
+module_param(brw_srv_workitems, int, 0644);
+MODULE_PARM_DESC(brw_srv_workitems, "# BRW server workitems");
 static int brw_inject_errors;
-CFS_MODULE_PARM(brw_inject_errors, "i", int, 0644,
-		"# data errors to inject randomly, zero by default");
+module_param(brw_inject_errors, int, 0644);
+MODULE_PARM_DESC(brw_inject_errors, "# data errors to inject randomly, zero by default");
 static void
 brw_client_fini(sfw_test_instance_t *tsi)
diff --git a/drivers/staging/lustre/lnet/selftest/framework.c b/drivers/staging/lustre/lnet/selftest/framework.c
index 483c785..050723a 100644
--- a/drivers/staging/lustre/lnet/selftest/framework.c
+++ b/drivers/staging/lustre/lnet/selftest/framework.c
@@ -46,12 +46,12 @@
 lst_sid_t LST_INVALID_SID = {LNET_NID_ANY, -1};
 static int session_timeout = 100;
-CFS_MODULE_PARM(session_timeout, "i", int, 0444,
-		"test session timeout in seconds (100 by default, 0 == never)");
+module_param(session_timeout, int, 0444);
+MODULE_PARM_DESC(session_timeout, "test session timeout in seconds (100 by default, 0 == never)");
 static int rpc_timeout = 64;
-CFS_MODULE_PARM(rpc_timeout, "i", int, 0644,
-		"rpc timeout in seconds (64 by default, 0 == never)");
+module_param(rpc_timeout, int, 0644);
+MODULE_PARM_DESC(rpc_timeout, "rpc timeout in seconds (64 by default, 0 == never)");
 #define sfw_unpack_id(id)	       \
 do {				    \
diff --git a/drivers/staging/lustre/lnet/selftest/ping_test.c b/drivers/staging/lustre/lnet/selftest/ping_test.c
index f0f9194..a37c3ff 100644
--- a/drivers/staging/lustre/lnet/selftest/ping_test.c
+++ b/drivers/staging/lustre/lnet/selftest/ping_test.c
@@ -45,7 +45,8 @@
 #define LST_PING_TEST_MAGIC     0xbabeface
 int ping_srv_workitems = SFW_TEST_WI_MAX;
-CFS_MODULE_PARM(ping_srv_workitems, "i", int, 0644, "# PING server workitems");
+module_param(ping_srv_workitems, int, 0644);
+MODULE_PARM_DESC(ping_srv_workitems, "# PING server workitems");
 typedef struct {
 	spinlock_t	pnd_lock;	/* serialize */
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c b/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c
index 40c58b7..bbf4291 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_lockd.c
@@ -49,12 +49,12 @@
 #include "ldlm_internal.h"
 static int ldlm_num_threads;
-CFS_MODULE_PARM(ldlm_num_threads, "i", int, 0444,
-		"number of DLM service threads to start");
+module_param(ldlm_num_threads, int, 0444);
+MODULE_PARM_DESC(ldlm_num_threads, "number of DLM service threads to start");
 static char *ldlm_cpts;
-CFS_MODULE_PARM(ldlm_cpts, "s", charp, 0444,
-		"CPU partitions ldlm threads should run on");
+module_param(ldlm_cpts, charp, 0444);
+MODULE_PARM_DESC(ldlm_cpts, "CPU partitions ldlm threads should run on");
 extern struct kmem_cache *ldlm_resource_slab;
 extern struct kmem_cache *ldlm_lock_slab;
diff --git a/drivers/staging/lustre/lustre/ldlm/ldlm_request.c b/drivers/staging/lustre/lustre/ldlm/ldlm_request.c
index 1ddcca3..4974bec 100644
--- a/drivers/staging/lustre/lustre/ldlm/ldlm_request.c
+++ b/drivers/staging/lustre/lustre/ldlm/ldlm_request.c
@@ -68,8 +68,8 @@
 int ldlm_enqueue_min = OBD_TIMEOUT_DEFAULT;
-CFS_MODULE_PARM(ldlm_enqueue_min, "i", int, 0644,
-		"lock enqueue timeout minimum");
+module_param(ldlm_enqueue_min, int, 0644);
+MODULE_PARM_DESC(ldlm_enqueue_min, "lock enqueue timeout minimum");
 /* in client side, whether the cached locks will be canceled before replay */
 unsigned int ldlm_cancel_unused_locks_before_replay = 1;
diff --git a/drivers/staging/lustre/lustre/libcfs/debug.c b/drivers/staging/lustre/lustre/libcfs/debug.c
index 9b9c451..f30c84f 100644
--- a/drivers/staging/lustre/lustre/libcfs/debug.c
+++ b/drivers/staging/lustre/lustre/libcfs/debug.c
@@ -47,44 +47,44 @@
 static char debug_file_name[1024];
 unsigned int libcfs_subsystem_debug = ~0;
-CFS_MODULE_PARM(libcfs_subsystem_debug, "i", int, 0644,
-		"Lustre kernel debug subsystem mask");
+module_param(libcfs_subsystem_debug, int, 0644);
+MODULE_PARM_DESC(libcfs_subsystem_debug, "Lustre kernel debug subsystem mask");
 EXPORT_SYMBOL(libcfs_subsystem_debug);
 unsigned int libcfs_debug = (D_CANTMASK |
 			     D_NETERROR | D_HA | D_CONFIG | D_IOCTL);
-CFS_MODULE_PARM(libcfs_debug, "i", int, 0644,
-		"Lustre kernel debug mask");
+module_param(libcfs_debug, int, 0644);
+MODULE_PARM_DESC(libcfs_debug, "Lustre kernel debug mask");
 EXPORT_SYMBOL(libcfs_debug);
 unsigned int libcfs_debug_mb = 0;
-CFS_MODULE_PARM(libcfs_debug_mb, "i", uint, 0644,
-		"Total debug buffer size.");
+module_param(libcfs_debug_mb, uint, 0644);
+MODULE_PARM_DESC(libcfs_debug_mb, "Total debug buffer size.");
 EXPORT_SYMBOL(libcfs_debug_mb);
 unsigned int libcfs_printk = D_CANTMASK;
-CFS_MODULE_PARM(libcfs_printk, "i", uint, 0644,
-		"Lustre kernel debug console mask");
+module_param(libcfs_printk, uint, 0644);
+MODULE_PARM_DESC(libcfs_printk, "Lustre kernel debug console mask");
 EXPORT_SYMBOL(libcfs_printk);
 unsigned int libcfs_console_ratelimit = 1;
-CFS_MODULE_PARM(libcfs_console_ratelimit, "i", uint, 0644,
-		"Lustre kernel debug console ratelimit (0 to disable)");
+module_param(libcfs_console_ratelimit, uint, 0644);
+MODULE_PARM_DESC(libcfs_console_ratelimit, "Lustre kernel debug console ratelimit (0 to disable)");
 EXPORT_SYMBOL(libcfs_console_ratelimit);
 unsigned int libcfs_console_max_delay;
-CFS_MODULE_PARM(libcfs_console_max_delay, "l", uint, 0644,
-		"Lustre kernel debug console max delay (jiffies)");
+module_param(libcfs_console_max_delay, uint, 0644);
+MODULE_PARM_DESC(libcfs_console_max_delay, "Lustre kernel debug console max delay (jiffies)");
 EXPORT_SYMBOL(libcfs_console_max_delay);
 unsigned int libcfs_console_min_delay;
-CFS_MODULE_PARM(libcfs_console_min_delay, "l", uint, 0644,
-		"Lustre kernel debug console min delay (jiffies)");
+module_param(libcfs_console_min_delay, uint, 0644);
+MODULE_PARM_DESC(libcfs_console_min_delay, "Lustre kernel debug console min delay (jiffies)");
 EXPORT_SYMBOL(libcfs_console_min_delay);
 unsigned int libcfs_console_backoff = CDEBUG_DEFAULT_BACKOFF;
-CFS_MODULE_PARM(libcfs_console_backoff, "i", uint, 0644,
-		"Lustre kernel debug console backoff factor");
+module_param(libcfs_console_backoff, uint, 0644);
+MODULE_PARM_DESC(libcfs_console_backoff, "Lustre kernel debug console backoff factor");
 EXPORT_SYMBOL(libcfs_console_backoff);
 unsigned int libcfs_debug_binary = 1;
@@ -103,8 +103,8 @@ unsigned int libcfs_watchdog_ratelimit = 300;
 EXPORT_SYMBOL(libcfs_watchdog_ratelimit);
 unsigned int libcfs_panic_on_lbug = 1;
-CFS_MODULE_PARM(libcfs_panic_on_lbug, "i", uint, 0644,
-		"Lustre kernel panic on LBUG");
+module_param(libcfs_panic_on_lbug, uint, 0644);
+MODULE_PARM_DESC(libcfs_panic_on_lbug, "Lustre kernel panic on LBUG");
 EXPORT_SYMBOL(libcfs_panic_on_lbug);
 atomic_t libcfs_kmemory = ATOMIC_INIT(0);
@@ -116,9 +116,9 @@ char libcfs_debug_file_path_arr[PATH_MAX] = LIBCFS_DEBUG_FILE_PATH_DEFAULT;
 /* We need to pass a pointer here, but elsewhere this must be a const */
 char *libcfs_debug_file_path;
-CFS_MODULE_PARM(libcfs_debug_file_path, "s", charp, 0644,
-		"Path for dumping debug logs, "
-		"set 'NONE' to prevent log dumping");
+module_param(libcfs_debug_file_path, charp, 0644);
+MODULE_PARM_DESC(libcfs_debug_file_path,
+		 "Path for dumping debug logs, set 'NONE' to prevent log dumping");
 int libcfs_panic_in_progress;
diff --git a/drivers/staging/lustre/lustre/libcfs/hash.c b/drivers/staging/lustre/lustre/libcfs/hash.c
index e3e0578..85cbe91 100644
--- a/drivers/staging/lustre/lustre/libcfs/hash.c
+++ b/drivers/staging/lustre/lustre/libcfs/hash.c
@@ -112,8 +112,8 @@
 #if CFS_HASH_DEBUG_LEVEL >= CFS_HASH_DEBUG_1
 static unsigned int warn_on_depth = 8;
-CFS_MODULE_PARM(warn_on_depth, "i", uint, 0644,
-		"warning when hash depth is high.");
+module_param(warn_on_depth, uint, 0644);
+MODULE_PARM_DESC(warn_on_depth, "warning when hash depth is high.");
 #endif
 struct cfs_wi_sched *cfs_sched_rehash;
diff --git a/drivers/staging/lustre/lustre/libcfs/linux/linux-cpu.c b/drivers/staging/lustre/lustre/libcfs/linux/linux-cpu.c
index 00ab8fd..58bb256 100644
--- a/drivers/staging/lustre/lustre/libcfs/linux/linux-cpu.c
+++ b/drivers/staging/lustre/lustre/libcfs/linux/linux-cpu.c
@@ -47,7 +47,8 @@
  * >1 : specify number of partitions
 static int	cpu_npartitions;
-CFS_MODULE_PARM(cpu_npartitions, "i", int, 0444, "# of CPU partitions");
+module_param(cpu_npartitions, int, 0444);
+MODULE_PARM_DESC(cpu_npartitions, "# of CPU partitions");
  * modparam for setting CPU partitions patterns:
@@ -61,7 +62,8 @@ CFS_MODULE_PARM(cpu_npartitions, "i", int, 0444, "# of CPU partitions");
  * NB: If user specified cpu_pattern, cpu_npartitions will be ignored
 static char	*cpu_pattern = "";
-CFS_MODULE_PARM(cpu_pattern, "s", charp, 0444, "CPU partitions pattern");
+module_param(cpu_pattern, charp, 0444);
+MODULE_PARM_DESC(cpu_pattern, "CPU partitions pattern");
 struct cfs_cpt_data {
 	/* serialize hotplug etc */
diff --git a/drivers/staging/lustre/lustre/llite/lloop.c b/drivers/staging/lustre/lustre/llite/lloop.c
index e2421ea..5338e8d 100644
--- a/drivers/staging/lustre/lustre/llite/lloop.c
+++ b/drivers/staging/lustre/lustre/llite/lloop.c
@@ -856,7 +856,8 @@ static void lloop_exit(void)
 module_init(lloop_init);
 module_exit(lloop_exit);
-CFS_MODULE_PARM(max_loop, "i", int, 0444, "maximum of lloop_device");
+module_param(max_loop, int, 0444);
+MODULE_PARM_DESC(max_loop, "maximum of lloop_device");
 MODULE_AUTHOR("Sun Microsystems, Inc. <http://www.lustre.org/>");
 MODULE_DESCRIPTION("Lustre virtual block device");
 MODULE_LICENSE("GPL");
diff --git a/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c b/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
index 02d76f8..0f0750b 100644
--- a/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
+++ b/drivers/staging/lustre/lustre/obdclass/lprocfs_status.c
@@ -49,8 +49,8 @@
 #if defined(LPROCFS)
 static int lprocfs_no_percpu_stats = 0;
-CFS_MODULE_PARM(lprocfs_no_percpu_stats, "i", int, 0644,
-		"Do not alloc percpu data for lprocfs stats");
+module_param(lprocfs_no_percpu_stats, int, 0644);
+MODULE_PARM_DESC(lprocfs_no_percpu_stats, "Do not alloc percpu data for lprocfs stats");
 #define MAX_STRING_SIZE 128
diff --git a/drivers/staging/lustre/lustre/obdclass/lu_object.c b/drivers/staging/lustre/lustre/obdclass/lu_object.c
index 212823a..d61b0db 100644
--- a/drivers/staging/lustre/lustre/obdclass/lu_object.c
+++ b/drivers/staging/lustre/lustre/obdclass/lu_object.c
@@ -830,8 +830,8 @@ enum {
 static unsigned int lu_cache_percent = LU_CACHE_PERCENT_DEFAULT;
-CFS_MODULE_PARM(lu_cache_percent, "i", int, 0644,
-		"Percentage of memory to be used as lu_object cache");
+module_param(lu_cache_percent, int, 0644);
+MODULE_PARM_DESC(lu_cache_percent, "Percentage of memory to be used as lu_object cache");
  * Return desired hash table order.
diff --git a/drivers/staging/lustre/lustre/ptlrpc/pinger.c b/drivers/staging/lustre/lustre/ptlrpc/pinger.c
index a084eb1..1707e61 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/pinger.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/pinger.c
@@ -45,7 +45,8 @@
 #include "ptlrpc_internal.h"
 static int suppress_pings;
-CFS_MODULE_PARM(suppress_pings, "i", int, 0644, "Suppress pings");
+module_param(suppress_pings, int, 0644);
+MODULE_PARM_DESC(suppress_pings, "Suppress pings");
 struct mutex pinger_mutex;
 static LIST_HEAD(pinger_imports);
diff --git a/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c b/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c
index 89c9be9..2ebdb1b 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/ptlrpcd.c
@@ -77,12 +77,12 @@ struct ptlrpcd {
 static int max_ptlrpcds;
-CFS_MODULE_PARM(max_ptlrpcds, "i", int, 0644,
-		"Max ptlrpcd thread count to be started.");
+module_param(max_ptlrpcds, int, 0644);
+MODULE_PARM_DESC(max_ptlrpcds, "Max ptlrpcd thread count to be started.");
 static int ptlrpcd_bind_policy = PDB_POLICY_PAIR;
-CFS_MODULE_PARM(ptlrpcd_bind_policy, "i", int, 0644,
-		"Ptlrpcd threads binding mode.");
+module_param(ptlrpcd_bind_policy, int, 0644);
+MODULE_PARM_DESC(ptlrpcd_bind_policy, "Ptlrpcd threads binding mode.");
 static struct ptlrpcd *ptlrpcds;
 struct mutex ptlrpcd_mutex;
diff --git a/drivers/staging/lustre/lustre/ptlrpc/service.c b/drivers/staging/lustre/lustre/ptlrpc/service.c
index 2b10d6d..590fa8d 100644
--- a/drivers/staging/lustre/lustre/ptlrpc/service.c
+++ b/drivers/staging/lustre/lustre/ptlrpc/service.c
@@ -44,19 +44,19 @@
 /* The following are visible and mutable through /sys/module/ptlrpc */
 int test_req_buffer_pressure = 0;
-CFS_MODULE_PARM(test_req_buffer_pressure, "i", int, 0444,
-		"set non-zero to put pressure on request buffer pools");
-CFS_MODULE_PARM(at_min, "i", int, 0644,
-		"Adaptive timeout minimum (sec)");
-CFS_MODULE_PARM(at_max, "i", int, 0644,
-		"Adaptive timeout maximum (sec)");
-CFS_MODULE_PARM(at_history, "i", int, 0644,
-		"Adaptive timeouts remember the slowest event that took place "
-		"within this period (sec)");
-CFS_MODULE_PARM(at_early_margin, "i", int, 0644,
-		"How soon before an RPC deadline to send an early reply");
-CFS_MODULE_PARM(at_extra, "i", int, 0644,
-		"How much extra time to give with each early reply");
+module_param(test_req_buffer_pressure, int, 0444);
+MODULE_PARM_DESC(test_req_buffer_pressure, "set non-zero to put pressure on request buffer pools");
+module_param(at_min, int, 0644);
+MODULE_PARM_DESC(at_min, "Adaptive timeout minimum (sec)");
+module_param(at_max, int, 0644);
+MODULE_PARM_DESC(at_max, "Adaptive timeout maximum (sec)");
+module_param(at_history, int, 0644);
+MODULE_PARM_DESC(at_history,
+		 "Adaptive timeouts remember the slowest event that took place within this period (sec)");
+module_param(at_early_margin, int, 0644);
+MODULE_PARM_DESC(at_early_margin, "How soon before an RPC deadline to send an early reply");
+module_param(at_extra, int, 0644);
+MODULE_PARM_DESC(at_extra, "How much extra time to give with each early reply");
 /* forward ref */
BtrLinux
Privacy Overview
