drivers/staging/keucr/common.h | 8 --
drivers/staging/keucr/init.c | 16 ++--
drivers/staging/keucr/init.h | 6 +-
drivers/staging/keucr/smil.h | 112 ++++++++++++-------------
drivers/staging/keucr/smilecc.c | 58 ++++++-------
drivers/staging/keucr/smilmain.c | 82 +++++++++---------
drivers/staging/keucr/smilsub.c | 170 +++++++++++++++++++-------------------
drivers/staging/keucr/smscsi.c | 28 +++----
drivers/staging/keucr/transport.c | 8 +-
drivers/staging/keucr/transport.h | 6 +-
drivers/staging/keucr/usb.c | 6 +-
drivers/staging/keucr/usb.h | 86 +++++++++----------
12 files changed, 289 insertions(+), 297 deletions(-)
diff --git a/drivers/staging/keucr/common.h b/drivers/staging/keucr/common.h
index cf347cc..f0b9776 100644
--- a/drivers/staging/keucr/common.h
+++ b/drivers/staging/keucr/common.h
@@ -1,14 +1,6 @@
#ifndef COMMON_INCD
#define COMMON_INCD
-typedef u8 BOOLEAN;
-typedef u8 BYTE;
-typedef u8 *PBYTE;
-typedef u16 WORD;
-typedef u16 *PWORD;
-typedef u32 DWORD;
-typedef u32 *PDWORD;
#define BYTE_MASK 0xff
#endif
diff --git a/drivers/staging/keucr/init.c b/drivers/staging/keucr/init.c
index f5d41e0..e611839 100644
--- a/drivers/staging/keucr/init.c
+++ b/drivers/staging/keucr/init.c
@@ -17,7 +17,7 @@
int ENE_InitMedia(struct us_data *us)
int result;
- BYTE MiscReg03 = 0;
+ u8 MiscReg03 = 0;
dev_info(&us->pusb_dev->dev, "--- Init Media ---\n");
result = ene_read_byte(us, REG_CARD_STATUS, &MiscReg03);
@@ -41,7 +41,7 @@ int ENE_InitMedia(struct us_data *us)
* ene_read_byte() :
-int ene_read_byte(struct us_data *us, WORD index, void *buf)
+int ene_read_byte(struct us_data *us, u16 index, void *buf)
struct bulk_cb_wrap *bcb = (struct bulk_cb_wrap *) us->iobuf;
int result;
@@ -51,8 +51,8 @@ int ene_read_byte(struct us_data *us, WORD index, void *buf)
bcb->DataTransferLength = 0x01;
bcb->Flags = 0x80;
bcb->CDB[0] = 0xED;
- bcb->CDB[2] = (BYTE)(index>>8);
- bcb->CDB[3] = (BYTE)index;
+ bcb->CDB[2] = (u8)(index>>8);
+ bcb->CDB[3] = (u8)index;
result = ENE_SendScsiCmd(us, FDIR_READ, buf, 0);
return result;
@@ -65,7 +65,7 @@ int ENE_SMInit(struct us_data *us)
int result;
- BYTE buf[0x200];
+ u8 buf[0x200];
dev_dbg(&us->pusb_dev->dev, "transport --- ENE_SMInit\n");
@@ -122,12 +122,12 @@ int ENE_SMInit(struct us_data *us)
* ENE_LoadBinCode()
-int ENE_LoadBinCode(struct us_data *us, BYTE flag)
+int ENE_LoadBinCode(struct us_data *us, u8 flag)
int result;
/* void *buf; */
- PBYTE buf;
+ u8 *buf;
/* dev_info(&us->pusb_dev->dev, "transport --- ENE_LoadBinCode\n"); */
if (us->BIN_FLAG == flag)
@@ -164,7 +164,7 @@ int ENE_LoadBinCode(struct us_data *us, BYTE flag)
* ENE_SendScsiCmd():
-int ENE_SendScsiCmd(struct us_data *us, BYTE fDir, void *buf, int use_sg)
+int ENE_SendScsiCmd(struct us_data *us, u8 fDir, void *buf, int use_sg)
struct bulk_cs_wrap *bcs = (struct bulk_cs_wrap *) us->iobuf;
diff --git a/drivers/staging/keucr/init.h b/drivers/staging/keucr/init.h
index c8b2cd6..98d2e3b 100644
--- a/drivers/staging/keucr/init.h
+++ b/drivers/staging/keucr/init.h
@@ -1,11 +1,11 @@
#include "common.h"
-extern DWORD MediaChange;
+extern u32 MediaChange;
extern int Check_D_MediaFmt(struct us_data *);
-static BYTE SM_Init[] = {
+static u8 SM_Init[] = {
0x7B, 0x09, 0x7C, 0xF0, 0x7D, 0x10, 0x7E, 0xE9,
0x7F, 0xCC, 0x12, 0x2F, 0x71, 0x90, 0xE9, 0xCC,
0xE0, 0xB4, 0x07, 0x12, 0x90, 0xFF, 0x09, 0xE0,
@@ -263,7 +263,7 @@ static BYTE SM_Init[] = {
0x58, 0x44, 0x2D, 0x49, 0x6E, 0x69, 0x74, 0x20,
0x20, 0x20, 0x20, 0x31, 0x30, 0x30, 0x30, 0x31 };
-static BYTE SM_Rdwr[] = {
+static u8 SM_Rdwr[] = {
0x7B, 0x0C, 0x7C, 0xF0, 0x7D, 0x10, 0x7E, 0xE9,
0x7F, 0xCC, 0x12, 0x2F, 0x71, 0x90, 0xE9, 0xC3,
0xE0, 0xB4, 0x73, 0x04, 0x74, 0x40, 0x80, 0x09,
diff --git a/drivers/staging/keucr/smil.h b/drivers/staging/keucr/smil.h
index 9136e94..3995173 100644
--- a/drivers/staging/keucr/smil.h
+++ b/drivers/staging/keucr/smil.h
@@ -169,29 +169,29 @@ SmartMedia Model & Attribute
Struct Definition
struct keucr_media_info {
- BYTE Model;
- BYTE Attribute;
- BYTE MaxZones;
- BYTE MaxSectors;
- WORD MaxBlocks;
- WORD MaxLogBlocks;
+ u8 Model;
+ u8 Attribute;
+ u8 MaxZones;
+ u8 MaxSectors;
+ u16 MaxBlocks;
+ u16 MaxLogBlocks;
struct keucr_media_address {
- BYTE Zone; /* Zone Number */
- BYTE Sector; /* Sector(512byte) Number on Block */
- WORD PhyBlock; /* Physical Block Number on Zone */
- WORD LogBlock; /* Logical Block Number of Zone */
+ u8 Zone; /* Zone Number */
+ u8 Sector; /* Sector(512byte) Number on Block */
+ u16 PhyBlock; /* Physical Block Number on Zone */
+ u16 LogBlock; /* Logical Block Number of Zone */
struct keucr_media_area {
- WORD PhyBlock; /* Physical Block Number on Zone 0 */
+ u16 PhyBlock; /* Physical Block Number on Zone 0 */
-extern WORD ReadBlock;
-extern WORD WriteBlock;
+extern u16 ReadBlock;
+extern u16 WriteBlock;
extern struct keucr_media_info Ssfdc;
extern struct keucr_media_address Media;
@@ -204,24 +204,24 @@ extern struct keucr_media_area CisArea;
int Init_D_SmartMedia(void);
int Pwoff_D_SmartMedia(void);
int Check_D_SmartMedia(void);
-int Check_D_Parameter(struct us_data *, WORD *, BYTE *, BYTE *);
-int Media_D_ReadSector(struct us_data *, DWORD, WORD, BYTE *);
-int Media_D_WriteSector(struct us_data *, DWORD, WORD, BYTE *);
-int Media_D_CopySector(struct us_data *, DWORD, WORD, BYTE *);
-int Media_D_EraseBlock(struct us_data *, DWORD, WORD);
+int Check_D_Parameter(struct us_data *, u16 *, u8 *, u8 *);
+int Media_D_ReadSector(struct us_data *, u32, u16, u8 *);
+int Media_D_WriteSector(struct us_data *, u32, u16, u8 *);
+int Media_D_CopySector(struct us_data *, u32, u16, u8 *);
+int Media_D_EraseBlock(struct us_data *, u32, u16);
int Media_D_EraseAll(struct us_data *);
-int Media_D_OneSectWriteStart(struct us_data *, DWORD, BYTE *);
-int Media_D_OneSectWriteNext(struct us_data *, BYTE *);
+int Media_D_OneSectWriteStart(struct us_data *, u32, u8 *);
+int Media_D_OneSectWriteNext(struct us_data *, u8 *);
int Media_D_OneSectWriteFlush(struct us_data *);
extern int SM_FreeMem(void); /* ENE SM function */
-void SM_EnableLED(struct us_data *, BOOLEAN);
+void SM_EnableLED(struct us_data *, bool);
void Led_D_TernOn(void);
void Led_D_TernOff(void);
-int Media_D_EraseAllRedtData(DWORD Index, BOOLEAN CheckBlock);
+int Media_D_EraseAllRedtData(u32 Index, bool CheckBlock);
/*DWORD Media_D_GetMediaInfo(struct us_data * fdoExt,
PIOCTL_MEDIA_INFO_IN pParamIn, PIOCTL_MEDIA_INFO_OUT pParamOut); */
@@ -229,31 +229,31 @@ int Media_D_EraseAllRedtData(DWORD Index, BOOLEAN CheckBlock);
* SMILSub.c
-int Check_D_DataBlank(BYTE *);
-int Check_D_FailBlock(BYTE *);
-int Check_D_DataStatus(BYTE *);
-int Load_D_LogBlockAddr(BYTE *);
-void Clr_D_RedundantData(BYTE *);
-void Set_D_LogBlockAddr(BYTE *);
-void Set_D_FailBlock(BYTE *);
-void Set_D_DataStaus(BYTE *);
+int Check_D_DataBlank(u8 *);
+int Check_D_FailBlock(u8 *);
+int Check_D_DataStatus(u8 *);
+int Load_D_LogBlockAddr(u8 *);
+void Clr_D_RedundantData(u8 *);
+void Set_D_LogBlockAddr(u8 *);
+void Set_D_FailBlock(u8 *);
+void Set_D_DataStaus(u8 *);
void Ssfdc_D_Reset(struct us_data *);
-int Ssfdc_D_ReadCisSect(struct us_data *, BYTE *, BYTE *);
+int Ssfdc_D_ReadCisSect(struct us_data *, u8 *, u8 *);
void Ssfdc_D_WriteRedtMode(void);
-void Ssfdc_D_ReadID(BYTE *, BYTE);
-int Ssfdc_D_ReadSect(struct us_data *, BYTE *, BYTE *);
-int Ssfdc_D_ReadBlock(struct us_data *, WORD, BYTE *, BYTE *);
-int Ssfdc_D_WriteSect(struct us_data *, BYTE *, BYTE *);
-int Ssfdc_D_WriteBlock(struct us_data *, WORD, BYTE *, BYTE *);
-int Ssfdc_D_CopyBlock(struct us_data *, WORD, BYTE *, BYTE *);
-int Ssfdc_D_WriteSectForCopy(struct us_data *, BYTE *, BYTE *);
+void Ssfdc_D_ReadID(u8 *, u8);
+int Ssfdc_D_ReadSect(struct us_data *, u8 *, u8 *);
+int Ssfdc_D_ReadBlock(struct us_data *, u16, u8 *, u8 *);
+int Ssfdc_D_WriteSect(struct us_data *, u8 *, u8 *);
+int Ssfdc_D_WriteBlock(struct us_data *, u16, u8 *, u8 *);
+int Ssfdc_D_CopyBlock(struct us_data *, u16, u8 *, u8 *);
+int Ssfdc_D_WriteSectForCopy(struct us_data *, u8 *, u8 *);
int Ssfdc_D_EraseBlock(struct us_data *);
-int Ssfdc_D_ReadRedtData(struct us_data *, BYTE *);
-int Ssfdc_D_WriteRedtData(struct us_data *, BYTE *);
+int Ssfdc_D_ReadRedtData(struct us_data *, u8 *);
+int Ssfdc_D_WriteRedtData(struct us_data *, u8 *);
int Ssfdc_D_CheckStatus(void);
-int Set_D_SsfdcModel(BYTE);
+int Set_D_SsfdcModel(u8);
void Cnt_D_Reset(void);
int Cnt_D_PowerOn(void);
void Cnt_D_PowerOff(void);
@@ -263,26 +263,26 @@ int Check_D_CntPower(void);
int Check_D_CardExist(void);
int Check_D_CardStsChg(void);
int Check_D_SsfdcWP(void);
-int SM_ReadBlock(struct us_data *, BYTE *, BYTE *);
+int SM_ReadBlock(struct us_data *, u8 *, u8 *);
-int Ssfdc_D_ReadSect_DMA(struct us_data *, BYTE *, BYTE *);
-int Ssfdc_D_ReadSect_PIO(struct us_data *, BYTE *, BYTE *);
-int Ssfdc_D_WriteSect_DMA(struct us_data *, BYTE *, BYTE *);
-int Ssfdc_D_WriteSect_PIO(struct us_data *, BYTE *, BYTE *);
+int Ssfdc_D_ReadSect_DMA(struct us_data *, u8 *, u8 *);
+int Ssfdc_D_ReadSect_PIO(struct us_data *, u8 *, u8 *);
+int Ssfdc_D_WriteSect_DMA(struct us_data *, u8 *, u8 *);
+int Ssfdc_D_WriteSect_PIO(struct us_data *, u8 *, u8 *);
-int Check_D_ReadError(BYTE *);
-int Check_D_Correct(BYTE *, BYTE *);
-int Check_D_CISdata(BYTE *, BYTE *);
-void Set_D_RightECC(BYTE *);
+int Check_D_ReadError(u8 *);
+int Check_D_Correct(u8 *, u8 *);
+int Check_D_CISdata(u8 *, u8 *);
+void Set_D_RightECC(u8 *);
* SMILECC.c
-void calculate_ecc(BYTE *, BYTE *, BYTE *, BYTE *, BYTE *);
-BYTE correct_data(BYTE *, BYTE *, BYTE, BYTE, BYTE);
-int _Correct_D_SwECC(BYTE *, BYTE *, BYTE *);
-void _Calculate_D_SwECC(BYTE *, BYTE *);
+void calculate_ecc(u8 *, u8 *, u8 *, u8 *, u8 *);
+u8 correct_data(u8 *, u8 *, u8, u8, u8);
+int _Correct_D_SwECC(u8 *, u8 *, u8 *);
+void _Calculate_D_SwECC(u8 *, u8 *);
void SM_Init(void);
diff --git a/drivers/staging/keucr/smilecc.c b/drivers/staging/keucr/smilecc.c
index 6b8f7d7..ffe6030 100644
--- a/drivers/staging/keucr/smilecc.c
+++ b/drivers/staging/keucr/smilecc.c
@@ -13,7 +13,7 @@
/* #include "EMCRIOS.h" */
/* CP0-CP5 code table */
-static BYTE ecctable[256] = {
+static u8 ecctable[256] = {
0x00, 0x55, 0x56, 0x03, 0x59, 0x0C, 0x0F, 0x5A, 0x5A, 0x0F, 0x0C, 0x59, 0x03,
0x56, 0x55, 0x00, 0x65, 0x30, 0x33, 0x66, 0x3C, 0x69, 0x6A, 0x3F, 0x3F, 0x6A,
0x69, 0x3C, 0x66, 0x33, 0x30, 0x65, 0x66, 0x33, 0x30, 0x65, 0x3F, 0x6A, 0x69,
@@ -36,7 +36,7 @@ static BYTE ecctable[256] = {
0x5A, 0x5A, 0x0F, 0x0C, 0x59, 0x03, 0x56, 0x55, 0x00
-static void trans_result(BYTE, BYTE, BYTE *, BYTE *);
+static void trans_result(u8, u8, u8 *, u8 *);
#define BIT7 0x80
#define BIT6 0x40
@@ -57,11 +57,11 @@ static void trans_result(BYTE, BYTE, BYTE *, BYTE *);
* *ecc1; * LP15,LP14,LP13,...
* *ecc2; * LP07,LP06,LP05,...
-static void trans_result(BYTE reg2, BYTE reg3, BYTE *ecc1, BYTE *ecc2)
+static void trans_result(u8 reg2, u8 reg3, u8 *ecc1, u8 *ecc2)
- BYTE a; /* Working for reg2,reg3 */
- BYTE b; /* Working for ecc1,ecc2 */
- BYTE i; /* For counting */
+ u8 a; /* Working for reg2,reg3 */
+ u8 b; /* Working for ecc1,ecc2 */
+ u8 i; /* For counting */
a = BIT7; b = BIT7; /* 80h=10000000b */
*ecc1 = *ecc2 = 0; /* Clear ecc1,ecc2 */
@@ -95,21 +95,21 @@ static void trans_result(BYTE reg2, BYTE reg3, BYTE *ecc1, BYTE *ecc2)
* *ecc3; * CP5,CP4,CP3,...,"1","1"
-void calculate_ecc(BYTE *table, BYTE *data, BYTE *ecc1, BYTE *ecc2, BYTE *ecc3)
+void calculate_ecc(u8 *table, u8 *data, u8 *ecc1, u8 *ecc2, u8 *ecc3)
- DWORD i; /* For counting */
- BYTE a; /* Working for table */
- BYTE reg1; /* D-all,CP5,CP4,CP3,... */
- BYTE reg2; /* LP14,LP12,L10,... */
- BYTE reg3; /* LP15,LP13,L11,... */
+ u32 i; /* For counting */
+ u8 a; /* Working for table */
+ u8 reg1; /* D-all,CP5,CP4,CP3,... */
+ u8 reg2; /* LP14,LP12,L10,... */
+ u8 reg3; /* LP15,LP13,L11,... */
reg1 = reg2 = reg3 = 0; /* Clear parameter */
for (i = 0; i < 256; ++i) {
a = table[data[i]]; /* Get CP0-CP5 code from table */
reg1 ^= (a&MASK_CPS); /* XOR with a */
if ((a&BIT6) != 0) { /* If D_all(all bit XOR) = 1 */
- reg3 ^= (BYTE)i; /* XOR with counter */
- reg2 ^= ~((BYTE)i); /* XOR with inv. of counter */
+ reg3 ^= (u8)i; /* XOR with counter */
+ reg2 ^= ~((u8)i); /* XOR with inv. of counter */
@@ -127,22 +127,22 @@ void calculate_ecc(BYTE *table, BYTE *data, BYTE *ecc1, BYTE *ecc2, BYTE *ecc3)
* ecc2; * LP07,LP06,LP05,...
* ecc3; * CP5,CP4,CP3,...,"1","1"
-BYTE correct_data(BYTE *data, BYTE *eccdata, BYTE ecc1, BYTE ecc2, BYTE ecc3)
+u8 correct_data(u8 *data, u8 *eccdata, u8 ecc1, u8 ecc2, u8 ecc3)
- DWORD l; /* Working to check d */
- DWORD d; /* Result of comparison */
- BYTE d1, d2, d3; /* Result of comparison */
- BYTE a; /* Working for add */
- BYTE add; /* Byte address of cor. DATA */
- BYTE b; /* Working for bit */
- BYTE bit; /* Bit address of cor. DATA */
+ u32 l; /* Working to check d */
+ u32 d; /* Result of comparison */
+ u8 d1, d2, d3; /* Result of comparison */
+ u8 a; /* Working for add */
+ u8 add; /* Byte address of cor. DATA */
+ u8 b; /* Working for bit */
+ u8 bit; /* Bit address of cor. DATA */
d1 = ecc1^eccdata[1]; d2 = ecc2^eccdata[0]; /* Compare LP's */
d3 = ecc3^eccdata[2]; /* Compare CP's */
- d = ((DWORD)d1<<16) /* Result of comparison */
- +((DWORD)d2<<8)
- +(DWORD)d3;
+ d = ((u32)d1<<16) /* Result of comparison */
+ +((u32)d2<<8)
+ +(u32)d3;
if (d == 0)
return 0; /* If No error, return */
@@ -188,9 +188,9 @@ BYTE correct_data(BYTE *data, BYTE *eccdata, BYTE ecc1, BYTE ecc2, BYTE ecc3)
return 3; /* Uncorrectable error */
-int _Correct_D_SwECC(BYTE *buf, BYTE *redundant_ecc, BYTE *calculate_ecc)
+int _Correct_D_SwECC(u8 *buf, u8 *redundant_ecc, u8 *calculate_ecc)
- DWORD err;
+ u32 err;
err = correct_data(buf, redundant_ecc, *(calculate_ecc + 1),
*(calculate_ecc), *(calculate_ecc + 2));
@@ -203,7 +203,7 @@ int _Correct_D_SwECC(BYTE *buf, BYTE *redundant_ecc, BYTE *calculate_ecc)
return -1;
-void _Calculate_D_SwECC(BYTE *buf, BYTE *ecc)
+void _Calculate_D_SwECC(u8 *buf, u8 *ecc)
calculate_ecc(ecctable, buf, ecc+1, ecc+0, ecc+2);
diff --git a/drivers/staging/keucr/smilmain.c b/drivers/staging/keucr/smilmain.c
index 09d07e0..fc7cbc6 100644
--- a/drivers/staging/keucr/smilmain.c
+++ b/drivers/staging/keucr/smilmain.c
@@ -4,11 +4,11 @@
#include "smcommon.h"
#include "smil.h"
-static int Conv_D_MediaAddr(struct us_data *, DWORD);
+static int Conv_D_MediaAddr(struct us_data *, u32);
static int Inc_D_MediaAddr(struct us_data *);
-static int Media_D_ReadOneSect(struct us_data *, WORD, BYTE *);
+static int Media_D_ReadOneSect(struct us_data *, u16, u8 *);
-static int Copy_D_BlockAll(struct us_data *, DWORD);
+static int Copy_D_BlockAll(struct us_data *, u32);
static int Assign_D_WriteBlock(void);
static int Release_D_ReadBlock(struct us_data *);
@@ -16,7 +16,7 @@ static int Release_D_WriteBlock(struct us_data *);
static int Release_D_CopySector(struct us_data *);
static int Copy_D_PhyOneSect(struct us_data *);
-static int Read_D_PhyOneSect(struct us_data *, WORD, BYTE *);
+static int Read_D_PhyOneSect(struct us_data *, u16, u8 *);
static int Erase_D_PhyOneBlock(struct us_data *);
static int Set_D_PhyFmtValue(struct us_data *);
@@ -25,24 +25,24 @@ static int Make_D_LogTable(struct us_data *);
static int MarkFail_D_PhyOneBlock(struct us_data *);
-static DWORD ErrCode;
-static BYTE WorkBuf[SECTSIZE];
-static BYTE Redundant[REDTSIZE];
-static BYTE WorkRedund[REDTSIZE];
+static u32 ErrCode;
+static u8 WorkBuf[SECTSIZE];
+static u8 Redundant[REDTSIZE];
+static u8 WorkRedund[REDTSIZE];
/* 128 x 1000, Log2Phy[MAX_ZONENUM][MAX_LOGBLOCK]; */
-static WORD *Log2Phy[MAX_ZONENUM];
-static BYTE Assign[MAX_ZONENUM][MAX_BLOCKNUM / 8];
-static WORD AssignStart[MAX_ZONENUM];
-WORD ReadBlock;
-WORD WriteBlock;
-DWORD MediaChange;
-static DWORD SectCopyMode;
+static u16 *Log2Phy[MAX_ZONENUM];
+static u8 Assign[MAX_ZONENUM][MAX_BLOCKNUM / 8];
+static u16 AssignStart[MAX_ZONENUM];
+u16 ReadBlock;
+u16 WriteBlock;
+u32 MediaChange;
+static u32 SectCopyMode;
/* BIT Control Macro */
-static BYTE BitData[] = { 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80 };
-#define Set_D_Bit(a, b) (a[(BYTE)((b) / 8)] |= BitData[(b) % 8])
-#define Clr_D_Bit(a, b) (a[(BYTE)((b) / 8)] &= ~BitData[(b) % 8])
-#define Chk_D_Bit(a, b) (a[(BYTE)((b) / 8)] & BitData[(b) % 8])
+static u8 BitData[] = { 0x01, 0x02, 0x04, 0x08, 0x10, 0x20, 0x40, 0x80 };
+#define Set_D_Bit(a, b) (a[(u8)((b) / 8)] |= BitData[(b) % 8])
+#define Clr_D_Bit(a, b) (a[(u8)((b) / 8)] &= ~BitData[(b) % 8])
+#define Chk_D_Bit(a, b) (a[(u8)((b) / 8)] & BitData[(b) % 8])
/* ----- SM_FreeMem() ------------------------------------------------- */
@@ -62,9 +62,9 @@ int SM_FreeMem(void)
/* SmartMedia Read/Write/Erase Function */
/* ----- Media_D_ReadSector() ------------------------------------------- */
-int Media_D_ReadSector(struct us_data *us, DWORD start, WORD count, BYTE *buf)
+int Media_D_ReadSector(struct us_data *us, u32 start, u16 count, u8 *buf)
- WORD len, bn;
+ u16 len, bn;
if (Conv_D_MediaAddr(us, start))
return ErrCode;
@@ -97,9 +97,9 @@ int Media_D_ReadSector(struct us_data *us, DWORD start, WORD count, BYTE *buf)
/* here */
/* ----- Media_D_CopySector() ------------------------------------------ */
-int Media_D_CopySector(struct us_data *us, DWORD start, WORD count, BYTE *buf)
+int Media_D_CopySector(struct us_data *us, u32 start, u16 count, u8 *buf)
- WORD len, bn;
+ u16 len, bn;
/* pr_info("Media_D_CopySector !!!\n"); */
@@ -186,12 +186,12 @@ int Check_D_MediaFmt(struct us_data *us)
/* SmartMedia Physical Address Control Subroutine */
/* ----- Conv_D_MediaAddr() --------------------------------------------- */
-static int Conv_D_MediaAddr(struct us_data *us, DWORD addr)
+static int Conv_D_MediaAddr(struct us_data *us, u32 addr)
- DWORD temp;
+ u32 temp;
temp = addr / Ssfdc.MaxSectors;
- Media.Zone = (BYTE) (temp / Ssfdc.MaxLogBlocks);
+ Media.Zone = (u8) (temp / Ssfdc.MaxLogBlocks);
if (Log2Phy[Media.Zone] == NULL) {
if (Make_D_LogTable(us)) {
@@ -200,8 +200,8 @@ static int Conv_D_MediaAddr(struct us_data *us, DWORD addr)
- Media.Sector = (BYTE) (addr % Ssfdc.MaxSectors);
- Media.LogBlock = (WORD) (temp % Ssfdc.MaxLogBlocks);
+ Media.Sector = (u8) (addr % Ssfdc.MaxSectors);
+ Media.LogBlock = (u16) (temp % Ssfdc.MaxLogBlocks);
if (Media.Zone < Ssfdc.MaxZones) {
Clr_D_RedundantData(Redundant);
@@ -217,7 +217,7 @@ static int Conv_D_MediaAddr(struct us_data *us, DWORD addr)
/* ----- Inc_D_MediaAddr() ---------------------------------------------- */
static int Inc_D_MediaAddr(struct us_data *us)
- WORD LogBlock = Media.LogBlock;
+ u16 LogBlock = Media.LogBlock;
if (++Media.Sector < Ssfdc.MaxSectors)
return SMSUCCESS;
@@ -265,9 +265,9 @@ static int Inc_D_MediaAddr(struct us_data *us)
/* SmartMedia Read/Write Subroutine with Retry */
/* ----- Media_D_ReadOneSect() ------------------------------------------ */
-static int Media_D_ReadOneSect(struct us_data *us, WORD count, BYTE *buf)
+static int Media_D_ReadOneSect(struct us_data *us, u16 count, u8 *buf)
- DWORD err, retry;
+ u32 err, retry;
if (!Read_D_PhyOneSect(us, count, buf))
return SMSUCCESS;
@@ -309,9 +309,9 @@ static int Media_D_ReadOneSect(struct us_data *us, WORD count, BYTE *buf)
/* SmartMedia Physical Sector Data Copy Subroutine */
/* ----- Copy_D_BlockAll() ---------------------------------------------- */
-static int Copy_D_BlockAll(struct us_data *us, DWORD mode)
+static int Copy_D_BlockAll(struct us_data *us, u32 mode)
- BYTE sect;
+ u8 sect;
sect = Media.Sector;
@@ -381,7 +381,7 @@ static int Assign_D_WriteBlock(void)
/* ----- Release_D_ReadBlock() ------------------------------------------ */
static int Release_D_ReadBlock(struct us_data *us)
- DWORD mode;
+ u32 mode;
mode = SectCopyMode;
SectCopyMode = COMPLETED;
@@ -430,7 +430,7 @@ static int Release_D_WriteBlock(struct us_data *us)
static int Copy_D_PhyOneSect(struct us_data *us)
int i;
- DWORD err, retry;
+ u32 err, retry;
/* pr_info("Copy_D_PhyOneSect --- Sector = %x\n", Media.Sector); */
if (ReadBlock != NO_ASSIGN) {
@@ -504,10 +504,10 @@ static int Copy_D_PhyOneSect(struct us_data *us)
/* SmartMedia Physical Sector Read/Write/Erase Subroutine */
/* ----- Read_D_PhyOneSect() -------------------------------------------- */
-static int Read_D_PhyOneSect(struct us_data *us, WORD count, BYTE *buf)
+static int Read_D_PhyOneSect(struct us_data *us, u16 count, u8 *buf)
int i;
- DWORD retry;
+ u32 retry;
if (Media.PhyBlock == NO_ASSIGN) {
for (i = 0; i < SECTSIZE; i++)
@@ -637,10 +637,10 @@ static int Search_D_CIS(struct us_data *us)
/* ----- Make_D_LogTable() ---------------------------------------------- */
static int Make_D_LogTable(struct us_data *us)
- WORD phyblock, logblock;
+ u16 phyblock, logblock;
- Log2Phy[Media.Zone] = kmalloc(MAX_LOGBLOCK * sizeof(WORD),
+ Log2Phy[Media.Zone] = kmalloc(MAX_LOGBLOCK * sizeof(u16),
GFP_KERNEL);
/* pr_info("ExAllocatePool Zone = %x, Addr = %x\n",
Media.Zone, Log2Phy[Media.Zone]); */
@@ -693,7 +693,7 @@ static int Make_D_LogTable(struct us_data *us)
phyblock = Media.PhyBlock;
logblock = Media.LogBlock;
- Media.Sector = (BYTE)(Ssfdc.MaxSectors - 1);
+ Media.Sector = (u8)(Ssfdc.MaxSectors - 1);
if (Ssfdc_D_ReadRedtData(us, Redundant)) {
Ssfdc_D_Reset(us);
@@ -738,7 +738,7 @@ static int Make_D_LogTable(struct us_data *us)
/* ----- MarkFail_D_PhyOneBlock() --------------------------------------- */
static int MarkFail_D_PhyOneBlock(struct us_data *us)
- BYTE sect;
+ u8 sect;
Set_D_FailBlock(WorkRedund);
diff --git a/drivers/staging/keucr/smilsub.c b/drivers/staging/keucr/smilsub.c
index 2e7e137..44ced82 100644
--- a/drivers/staging/keucr/smilsub.c
+++ b/drivers/staging/keucr/smilsub.c
@@ -6,16 +6,16 @@
#include "smil.h"
-static BYTE _Check_D_DevCode(BYTE);
-static DWORD ErrXDCode;
-static BYTE IsSSFDCCompliance;
-static BYTE IsXDCompliance;
+static u8 _Check_D_DevCode(u8);
+static u32 ErrXDCode;
+static u8 IsSSFDCCompliance;
+static u8 IsXDCompliance;
-static BYTE EccBuf[6];
+static u8 EccBuf[6];
#define EVEN 0 /* Even Page for 256byte/page */
#define ODD 1 /* Odd Page for 256byte/page */
@@ -24,7 +24,7 @@ static BYTE EccBuf[6];
/* SmartMedia Redundant buffer data Control Subroutine
*----- Check_D_DataBlank() --------------------------------------------
-int Check_D_DataBlank(BYTE *redundant)
+int Check_D_DataBlank(u8 *redundant)
char i;
@@ -36,7 +36,7 @@ int Check_D_DataBlank(BYTE *redundant)
/* ----- Check_D_FailBlock() -------------------------------------------- */
-int Check_D_FailBlock(BYTE *redundant)
+int Check_D_FailBlock(u8 *redundant)
redundant += REDT_BLOCK;
@@ -51,7 +51,7 @@ int Check_D_FailBlock(BYTE *redundant)
/* ----- Check_D_DataStatus() ------------------------------------------- */
-int Check_D_DataStatus(BYTE *redundant)
+int Check_D_DataStatus(u8 *redundant)
redundant += REDT_DATA;
@@ -70,14 +70,14 @@ int Check_D_DataStatus(BYTE *redundant)
/* ----- Load_D_LogBlockAddr() ------------------------------------------ */
-int Load_D_LogBlockAddr(BYTE *redundant)
+int Load_D_LogBlockAddr(u8 *redundant)
- WORD addr1, addr2;
+ u16 addr1, addr2;
- addr1 = (WORD)*(redundant + REDT_ADDR1H)*0x0100 +
- (WORD)*(redundant + REDT_ADDR1L);
- addr2 = (WORD)*(redundant + REDT_ADDR2H)*0x0100 +
- (WORD)*(redundant + REDT_ADDR2L);
+ addr1 = (u16)*(redundant + REDT_ADDR1H)*0x0100 +
+ (u16)*(redundant + REDT_ADDR1L);
+ addr2 = (u16)*(redundant + REDT_ADDR2H)*0x0100 +
+ (u16)*(redundant + REDT_ADDR2L);
if (addr1 == addr2)
if ((addr1 & 0xF000) == 0x1000) {
@@ -85,7 +85,7 @@ int Load_D_LogBlockAddr(BYTE *redundant)
return SMSUCCESS;
- if (hweight16((WORD)(addr1^addr2)) != 0x01)
+ if (hweight16((u16)(addr1^addr2)) != 0x01)
return ERROR;
@@ -104,7 +104,7 @@ int Load_D_LogBlockAddr(BYTE *redundant)
/* ----- Clr_D_RedundantData() ------------------------------------------ */
-void Clr_D_RedundantData(BYTE *redundant)
+void Clr_D_RedundantData(u8 *redundant)
char i;
@@ -113,9 +113,9 @@ void Clr_D_RedundantData(BYTE *redundant)
/* ----- Set_D_LogBlockAddr() ------------------------------------------- */
-void Set_D_LogBlockAddr(BYTE *redundant)
+void Set_D_LogBlockAddr(u8 *redundant)
- WORD addr;
+ u16 addr;
*(redundant + REDT_BLOCK) = 0xFF;
*(redundant + REDT_DATA) = 0xFF;
@@ -125,20 +125,20 @@ void Set_D_LogBlockAddr(BYTE *redundant)
addr++;
*(redundant + REDT_ADDR1H) = *(redundant + REDT_ADDR2H) =
- (BYTE)(addr / 0x0100);
- *(redundant + REDT_ADDR1L) = *(redundant + REDT_ADDR2L) = (BYTE)addr;
+ (u8)(addr / 0x0100);
+ *(redundant + REDT_ADDR1L) = *(redundant + REDT_ADDR2L) = (u8)addr;
/*----- Set_D_FailBlock() ---------------------------------------------- */
-void Set_D_FailBlock(BYTE *redundant)
+void Set_D_FailBlock(u8 *redundant)
char i;
for (i = 0; i < REDTSIZE; i++)
- *redundant++ = (BYTE)((i == REDT_BLOCK) ? 0xF0 : 0xFF);
+ *redundant++ = (u8)((i == REDT_BLOCK) ? 0xF0 : 0xFF);
/* ----- Set_D_DataStaus() ---------------------------------------------- */
-void Set_D_DataStaus(BYTE *redundant)
+void Set_D_DataStaus(u8 *redundant)
*redundant = 0x00;
@@ -154,10 +154,10 @@ void Ssfdc_D_Reset(struct us_data *us)
/* ----- Ssfdc_D_ReadCisSect() ------------------------------------------ */
-int Ssfdc_D_ReadCisSect(struct us_data *us, BYTE *buf, BYTE *redundant)
+int Ssfdc_D_ReadCisSect(struct us_data *us, u8 *buf, u8 *redundant)
- BYTE zone, sector;
- WORD block;
+ u8 zone, sector;
+ u16 block;
zone = Media.Zone; block = Media.PhyBlock; sector = Media.Sector;
Media.Zone = 0;
@@ -177,11 +177,11 @@ int Ssfdc_D_ReadCisSect(struct us_data *us, BYTE *buf, BYTE *redundant)
/* 6250 CMD 1 */
/* ----- Ssfdc_D_ReadSect() --------------------------------------------- */
-int Ssfdc_D_ReadSect(struct us_data *us, BYTE *buf, BYTE *redundant)
+int Ssfdc_D_ReadSect(struct us_data *us, u8 *buf, u8 *redundant)
int result;
- WORD addr;
+ u16 addr;
result = ENE_LoadBinCode(us, SM_RW_PATTERN);
if (result != USB_STOR_XFER_GOOD) {
@@ -190,8 +190,8 @@ int Ssfdc_D_ReadSect(struct us_data *us, BYTE *buf, BYTE *redundant)
return USB_STOR_TRANSPORT_ERROR;
- addr = (WORD)Media.Zone*Ssfdc.MaxBlocks + Media.PhyBlock;
- addr = addr*(WORD)Ssfdc.MaxSectors + Media.Sector;
+ addr = (u16)Media.Zone*Ssfdc.MaxBlocks + Media.PhyBlock;
+ addr = addr*(u16)Ssfdc.MaxSectors + Media.Sector;
/* Read sect data */
memset(bcb, 0, sizeof(struct bulk_cb_wrap));
@@ -200,8 +200,8 @@ int Ssfdc_D_ReadSect(struct us_data *us, BYTE *buf, BYTE *redundant)
bcb->Flags = 0x80;
bcb->CDB[0] = 0xF1;
bcb->CDB[1] = 0x02;
- bcb->CDB[4] = (BYTE)addr;
- bcb->CDB[3] = (BYTE)(addr / 0x0100);
+ bcb->CDB[4] = (u8)addr;
+ bcb->CDB[3] = (u8)(addr / 0x0100);
bcb->CDB[2] = Media.Zone / 2;
@@ -215,8 +215,8 @@ int Ssfdc_D_ReadSect(struct us_data *us, BYTE *buf, BYTE *redundant)
bcb->Flags = 0x80;
bcb->CDB[0] = 0xF1;
bcb->CDB[1] = 0x03;
bcb->CDB[8] = 0;
bcb->CDB[9] = 1;
@@ -229,12 +229,12 @@ int Ssfdc_D_ReadSect(struct us_data *us, BYTE *buf, BYTE *redundant)
/* ----- Ssfdc_D_ReadBlock() --------------------------------------------- */
-int Ssfdc_D_ReadBlock(struct us_data *us, WORD count, BYTE *buf,
- BYTE *redundant)
+int Ssfdc_D_ReadBlock(struct us_data *us, u16 count, u8 *buf,
+ u8 *redundant)
int result;
- WORD addr;
+ u16 addr;
@@ -243,8 +243,8 @@ int Ssfdc_D_ReadBlock(struct us_data *us, WORD count, BYTE *buf,
@@ -253,8 +253,8 @@ int Ssfdc_D_ReadBlock(struct us_data *us, WORD count, BYTE *buf,
bcb->Flags = 0x80;
bcb->CDB[0] = 0xF1;
bcb->CDB[1] = 0x02;
@@ -268,8 +268,8 @@ int Ssfdc_D_ReadBlock(struct us_data *us, WORD count, BYTE *buf,
bcb->Flags = 0x80;
bcb->CDB[0] = 0xF1;
bcb->CDB[1] = 0x03;
bcb->CDB[8] = 0;
bcb->CDB[9] = 1;
@@ -283,12 +283,12 @@ int Ssfdc_D_ReadBlock(struct us_data *us, WORD count, BYTE *buf,
/* ----- Ssfdc_D_CopyBlock() -------------------------------------------- */
-int Ssfdc_D_CopyBlock(struct us_data *us, WORD count, BYTE *buf,
- BYTE *redundant)
+int Ssfdc_D_CopyBlock(struct us_data *us, u16 count, u8 *buf,
+ u8 *redundant)
int result;
- WORD ReadAddr, WriteAddr;
+ u16 ReadAddr, WriteAddr;
@@ -297,10 +297,10 @@ int Ssfdc_D_CopyBlock(struct us_data *us, WORD count, BYTE *buf,
- ReadAddr = (WORD)Media.Zone*Ssfdc.MaxBlocks + ReadBlock;
- ReadAddr = ReadAddr*(WORD)Ssfdc.MaxSectors;
- WriteAddr = (WORD)Media.Zone*Ssfdc.MaxBlocks + WriteBlock;
- WriteAddr = WriteAddr*(WORD)Ssfdc.MaxSectors;
+ ReadAddr = (u16)Media.Zone*Ssfdc.MaxBlocks + ReadBlock;
+ ReadAddr = ReadAddr*(u16)Ssfdc.MaxSectors;
+ WriteAddr = (u16)Media.Zone*Ssfdc.MaxBlocks + WriteBlock;
+ WriteAddr = WriteAddr*(u16)Ssfdc.MaxSectors;
/* Write sect data */
@@ -309,16 +309,16 @@ int Ssfdc_D_CopyBlock(struct us_data *us, WORD count, BYTE *buf,
bcb->Flags = 0x00;
bcb->CDB[0] = 0xF0;
bcb->CDB[1] = 0x08;
- bcb->CDB[7] = (BYTE)WriteAddr;
- bcb->CDB[6] = (BYTE)(WriteAddr / 0x0100);
+ bcb->CDB[7] = (u8)WriteAddr;
+ bcb->CDB[6] = (u8)(WriteAddr / 0x0100);
bcb->CDB[5] = Media.Zone / 2;
bcb->CDB[8] = *(redundant + REDT_ADDR1H);
bcb->CDB[9] = *(redundant + REDT_ADDR1L);
bcb->CDB[10] = Media.Sector;
- bcb->CDB[4] = (BYTE)ReadAddr;
- bcb->CDB[3] = (BYTE)(ReadAddr / 0x0100);
+ bcb->CDB[4] = (u8)ReadAddr;
+ bcb->CDB[3] = (u8)(ReadAddr / 0x0100);
} else
bcb->CDB[11] = 1;
@@ -331,11 +331,11 @@ int Ssfdc_D_CopyBlock(struct us_data *us, WORD count, BYTE *buf,
/* ----- Ssfdc_D_WriteSectForCopy() ------------------------------------- */
-int Ssfdc_D_WriteSectForCopy(struct us_data *us, BYTE *buf, BYTE *redundant)
+int Ssfdc_D_WriteSectForCopy(struct us_data *us, u8 *buf, u8 *redundant)
int result;
- WORD addr;
+ u16 addr;
@@ -345,8 +345,8 @@ int Ssfdc_D_WriteSectForCopy(struct us_data *us, BYTE *buf, BYTE *redundant)
@@ -355,8 +355,8 @@ int Ssfdc_D_WriteSectForCopy(struct us_data *us, BYTE *buf, BYTE *redundant)
bcb->Flags = 0x00;
bcb->CDB[0] = 0xF0;
bcb->CDB[1] = 0x04;
- bcb->CDB[7] = (BYTE)addr;
- bcb->CDB[6] = (BYTE)(addr / 0x0100);
+ bcb->CDB[7] = (u8)addr;
+ bcb->CDB[6] = (u8)(addr / 0x0100);
@@ -374,7 +374,7 @@ int Ssfdc_D_EraseBlock(struct us_data *us)
int result;
- WORD addr;
+ u16 addr;
@@ -383,8 +383,8 @@ int Ssfdc_D_EraseBlock(struct us_data *us)
- addr = addr*(WORD)Ssfdc.MaxSectors;
+ addr = addr*(u16)Ssfdc.MaxSectors;
bcb->Signature = cpu_to_le32(US_BULK_CB_SIGN);
@@ -392,8 +392,8 @@ int Ssfdc_D_EraseBlock(struct us_data *us)
bcb->Flags = 0x80;
bcb->CDB[0] = 0xF2;
bcb->CDB[1] = 0x06;
result = ENE_SendScsiCmd(us, FDIR_READ, NULL, 0);
@@ -405,12 +405,12 @@ int Ssfdc_D_EraseBlock(struct us_data *us)
/* 6250 CMD 2 */
/*----- Ssfdc_D_ReadRedtData() ----------------------------------------- */
-int Ssfdc_D_ReadRedtData(struct us_data *us, BYTE *redundant)
+int Ssfdc_D_ReadRedtData(struct us_data *us, u8 *redundant)
int result;
- WORD addr;
- BYTE *buf;
+ u16 addr;
+ u8 *buf;
@@ -419,8 +419,8 @@ int Ssfdc_D_ReadRedtData(struct us_data *us, BYTE *redundant)
@@ -428,8 +428,8 @@ int Ssfdc_D_ReadRedtData(struct us_data *us, BYTE *redundant)
bcb->Flags = 0x80;
bcb->CDB[0] = 0xF1;
bcb->CDB[1] = 0x03;
bcb->CDB[8] = 0;
bcb->CDB[9] = 1;
@@ -446,11 +446,11 @@ int Ssfdc_D_ReadRedtData(struct us_data *us, BYTE *redundant)
/* 6250 CMD 4 */
/* ----- Ssfdc_D_WriteRedtData() ---------------------------------------- */
-int Ssfdc_D_WriteRedtData(struct us_data *us, BYTE *redundant)
+int Ssfdc_D_WriteRedtData(struct us_data *us, u8 *redundant)
int result;
- WORD addr;
+ u16 addr;
@@ -459,8 +459,8 @@ int Ssfdc_D_WriteRedtData(struct us_data *us, BYTE *redundant)
@@ -468,8 +468,8 @@ int Ssfdc_D_WriteRedtData(struct us_data *us, BYTE *redundant)
bcb->Flags = 0x80;
bcb->CDB[0] = 0xF2;
bcb->CDB[1] = 0x05;
@@ -492,7 +492,7 @@ int Ssfdc_D_CheckStatus(void)
/* SmartMedia ID Code Check & Mode Set Subroutine
* ----- Set_D_SsfdcModel() ---------------------------------------------
-int Set_D_SsfdcModel(BYTE dcode)
+int Set_D_SsfdcModel(u8 dcode)
switch (_Check_D_DevCode(dcode)) {
case SSFDC1MB:
@@ -600,7 +600,7 @@ int Set_D_SsfdcModel(BYTE dcode)
/* ----- _Check_D_DevCode() --------------------------------------------- */
-static BYTE _Check_D_DevCode(BYTE dcode)
+static u8 _Check_D_DevCode(u8 dcode)
switch (dcode) {
case 0x6E:
@@ -630,21 +630,21 @@ static BYTE _Check_D_DevCode(BYTE dcode)
/* SmartMedia ECC Control Subroutine
* ----- Check_D_ReadError() ----------------------------------------------
-int Check_D_ReadError(BYTE *redundant)
+int Check_D_ReadError(u8 *redundant)
return SMSUCCESS;
/* ----- Check_D_Correct() ---------------------------------------------- */
-int Check_D_Correct(BYTE *buf, BYTE *redundant)
+int Check_D_Correct(u8 *buf, u8 *redundant)
return SMSUCCESS;
/* ----- Check_D_CISdata() ---------------------------------------------- */
-int Check_D_CISdata(BYTE *buf, BYTE *redundant)
+int Check_D_CISdata(u8 *buf, u8 *redundant)
- BYTE cis[] = {0x01, 0x03, 0xD9, 0x01, 0xFF, 0x18, 0x02,
+ u8 cis[] = {0x01, 0x03, 0xD9, 0x01, 0xFF, 0x18, 0x02,
0xDF, 0x01, 0x20};
int cis_len = sizeof(cis);
@@ -669,7 +669,7 @@ int Check_D_CISdata(BYTE *buf, BYTE *redundant)
/* ----- Set_D_RightECC() ---------------------------------------------- */
-void Set_D_RightECC(BYTE *redundant)
+void Set_D_RightECC(u8 *redundant)
/* Driver ECC Check */
return;
diff --git a/drivers/staging/keucr/smscsi.c b/drivers/staging/keucr/smscsi.c
index 5c03eca..20858f6 100644
--- a/drivers/staging/keucr/smscsi.c
+++ b/drivers/staging/keucr/smscsi.c
@@ -68,7 +68,7 @@ static int SM_SCSI_Test_Unit_Ready(struct us_data *us, struct scsi_cmnd *srb)
/* ----- SM_SCSI_Inquiry() --------------------------------------------- */
static int SM_SCSI_Inquiry(struct us_data *us, struct scsi_cmnd *srb)
- BYTE data_ptr[36] = {0x00, 0x80, 0x02, 0x00, 0x1F, 0x00, 0x00, 0x00,
+ u8 data_ptr[36] = {0x00, 0x80, 0x02, 0x00, 0x1F, 0x00, 0x00, 0x00,
0x55, 0x53, 0x42, 0x32, 0x2E, 0x30, 0x20,
0x20, 0x43, 0x61, 0x72, 0x64, 0x52, 0x65,
0x61, 0x64, 0x65, 0x72, 0x20, 0x20, 0x20,
@@ -82,9 +82,9 @@ static int SM_SCSI_Inquiry(struct us_data *us, struct scsi_cmnd *srb)
/* ----- SM_SCSI_Mode_Sense() ------------------------------------------ */
static int SM_SCSI_Mode_Sense(struct us_data *us, struct scsi_cmnd *srb)
- BYTE mediaNoWP[12] = {0x0b, 0x00, 0x00, 0x08, 0x00, 0x00,
+ u8 mediaNoWP[12] = {0x0b, 0x00, 0x00, 0x08, 0x00, 0x00,
0x71, 0xc0, 0x00, 0x00, 0x02, 0x00};
- BYTE mediaWP[12] = {0x0b, 0x00, 0x80, 0x08, 0x00, 0x00,
+ u8 mediaWP[12] = {0x0b, 0x00, 0x80, 0x08, 0x00, 0x00,
if (us->SM_Status.WtP)
@@ -101,9 +101,9 @@ static int SM_SCSI_Read_Capacity(struct us_data *us, struct scsi_cmnd *srb)
unsigned int offset = 0;
struct scatterlist *sg = NULL;
- DWORD bl_num;
- WORD bl_len;
- BYTE buf[8];
+ u32 bl_num;
+ u16 bl_len;
+ u8 buf[8];
dev_dbg(&us->pusb_dev->dev, "SM_SCSI_Read_Capacity\n");
@@ -132,13 +132,13 @@ static int SM_SCSI_Read_Capacity(struct us_data *us, struct scsi_cmnd *srb)
static int SM_SCSI_Read(struct us_data *us, struct scsi_cmnd *srb)
int result = 0;
- PBYTE Cdb = srb->cmnd;
- DWORD bn = ((Cdb[2] << 24) & 0xff000000) |
+ u8 *Cdb = srb->cmnd;
+ u32 bn = ((Cdb[2] << 24) & 0xff000000) |
((Cdb[3] << 16) & 0x00ff0000) |
((Cdb[4] << 8) & 0x0000ff00) |
((Cdb[5] << 0) & 0x000000ff);
- WORD blen = ((Cdb[7] << 8) & 0xff00) | ((Cdb[8] << 0) & 0x00ff);
- DWORD blenByte = blen * 0x200;
+ u16 blen = ((Cdb[7] << 8) & 0xff00) | ((Cdb[8] << 0) & 0x00ff);
+ u32 blenByte = blen * 0x200;
void *buf;
@@ -164,13 +164,13 @@ static int SM_SCSI_Read(struct us_data *us, struct scsi_cmnd *srb)
static int SM_SCSI_Write(struct us_data *us, struct scsi_cmnd *srb)
int result = 0;
void *buf;
diff --git a/drivers/staging/keucr/transport.c b/drivers/staging/keucr/transport.c
index aeb2186..ae94147 100644
--- a/drivers/staging/keucr/transport.c
+++ b/drivers/staging/keucr/transport.c
@@ -83,8 +83,8 @@ static int usb_stor_msg_common(struct us_data *us, int timeout)
static void usb_stor_print_cmd(struct us_data *us, struct scsi_cmnd *srb)
- DWORD cmd = Cdb[0];
+ u32 cmd = Cdb[0];
switch (cmd) {
case TEST_UNIT_READY:
@@ -545,8 +545,8 @@ Handle_Errors:
void BuildSenseBuffer(struct scsi_cmnd *srb, int SrbStatus)
- BYTE *buf = srb->sense_buffer;
- BYTE asc;
+ u8 *buf = srb->sense_buffer;
+ u8 asc;
pr_info("transport --- BuildSenseBuffer\n");
switch (SrbStatus) {
diff --git a/drivers/staging/keucr/transport.h b/drivers/staging/keucr/transport.h
index df34474..abd8e5a 100644
--- a/drivers/staging/keucr/transport.h
+++ b/drivers/staging/keucr/transport.h
@@ -58,9 +58,9 @@ extern void usb_stor_set_xfer_buf(struct us_data*, unsigned char *buffer,
extern void ENE_stor_invoke_transport(struct scsi_cmnd *, struct us_data *);
extern int ENE_InitMedia(struct us_data *);
extern int ENE_SMInit(struct us_data *);
-extern int ENE_SendScsiCmd(struct us_data*, BYTE, void*, int);
-extern int ENE_LoadBinCode(struct us_data*, BYTE);
-extern int ene_read_byte(struct us_data*, WORD index, void *buf);
+extern int ENE_SendScsiCmd(struct us_data*, u8, void*, int);
+extern int ENE_LoadBinCode(struct us_data*, u8);
+extern int ene_read_byte(struct us_data*, u16 index, void *buf);
extern int ENE_Read_Data(struct us_data*, void *buf, unsigned int length);
extern int ENE_Write_Data(struct us_data*, void *buf, unsigned int length);
extern void BuildSenseBuffer(struct scsi_cmnd *, int);
diff --git a/drivers/staging/keucr/usb.c b/drivers/staging/keucr/usb.c
index 3e3ca63..12ebde7 100644
--- a/drivers/staging/keucr/usb.c
+++ b/drivers/staging/keucr/usb.c
@@ -50,7 +50,7 @@ static int eucr_suspend(struct usb_interface *iface, pm_message_t message)
static int eucr_resume(struct usb_interface *iface)
- BYTE tmp = 0;
+ u8 tmp = 0;
struct us_data *us = usb_get_intfdata(iface);
pr_info("--- eucr_resume---\n");
@@ -71,7 +71,7 @@ static int eucr_resume(struct usb_interface *iface)
static int eucr_reset_resume(struct usb_interface *iface)
- BYTE tmp = 0;
+ u8 tmp = 0;
pr_info("--- eucr_reset_resume---\n");
@@ -528,7 +528,7 @@ static int eucr_probe(struct usb_interface *intf,
struct Scsi_Host *host;
struct us_data *us;
int result;
+ u8 MiscReg03 = 0;
struct task_struct *th;
pr_info("usb --- eucr_probe\n");
diff --git a/drivers/staging/keucr/usb.h b/drivers/staging/keucr/usb.h
index d665af1..e894f84 100644
--- a/drivers/staging/keucr/usb.h
+++ b/drivers/staging/keucr/usb.h
@@ -52,34 +52,34 @@ struct us_unusual_dev {
#define FDIR_READ 1
struct keucr_sd_status {
- BYTE Insert:1;
- BYTE Ready:1;
- BYTE MediaChange:1;
- BYTE IsMMC:1;
- BYTE HiCapacity:1;
- BYTE HiSpeed:1;
- BYTE WtP:1;
- BYTE Reserved:1;
+ u8 Insert:1;
+ u8 Ready:1;
+ u8 MediaChange:1;
+ u8 IsMMC:1;
+ u8 HiCapacity:1;
+ u8 HiSpeed:1;
+ u8 WtP:1;
+ u8 Reserved:1;
struct keucr_ms_status {
- BYTE Insert:1;
- BYTE Ready:1;
- BYTE IsMSPro:1;
- BYTE IsMSPHG:1;
- BYTE Reserved1:1;
- BYTE WtP:1;
- BYTE Reserved2:1;
+ u8 Insert:1;
+ u8 Ready:1;
+ u8 MediaChange:1;
+ u8 IsMSPro:1;
+ u8 IsMSPHG:1;
+ u8 Reserved1:1;
+ u8 WtP:1;
+ u8 Reserved2:1;
struct keucr_sm_status {
- BYTE Insert:1;
- BYTE Ready:1;
- BYTE Reserved:3;
- BYTE WtP:1;
- BYTE IsMS:1;
+ u8 Insert:1;
+ u8 Ready:1;
+ u8 MediaChange:1;
+ u8 Reserved:3;
+ u8 WtP:1;
+ u8 IsMS:1;
/* SD Block Length */
@@ -184,38 +184,38 @@ struct us_data {
/* ----- SD Control Data ---------------- */
/* SD_REGISTER SD_Regs; */
- WORD SD_Block_Mult;
- BYTE SD_READ_BL_LEN;
- WORD SD_C_SIZE;
- BYTE SD_C_SIZE_MULT;
+ u16 SD_Block_Mult;
+ u8 SD_READ_BL_LEN;
+ u16 SD_C_SIZE;
+ u8 SD_C_SIZE_MULT;
/* SD/MMC New spec. */
- BYTE SD_SPEC_VER;
- BYTE SD_CSD_VER;
- BYTE SD20_HIGH_CAPACITY;
- DWORD HC_C_SIZE;
- BYTE MMC_SPEC_VER;
- BYTE MMC_BusWidth;
- BYTE MMC_HIGH_CAPACITY;
+ u8 SD_SPEC_VER;
+ u8 SD_CSD_VER;
+ u8 SD20_HIGH_CAPACITY;
+ u32 HC_C_SIZE;
+ u8 MMC_SPEC_VER;
+ u8 MMC_BusWidth;
+ u8 MMC_HIGH_CAPACITY;
/* ----- MS Control Data ---------------- */
- BOOLEAN MS_SWWP;
- DWORD MSP_TotalBlock;
+ bool MS_SWWP;
+ u32 MSP_TotalBlock;
/* MS_LibControl MS_Lib; */
- BOOLEAN MS_IsRWPage;
- WORD MS_Model;
+ bool MS_IsRWPage;
+ u16 MS_Model;
/* ----- SM Control Data ---------------- */
- BYTE SM_DeviceID;
- BYTE SM_CardID;
+ u8 SM_DeviceID;
+ u8 SM_CardID;
- PBYTE testbuf;
- BYTE BIN_FLAG;
- DWORD bl_num;
+ u8 *testbuf;
+ u8 BIN_FLAG;
+ u32 bl_num;
int SrbStatus;
/* ------Power Managerment --------------- */
- BOOLEAN Power_IsResum;
+ bool Power_IsResum;
/* Convert between us_data and the corresponding Scsi_Host */ |
