staging:iio:adis16260: Fix drvdata inconsistency
Author: Lars-Peter Clausen <lars@metafoo.de>
The SPI drvdata is set to adis16260_state struct in probe(), but assumed to be
the iio_dev struct in remove(). Fix this by setting it to the iio_dev in
probe().
The issue has been discovered using the following coccinelle patch:
@r1@
type T;
T data;
expression dev;
spi_set_drvdata(dev, (void *)data)
spi_set_drvdata(dev, data)
@r2@
type r1.T;
T data;
position p;
expression dev;
data = spi_get_drvdata@p(dev)
@depends on r1@
position p != r2.p;
expression dev;
identifier data;
*data = spi_get_drvdata@p(dev)
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Jonathan Cameron
drivers/staging/iio/gyro/adis16260_core.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/iio/gyro/adis16260_core.c b/drivers/staging/iio/gyro/adis16260_core.c
index f16b393..93aa431 100644
--- a/drivers/staging/iio/gyro/adis16260_core.c
+++ b/drivers/staging/iio/gyro/adis16260_core.c
@@ -617,7 +617,7 @@ static int __devinit adis16260_probe(struct spi_device *spi)
if (pd)
st->negate = pd->negate;
/* this is only used for removal purposes */
- spi_set_drvdata(spi, st);
+ spi_set_drvdata(spi, indio_dev);
st->us = spi;
mutex_init(&st->buf_lock); |
if (pd)
st->us = spi;
