staging:iio: Add missing __devinit and __devexit annotations
Author: Lars-Peter Clausen <lars@metafoo.de>
Autogenerated using the following coccinelle semantic patch:
@r1@
identifier driver;
identifier fn;
position p;
type T;
T driver = {
 .remove =
 fn@p
 __devexit_p(fn@p)
@r2@
identifier r1.fn;
position p != r1.p;
fn@p
@r3@
identifier r1.fn;
position r1.p;
 __devexit_p(fn@p)
-fn@p
+__devexit_p(fn)
@depends on !r2@
identifier r1.fn;
 static
-int fn
+int __devexit fn
@r11@
identifier driver;
identifier fn;
position p;
type T;
T driver = {
	.probe = fn@p
@r12@
identifier r11.fn;
position p != r11.p;
fn@p
@depends on !r12@
identifier r11.fn;
 static
-int fn
+int __devinit fn
Signed-off-by: Lars-Peter Clausen
Signed-off-by: Jonathan Cameron
 drivers/staging/iio/accel/adis16201_core.c          | 2 +-
 drivers/staging/iio/accel/adis16203_core.c          | 2 +-
 drivers/staging/iio/accel/adis16204_core.c          | 2 +-
 drivers/staging/iio/accel/adis16209_core.c          | 2 +-
 drivers/staging/iio/accel/adis16220_core.c          | 2 +-
 drivers/staging/iio/accel/adis16240_core.c          | 2 +-
 drivers/staging/iio/accel/lis3l02dq_core.c          | 2 +-
 drivers/staging/iio/accel/sca3000_core.c            | 2 +-
 drivers/staging/iio/adc/ad7192.c                    | 2 +-
 drivers/staging/iio/adc/ad7476_core.c               | 2 +-
 drivers/staging/iio/adc/ad7780.c                    | 2 +-
 drivers/staging/iio/adc/ad7793.c                    | 2 +-
 drivers/staging/iio/adc/ad7887_core.c               | 2 +-
 drivers/staging/iio/adc/max1363_core.c              | 4 ++--
 drivers/staging/iio/gyro/adis16060_core.c           | 4 ++--
 drivers/staging/iio/gyro/adis16080_core.c           | 2 +-
 drivers/staging/iio/gyro/adis16130_core.c           | 2 +-
 drivers/staging/iio/gyro/adis16260_core.c           | 2 +-
 drivers/staging/iio/gyro/adxrs450_core.c            | 2 +-
 drivers/staging/iio/imu/adis16400_core.c            | 2 +-
 drivers/staging/iio/light/tsl2563.c                 | 2 +-
 drivers/staging/iio/meter/ade7753.c                 | 2 +-
 drivers/staging/iio/meter/ade7754.c                 | 2 +-
 drivers/staging/iio/meter/ade7758_core.c            | 2 +-
 drivers/staging/iio/meter/ade7759.c                 | 2 +-
 drivers/staging/iio/meter/ade7854-spi.c             | 2 +-
 drivers/staging/iio/trigger/iio-trig-gpio.c         | 6 +++---
 drivers/staging/iio/trigger/iio-trig-periodic-rtc.c | 6 +++---
 28 files changed, 34 insertions(+), 34 deletions(-)
diff --git a/drivers/staging/iio/accel/adis16201_core.c b/drivers/staging/iio/accel/adis16201_core.c
index ec2332f..8e37d6e 100644
--- a/drivers/staging/iio/accel/adis16201_core.c
+++ b/drivers/staging/iio/accel/adis16201_core.c
@@ -565,7 +565,7 @@ error_ret:
 	return ret;
-static int adis16201_remove(struct spi_device *spi)
+static int __devexit adis16201_remove(struct spi_device *spi)
 	struct iio_dev *indio_dev = spi_get_drvdata(spi);
diff --git a/drivers/staging/iio/accel/adis16203_core.c b/drivers/staging/iio/accel/adis16203_core.c
index 34b76c5..002fa9d 100644
--- a/drivers/staging/iio/accel/adis16203_core.c
+++ b/drivers/staging/iio/accel/adis16203_core.c
@@ -500,7 +500,7 @@ error_ret:
 	return ret;
-static int adis16203_remove(struct spi_device *spi)
+static int __devexit adis16203_remove(struct spi_device *spi)
diff --git a/drivers/staging/iio/accel/adis16204_core.c b/drivers/staging/iio/accel/adis16204_core.c
index 02fb101..05bdb7c 100644
--- a/drivers/staging/iio/accel/adis16204_core.c
+++ b/drivers/staging/iio/accel/adis16204_core.c
@@ -558,7 +558,7 @@ error_ret:
 	return ret;
-static int adis16204_remove(struct spi_device *spi)
+static int __devexit adis16204_remove(struct spi_device *spi)
diff --git a/drivers/staging/iio/accel/adis16209_core.c b/drivers/staging/iio/accel/adis16209_core.c
index 4fa2229..b7333bf 100644
--- a/drivers/staging/iio/accel/adis16209_core.c
+++ b/drivers/staging/iio/accel/adis16209_core.c
@@ -573,7 +573,7 @@ error_ret:
 	return ret;
-static int adis16209_remove(struct spi_device *spi)
+static int __devexit adis16209_remove(struct spi_device *spi)
diff --git a/drivers/staging/iio/accel/adis16220_core.c b/drivers/staging/iio/accel/adis16220_core.c
index c31e1ec..c755089 100644
--- a/drivers/staging/iio/accel/adis16220_core.c
+++ b/drivers/staging/iio/accel/adis16220_core.c
@@ -663,7 +663,7 @@ error_ret:
 	return ret;
-static int adis16220_remove(struct spi_device *spi)
+static int __devexit adis16220_remove(struct spi_device *spi)
diff --git a/drivers/staging/iio/accel/adis16240_core.c b/drivers/staging/iio/accel/adis16240_core.c
index dafc0d8..0fc26a49 100644
--- a/drivers/staging/iio/accel/adis16240_core.c
+++ b/drivers/staging/iio/accel/adis16240_core.c
@@ -619,7 +619,7 @@ error_ret:
 	return ret;
-static int adis16240_remove(struct spi_device *spi)
+static int __devexit adis16240_remove(struct spi_device *spi)
diff --git a/drivers/staging/iio/accel/lis3l02dq_core.c b/drivers/staging/iio/accel/lis3l02dq_core.c
index 0c2b4ba..54ce17f 100644
--- a/drivers/staging/iio/accel/lis3l02dq_core.c
+++ b/drivers/staging/iio/accel/lis3l02dq_core.c
@@ -780,7 +780,7 @@ err_ret:
 /* fixme, confirm ordering in this function */
-static int lis3l02dq_remove(struct spi_device *spi)
+static int __devexit lis3l02dq_remove(struct spi_device *spi)
 	int ret;
diff --git a/drivers/staging/iio/accel/sca3000_core.c b/drivers/staging/iio/accel/sca3000_core.c
index cc040e1..581cdbd 100644
--- a/drivers/staging/iio/accel/sca3000_core.c
+++ b/drivers/staging/iio/accel/sca3000_core.c
@@ -1233,7 +1233,7 @@ error_ret:
 	return ret;
-static int sca3000_remove(struct spi_device *spi)
+static int __devexit sca3000_remove(struct spi_device *spi)
 	struct sca3000_state *st = iio_priv(indio_dev);
diff --git a/drivers/staging/iio/adc/ad7192.c b/drivers/staging/iio/adc/ad7192.c
index 189d951..c351cae 100644
--- a/drivers/staging/iio/adc/ad7192.c
+++ b/drivers/staging/iio/adc/ad7192.c
@@ -684,7 +684,7 @@ error_put_reg:
 	return ret;
-static int ad7192_remove(struct spi_device *spi)
+static int __devexit ad7192_remove(struct spi_device *spi)
 	struct ad7192_state *st = iio_priv(indio_dev);
diff --git a/drivers/staging/iio/adc/ad7476_core.c b/drivers/staging/iio/adc/ad7476_core.c
index 4d30a79..4f6d59e 100644
--- a/drivers/staging/iio/adc/ad7476_core.c
+++ b/drivers/staging/iio/adc/ad7476_core.c
@@ -196,7 +196,7 @@ error_ret:
 	return ret;
-static int ad7476_remove(struct spi_device *spi)
+static int __devexit ad7476_remove(struct spi_device *spi)
 	struct ad7476_state *st = iio_priv(indio_dev);
diff --git a/drivers/staging/iio/adc/ad7780.c b/drivers/staging/iio/adc/ad7780.c
index 853f8b1..5f807ce 100644
--- a/drivers/staging/iio/adc/ad7780.c
+++ b/drivers/staging/iio/adc/ad7780.c
@@ -225,7 +225,7 @@ error_put_reg:
 	return ret;
-static int ad7780_remove(struct spi_device *spi)
+static int __devexit ad7780_remove(struct spi_device *spi)
 	struct ad7780_state *st = iio_priv(indio_dev);
diff --git a/drivers/staging/iio/adc/ad7793.c b/drivers/staging/iio/adc/ad7793.c
index ddc7fd7..691a7be 100644
--- a/drivers/staging/iio/adc/ad7793.c
+++ b/drivers/staging/iio/adc/ad7793.c
@@ -522,7 +522,7 @@ error_put_reg:
 	return ret;
-static int ad7793_remove(struct spi_device *spi)
+static int __devexit ad7793_remove(struct spi_device *spi)
 	struct ad7793_state *st = iio_priv(indio_dev);
diff --git a/drivers/staging/iio/adc/ad7887_core.c b/drivers/staging/iio/adc/ad7887_core.c
index 397b849..5517905 100644
--- a/drivers/staging/iio/adc/ad7887_core.c
+++ b/drivers/staging/iio/adc/ad7887_core.c
@@ -219,7 +219,7 @@ error_put_reg:
 	return ret;
-static int ad7887_remove(struct spi_device *spi)
+static int __devexit ad7887_remove(struct spi_device *spi)
 	struct ad7887_state *st = iio_priv(indio_dev);
diff --git a/drivers/staging/iio/adc/max1363_core.c b/drivers/staging/iio/adc/max1363_core.c
index 816bb2c..adb90fe 100644
--- a/drivers/staging/iio/adc/max1363_core.c
+++ b/drivers/staging/iio/adc/max1363_core.c
@@ -1367,7 +1367,7 @@ error_out:
 	return ret;
-static int max1363_remove(struct i2c_client *client)
+static int __devexit max1363_remove(struct i2c_client *client)
 	struct iio_dev *indio_dev = i2c_get_clientdata(client);
 	struct max1363_state *st = iio_priv(indio_dev);
@@ -1434,7 +1434,7 @@ static struct i2c_driver max1363_driver = {
 		.name = "max1363",
 	.probe = max1363_probe,
-	.remove = max1363_remove,
+	.remove = __devexit_p(max1363_remove),
 	.id_table = max1363_id,
 module_i2c_driver(max1363_driver);
diff --git a/drivers/staging/iio/gyro/adis16060_core.c b/drivers/staging/iio/gyro/adis16060_core.c
index 9931e20..87151a7 100644
--- a/drivers/staging/iio/gyro/adis16060_core.c
+++ b/drivers/staging/iio/gyro/adis16060_core.c
@@ -184,7 +184,7 @@ error_ret:
-static int adis16060_r_remove(struct spi_device *spi)
+static int __devexit adis16060_r_remove(struct spi_device *spi)
 	iio_device_unregister(spi_get_drvdata(spi));
 	iio_device_free(spi_get_drvdata(spi));
@@ -210,7 +210,7 @@ error_ret:
 	return ret;
-static int adis16060_w_remove(struct spi_device *spi)
+static int __devexit adis16060_w_remove(struct spi_device *spi)
 	return 0;
diff --git a/drivers/staging/iio/gyro/adis16080_core.c b/drivers/staging/iio/gyro/adis16080_core.c
index 345e4fa..a739025 100644
--- a/drivers/staging/iio/gyro/adis16080_core.c
+++ b/drivers/staging/iio/gyro/adis16080_core.c
@@ -177,7 +177,7 @@ error_ret:
-static int adis16080_remove(struct spi_device *spi)
+static int __devexit adis16080_remove(struct spi_device *spi)
diff --git a/drivers/staging/iio/gyro/adis16130_core.c b/drivers/staging/iio/gyro/adis16130_core.c
index bf61cd0..fbf96b0 100644
--- a/drivers/staging/iio/gyro/adis16130_core.c
+++ b/drivers/staging/iio/gyro/adis16130_core.c
@@ -154,7 +154,7 @@ error_ret:
-static int adis16130_remove(struct spi_device *spi)
+static int __devexit adis16130_remove(struct spi_device *spi)
diff --git a/drivers/staging/iio/gyro/adis16260_core.c b/drivers/staging/iio/gyro/adis16260_core.c
index 93aa431..dec2504 100644
--- a/drivers/staging/iio/gyro/adis16260_core.c
+++ b/drivers/staging/iio/gyro/adis16260_core.c
@@ -698,7 +698,7 @@ error_ret:
 	return ret;
-static int adis16260_remove(struct spi_device *spi)
+static int __devexit adis16260_remove(struct spi_device *spi)
 	int ret;
diff --git a/drivers/staging/iio/gyro/adxrs450_core.c b/drivers/staging/iio/gyro/adxrs450_core.c
index 6513119..d93527d 100644
--- a/drivers/staging/iio/gyro/adxrs450_core.c
+++ b/drivers/staging/iio/gyro/adxrs450_core.c
@@ -409,7 +409,7 @@ error_ret:
 	return ret;
-static int adxrs450_remove(struct spi_device *spi)
+static int __devexit adxrs450_remove(struct spi_device *spi)
diff --git a/drivers/staging/iio/imu/adis16400_core.c b/drivers/staging/iio/imu/adis16400_core.c
index 4ce9e3d..b9f8438 100644
--- a/drivers/staging/iio/imu/adis16400_core.c
+++ b/drivers/staging/iio/imu/adis16400_core.c
@@ -1204,7 +1204,7 @@ error_ret:
-static int adis16400_remove(struct spi_device *spi)
+static int __devexit adis16400_remove(struct spi_device *spi)
 	int ret;
diff --git a/drivers/staging/iio/light/tsl2563.c b/drivers/staging/iio/light/tsl2563.c
index 9d740be..954ca2c 100644
--- a/drivers/staging/iio/light/tsl2563.c
+++ b/drivers/staging/iio/light/tsl2563.c
@@ -805,7 +805,7 @@ fail1:
 	return err;
-static int tsl2563_remove(struct i2c_client *client)
+static int __devexit tsl2563_remove(struct i2c_client *client)
 	struct tsl2563_chip *chip = i2c_get_clientdata(client);
 	struct iio_dev *indio_dev = iio_priv_to_dev(chip);
diff --git a/drivers/staging/iio/meter/ade7753.c b/drivers/staging/iio/meter/ade7753.c
index f04ece7..6caf80c 100644
--- a/drivers/staging/iio/meter/ade7753.c
+++ b/drivers/staging/iio/meter/ade7753.c
@@ -553,7 +553,7 @@ error_ret:
-static int ade7753_remove(struct spi_device *spi)
+static int __devexit ade7753_remove(struct spi_device *spi)
 	int ret;
diff --git a/drivers/staging/iio/meter/ade7754.c b/drivers/staging/iio/meter/ade7754.c
index 6cee28a..ab912ca 100644
--- a/drivers/staging/iio/meter/ade7754.c
+++ b/drivers/staging/iio/meter/ade7754.c
@@ -575,7 +575,7 @@ error_ret:
-static int ade7754_remove(struct spi_device *spi)
+static int __devexit ade7754_remove(struct spi_device *spi)
 	int ret;
diff --git a/drivers/staging/iio/meter/ade7758_core.c b/drivers/staging/iio/meter/ade7758_core.c
index 6d3725a..958f8f2 100644
--- a/drivers/staging/iio/meter/ade7758_core.c
+++ b/drivers/staging/iio/meter/ade7758_core.c
@@ -962,7 +962,7 @@ error_ret:
 	return ret;
-static int ade7758_remove(struct spi_device *spi)
+static int __devexit ade7758_remove(struct spi_device *spi)
 	struct ade7758_state *st = iio_priv(indio_dev);
diff --git a/drivers/staging/iio/meter/ade7759.c b/drivers/staging/iio/meter/ade7759.c
index b3f7e0fa9..d494052 100644
--- a/drivers/staging/iio/meter/ade7759.c
+++ b/drivers/staging/iio/meter/ade7759.c
@@ -497,7 +497,7 @@ error_ret:
-static int ade7759_remove(struct spi_device *spi)
+static int __devexit ade7759_remove(struct spi_device *spi)
 	int ret;
diff --git a/drivers/staging/iio/meter/ade7854-spi.c b/drivers/staging/iio/meter/ade7854-spi.c
index 9fb2f8b..7dae035 100644
--- a/drivers/staging/iio/meter/ade7854-spi.c
+++ b/drivers/staging/iio/meter/ade7854-spi.c
@@ -330,7 +330,7 @@ static int __devinit ade7854_spi_probe(struct spi_device *spi)
 	return 0;
-static int ade7854_spi_remove(struct spi_device *spi)
+static int __devexit ade7854_spi_remove(struct spi_device *spi)
 	ade7854_remove(spi_get_drvdata(spi));
diff --git a/drivers/staging/iio/trigger/iio-trig-gpio.c b/drivers/staging/iio/trigger/iio-trig-gpio.c
index 90b2684..de26d54 100644
--- a/drivers/staging/iio/trigger/iio-trig-gpio.c
+++ b/drivers/staging/iio/trigger/iio-trig-gpio.c
@@ -51,7 +51,7 @@ static const struct iio_trigger_ops iio_gpio_trigger_ops = {
 	.owner = THIS_MODULE,
-static int iio_gpio_trigger_probe(struct platform_device *pdev)
+static int __devinit iio_gpio_trigger_probe(struct platform_device *pdev)
 	struct iio_gpio_trigger_info *trig_info;
 	struct iio_trigger *trig, *trig2;
@@ -130,7 +130,7 @@ error_free_completed_registrations:
 	return ret;
-static int iio_gpio_trigger_remove(struct platform_device *pdev)
+static int __devexit iio_gpio_trigger_remove(struct platform_device *pdev)
@@ -153,7 +153,7 @@ static int iio_gpio_trigger_remove(struct platform_device *pdev)
 static struct platform_driver iio_gpio_trigger_driver = {
 	.probe = iio_gpio_trigger_probe,
-	.remove = iio_gpio_trigger_remove,
+	.remove = __devexit_p(iio_gpio_trigger_remove),
 	.driver = {
 		.name = "iio_gpio_trigger",
diff --git a/drivers/staging/iio/trigger/iio-trig-periodic-rtc.c b/drivers/staging/iio/trigger/iio-trig-periodic-rtc.c
index 4ceaa18..b837801 100644
--- a/drivers/staging/iio/trigger/iio-trig-periodic-rtc.c
+++ b/drivers/staging/iio/trigger/iio-trig-periodic-rtc.c
@@ -101,7 +101,7 @@ static const struct iio_trigger_ops iio_prtc_trigger_ops = {
 	.set_trigger_state = &iio_trig_periodic_rtc_set_state,
-static int iio_trig_periodic_rtc_probe(struct platform_device *dev)
+static int __devinit iio_trig_periodic_rtc_probe(struct platform_device *dev)
 	char **pdata = dev->dev.platform_data;
 	struct iio_prtc_trigger_info *trig_info;
@@ -167,7 +167,7 @@ error_free_completed_registrations:
 	return ret;
-static int iio_trig_periodic_rtc_remove(struct platform_device *dev)
+static int __devexit iio_trig_periodic_rtc_remove(struct platform_device *dev)
@@ -188,7 +188,7 @@ static int iio_trig_periodic_rtc_remove(struct platform_device *dev)
 static struct platform_driver iio_trig_periodic_rtc_driver = {
 	.probe = iio_trig_periodic_rtc_probe,
-	.remove = iio_trig_periodic_rtc_remove,
+	.remove = __devexit_p(iio_trig_periodic_rtc_remove),
 	.driver = {
 		.name = "iio_prtc_trigger",
BtrLinux
Privacy Overview
