staging/easycap: Use memdup_user
Author: Thomas Meyer <thomas@m3y3r.de>
Use kmemdup_user rather than duplicating its implementation
This is a little bit restricted to reduce false positives
The semantic patch that makes this output is available
in scripts/coccinelle/api/memdup_user.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Thomas Meyer
drivers/staging/easycap/easycap_ioctl.c | 30 ++++++++++--------------------
1 file changed, 10 insertions(+), 20 deletions(-)
diff --git a/drivers/staging/easycap/easycap_ioctl.c b/drivers/staging/easycap/easycap_ioctl.c
index 0accab9..91262fb 100644
--- a/drivers/staging/easycap/easycap_ioctl.c
+++ b/drivers/staging/easycap/easycap_ioctl.c
@@ -1317,17 +1317,12 @@ long easycap_unlocked_ioctl(struct file *file,
struct v4l2_control *pv4l2_control;
JOM(8, "VIDIOC_G_CTRL\n");
- pv4l2_control = kzalloc(sizeof(struct v4l2_control), GFP_KERNEL);
- if (!pv4l2_control) {
- SAM("ERROR: out of memory\n");
+ pv4l2_control = memdup_user((void __user *)arg,
+ sizeof(struct v4l2_control));
+ if (IS_ERR(pv4l2_control)) {
+ SAM("ERROR: copy from user failed\n");
mutex_unlock(&easycapdc60_dongle[kd].mutex_video);
- return -ENOMEM;
- if (0 != copy_from_user(pv4l2_control, (void __user *)arg,
- sizeof(struct v4l2_control))) {
- kfree(pv4l2_control);
- mutex_unlock(&easycapdc60_dongle[kd].mutex_video);
- return -EFAULT;
+ return PTR_ERR(pv4l2_control);
switch (pv4l2_control->id) {
@@ -2356,17 +2351,12 @@ long easycap_unlocked_ioctl(struct file *file,
struct v4l2_streamparm *pv4l2_streamparm;
JOM(8, "VIDIOC_G_PARM\n");
- pv4l2_streamparm = kzalloc(sizeof(struct v4l2_streamparm), GFP_KERNEL);
- if (!pv4l2_streamparm) {
- return -ENOMEM;
- if (copy_from_user(pv4l2_streamparm,
- (void __user *)arg, sizeof(struct v4l2_streamparm))) {
- kfree(pv4l2_streamparm);
+ pv4l2_streamparm = memdup_user((void __user *)arg,
+ sizeof(struct v4l2_streamparm));
+ if (IS_ERR(pv4l2_streamparm)) {
- return -EFAULT;
+ return PTR_ERR(pv4l2_streamparm);
if (pv4l2_streamparm->type != V4L2_BUF_TYPE_VIDEO_CAPTURE) { |
- return -ENOMEM;
- return -EFAULT;
- return -ENOMEM;
- return -EFAULT;
