staging:dgnc: Removed assignments from if statements.
Author: Chi Pham <fempsci@gmail.com>
Coccinelle was used for this patch. The script is not complete (semantically) and might raise some checkpatch warnings in terms of indentation depending on existing code.
*** IFASSIGNMENT.COCCI START ***
/* Coccinelle script to handle assignments in if statements
* For compound statements, can so far only handle statements with the
* assignment on either extreme */
/* This rule is for simple cases
* e.g. just an assignment in if, possibly with unary operator */
@simple@
expression E1, E2;
statement S1, S2;
+ E1 = E2;
if (
- (E1 = E2)
+ E1
S1 else S2
/* This rule is for compound statements where the assignment is on the right.*/
@right@
expression E, E1, E2;
statement S1, S2;
/* and */
- if (E && (E1 = E2))
+ if (E) {
+ E1 = E2;
+ if (E1)
S1 else S2
+ } else S2
+ if (E) {
+ E1 = E2;
+ if (E1)
S1
/* or */
- if (E || (E1 = E2))
+ if (!E) {
+ E1 = E2;
+ if (E1)
S1 else S2
+ else S1
+ if (!E) {
+ E1 = E2;
+ if (E1) S1
+ } else
S1
/* not equal */
- if (E != (E1 = E2))
+ E1 = E2;
+ if (E != E1)
S1 else S2
+ E1 = E2;
+ if (E != E1)
S1
/* equal */
- if (E == (E1 = E2))
+ E1 = E2;
+ if (E == E1)
S1 else S2
+ E1 = E2;
+ if (E == E1)
S1
/* greater than */
- if (E > (E1 = E2))
+ E1 = E2;
+ if (E > E1)
S1 else S2
+ E1 = E2;
+ if (E > E1)
S1
/* less than */
- if (E < (E1 = E2))
+ E1 = E2;
+ if (E < E1)
S1 else S2
+ E1 = E2;
+ if (E < E1)
S1
/* lesser than or equal to */
- if (E <= (E1 = E2))
+ E1 = E2;
+ if (E <= E1)
S1 else S2
+ E1 = E2;
+ if (E <= E1)
S1
/* greater than or equal to */
- if (E >= (E1 = E2))
+ E1 = E2;
+ if (E >= E1)
S1 else S2
+ E1 = E2;
+ if (E >= E1)
S1
/* This rule is for compound statements where the assignment is on the left.*/
@left@
statement S1, S2;
/* and */
- if ((E1 = E2) && E)
+ E1 = E2;
+ if (E1 && E)
S1 else S2
+ E1 = E2;
+ if (E1 && E)
S1
/* or */
- if ((E1 = E2) || E)
+ E1 = E2;
+ if (E1 || E)
S1
+ E1 = E2;
+ if (E1 || E)
S1 else S2
/* not equal */
- if ((E1 = E2) != E)
+ E1 = E2;
+ if (E1 != E)
S1
+ E1 = E2;
+ if (E1 != E)
S1 else S2
/* equal */
- if ((E1 = E2) == E)
+ E1 = E2;
+ if (E1 == E)
S1
+ E1 = E2;
+ if (E1 == E)
S1 else S2
/* greater */
- if ((E1 = E2) > E)
+ E1 = E2;
+ if (E1 > E)
S1
+ E1 = E2;
+ if (E1 > E)
S1 else S2
/* less */
- if ((E1 = E2) < E)
+ E1 = E2;
+ if (E1 < E)
S1
+ E1 = E2;
+ if (E1 < E)
S1 else S2
- if ((E1 = E2) <= E)
+ E1 = E2;
+ if (E1 <= E)
S1
+ E1 = E2;
+ if (E1 <= E)
S1 else S2
- if ((E1 = E2) >= E)
+ E1 = E2;
+ if (E1 >= E)
S1
+ E1 = E2;
+ if (E1 >= E)
S1 else S2
*** IFASSIGNMENT.COCCI END ***
Signed-off-by: Chi Pham
drivers/staging/dgnc/dgnc_neo.c | 3 ++-
drivers/staging/dgnc/dgnc_tty.c | 12 ++++++++----
2 files changed, 10 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/dgnc/dgnc_neo.c b/drivers/staging/dgnc/dgnc_neo.c
index dc5a138..cf22c7b 100644
--- a/drivers/staging/dgnc/dgnc_neo.c
+++ b/drivers/staging/dgnc/dgnc_neo.c
@@ -1201,7 +1201,8 @@ static void neo_copy_data_from_uart_to_queue(struct channel_t *ch)
ch->ch_cached_lsr = 0;
/* Store how much space we have left in the queue */
- if ((qleft = tail - head - 1) < 0)
+ qleft = tail - head - 1;
+ if (qleft < 0)
qleft += RQUEUEMASK + 1;
diff --git a/drivers/staging/dgnc/dgnc_tty.c b/drivers/staging/dgnc/dgnc_tty.c
index 199b9d7..f0b17c3 100644
--- a/drivers/staging/dgnc/dgnc_tty.c
+++ b/drivers/staging/dgnc/dgnc_tty.c
@@ -1022,7 +1022,8 @@ void dgnc_check_queue_flow_control(struct channel_t *ch)
int qleft = 0;
- if ((qleft = ch->ch_r_tail - ch->ch_r_head - 1) < 0)
+ qleft = ch->ch_r_tail - ch->ch_r_head - 1;
+ if (qleft < 0)
@@ -1116,7 +1117,8 @@ void dgnc_wakeup_writes(struct channel_t *ch)
* If channel now has space, wake up anyone waiting on the condition.
- if ((qlen = ch->ch_w_head - ch->ch_w_tail) < 0)
+ qlen = ch->ch_w_head - ch->ch_w_tail;
+ if (qlen < 0)
qlen += WQUEUESIZE;
if (qlen >= (WQUEUESIZE - 256)) {
@@ -1914,7 +1916,8 @@ static int dgnc_tty_write_room(struct tty_struct *tty)
head = (ch->ch_w_head) & tmask;
tail = (ch->ch_w_tail) & tmask;
- if ((ret = tail - head - 1) < 0)
+ ret = tail - head - 1;
+ if (ret < 0)
ret += WQUEUESIZE;
/* Limit printer to maxcps */
@@ -2014,7 +2017,8 @@ static int dgnc_tty_write(struct tty_struct *tty,
- if ((bufcount = tail - head - 1) < 0)
+ bufcount = tail - head - 1;
+ if (bufcount < 0)
bufcount += WQUEUESIZE;
DPR_WRITE(("%d: bufcount: %x count: %x tail: %x head: %x tmask: %x\n", |
+ if (qleft < 0)
int qleft = 0;
+ if (qleft < 0)
+ if (qlen < 0)
qlen += WQUEUESIZE;
+ if (ret < 0)
ret += WQUEUESIZE;
+ if (bufcount < 0)
