staging/comedi: Use bool initializations
Author: Peter Huewe <peterhuewe@gmx.de>
Found with coccicheck.
The semantic patch that makes this output is available
in scripts/coccinelle/misc/boolinit.cocci.
More information about semantic patching is available at
http://coccinelle.lip6.fr/
Signed-off-by: Peter Huewe
 drivers/staging/comedi/comedi_fops.c | 4 ++--
 1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/comedi/comedi_fops.c b/drivers/staging/comedi/comedi_fops.c
index 3e82ab9..dc3588a 100644
--- a/drivers/staging/comedi/comedi_fops.c
+++ b/drivers/staging/comedi/comedi_fops.c
@@ -58,7 +58,7 @@ MODULE_PARM_DESC(comedi_debug,
 #endif
-bool comedi_autoconfig = 1;
+bool comedi_autoconfig = true;
 module_param(comedi_autoconfig, bool, S_IRUGO);
 MODULE_PARM_DESC(comedi_autoconfig,
 		 "enable drivers to auto-configure comedi devices (default 1)");
@@ -2437,7 +2437,7 @@ static int __init comedi_init(void)
 	 * comedi_num_legacy_minors are zero, so we might as well adjust the
 	 * defaults in that case
-	if (comedi_autoconfig == 0 && comedi_num_legacy_minors == 0)
+	if (!comedi_autoconfig && comedi_num_legacy_minors == 0)
 		comedi_num_legacy_minors = 16;
 	memset(comedi_file_info_table, 0,
BtrLinux
Privacy Overview
