Author: Luis R. Rodriguez <mcgrof@suse.com>
The same area used for ioremap() is used for the MTRR area.
Convert the driver from using the x86 specific MTRR code to
the architecture agnostic arch_phys_wc_add(). arch_phys_wc_add()
will avoid MTRR if write-combining is available, in order to
take advantage of that also ensure the ioremap'd area is requested
as write-combining.
There are a few motivations for this:
a) Take advantage of PAT when available
b) Help bury MTRR code away, MTRR is architecture specific and on
x86 its replaced by PAT
c) Help with the goal of eventually using _PAGE_CACHE_UC over
_PAGE_CACHE_UC_MINUS on x86 on ioremap_nocache() (see commit
de33c442e titled "x86 PAT: fix performance drop for glx,
use UC minus for ioremap(), ioremap_nocache() and
pci_mmap_page_range()")
The conversion done is expressed by the following Coccinelle
SmPL patch, it additionally required manual intervention to
address all the #ifdery and removal of redundant things which
arch_phys_wc_add() already addresses such as verbose message
about when MTRR fails and doing nothing when we didn't get
an MTRR.
@ mtrr_found @
expression index, base, size;
-index = mtrr_add(base, size, MTRR_TYPE_WRCOMB, 1);
+index = arch_phys_wc_add(base, size);
@ mtrr_rm depends on mtrr_found @
expression mtrr_found.index, mtrr_found.base, mtrr_found.size;
-mtrr_del(index, base, size);
+arch_phys_wc_del(index);
@ mtrr_rm_zero_arg depends on mtrr_found @
expression mtrr_found.index;
-mtrr_del(index, 0, 0);
@ mtrr_rm_fb_info depends on mtrr_found @
struct fb_info *info;
-mtrr_del(index, info->fix.smem_start, info->fix.smem_len);
@ ioremap_replace_nocache depends on mtrr_found @
expression base, size;
-info->screen_base = ioremap_nocache(base, size);
+info->screen_base = ioremap_wc(base, size);
@ ioremap_replace_default depends on mtrr_found @
-info->screen_base = ioremap(base, size);
Generated-by: Coccinelle SmPL
Cc: Arnaud Patard
Cc: Greg Kroah-Hartman
Cc: Aaro Koskinen
Cc: Brian Vandre
Cc: Thomas Gummerer
Cc: Aya Mahfouz
Cc: Lubomir Rintel
Cc: Vitor Braga
Cc: Sudip Mukherjee
Cc: Suresh Siddha
Cc: Ingo Molnar
Cc: Thomas Gleixner
Cc: Juergen Gross
Cc: Daniel Vetter
Cc: Andy Lutomirski
Cc: Dave Airlie
Cc: Antonino Daplas
Cc: Jean-Christophe Plagniol-Villard
Cc: Tomi Valkeinen
Cc: devel@driverdev.osuosl.org
Cc: linux-fbdev@vger.kernel.org
Cc: linux-kernel@vger.kernel.org
Signed-off-by: Luis R. Rodriguez
drivers/staging/xgifb/XGI_main_26.c | 27 ++++++---------------------
1 file changed, 6 insertions(+), 21 deletions(-)
diff --git a/drivers/staging/xgifb/XGI_main_26.c b/drivers/staging/xgifb/XGI_main_26.c
index 74e8820..943d463 100644
--- a/drivers/staging/xgifb/XGI_main_26.c
+++ b/drivers/staging/xgifb/XGI_main_26.c
@@ -8,10 +8,7 @@
#include <linux/sizes.h>
#include <linux/module.h>
-#ifdef CONFIG_MTRR
-#include <asm/mtrr.h>
-#endif
+#include <linux/pci.h>
#include "XGI_main.h"
#include "vb_init.h"
@@ -1770,7 +1767,7 @@ static int xgifb_probe(struct pci_dev *pdev,
xgifb_info->video_vbase = hw_info->pjVideoMemoryAddress =
- ioremap(xgifb_info->video_base, xgifb_info->video_size);
+ ioremap_wc(xgifb_info->video_base, xgifb_info->video_size);
xgifb_info->mmio_vbase = ioremap(xgifb_info->mmio_base,
xgifb_info->mmio_size);
@@ -2014,12 +2011,8 @@ static int xgifb_probe(struct pci_dev *pdev,
fb_alloc_cmap(&fb_info->cmap, 256, 0);
-#ifdef CONFIG_MTRR
- xgifb_info->mtrr = mtrr_add(xgifb_info->video_base,
- xgifb_info->video_size, MTRR_TYPE_WRCOMB, 1);
- if (xgifb_info->mtrr >= 0)
- dev_info(&pdev->dev, "Added MTRR\n");
-#endif
+ xgifb_info->mtrr = arch_phys_wc_add(xgifb_info->video_base,
+ xgifb_info->video_size);
if (register_framebuffer(fb_info) < 0) {
ret = -EINVAL;
@@ -2031,11 +2024,7 @@ static int xgifb_probe(struct pci_dev *pdev,
return 0;
error_mtrr:
-#ifdef CONFIG_MTRR
- mtrr_del(xgifb_info->mtrr, xgifb_info->video_base,
- xgifb_info->video_size);
-#endif /* CONFIG_MTRR */
+ arch_phys_wc_del(xgifb_info->mtrr);
error_1:
iounmap(xgifb_info->mmio_vbase);
iounmap(xgifb_info->video_vbase);
@@ -2059,11 +2048,7 @@ static void xgifb_remove(struct pci_dev *pdev)
struct fb_info *fb_info = xgifb_info->fb_info;
unregister_framebuffer(fb_info);
-#ifdef CONFIG_MTRR
release_mem_region(xgifb_info->mmio_base, xgifb_info->mmio_size); |
@@ -8,10 +8,7 @@
-#ifdef CONFIG_MTRR
-#endif
-#ifdef CONFIG_MTRR
-#endif
ret = -EINVAL;
return 0;
error_mtrr:
-#ifdef CONFIG_MTRR
error_1:
-#ifdef CONFIG_MTRR
