staging: xgifb: remove extra parentheses around right bit shift operations
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
Removes extra parentheses around bitwise right shift operations.
The cases handled here are when resultant values are assigned to
variables. The issue was detected and resolved using the following
coccinelle script:
expression e, e1;
constant c;
e =
-(e1
+e1
-c);
+c;
identifier i;
constant c;
type t;
expression e;
t i =
-(e
+e
-c);
+c;
expression e, e1;
identifier f;
constant c;
e1 = f(...,
-(e
+e
-c)
+c
Signed-off-by: Aya Mahfouz
 drivers/staging/xgifb/XGI_main_26.c | 6 +++---
 1 file changed, 3 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/xgifb/XGI_main_26.c b/drivers/staging/xgifb/XGI_main_26.c
index 935c714..74e8820 100644
--- a/drivers/staging/xgifb/XGI_main_26.c
+++ b/drivers/staging/xgifb/XGI_main_26.c
@@ -106,7 +106,7 @@ static int XGIfb_mode_rate_to_ddata(struct vb_device_info *XGI_Pr,
 	sr_data = XGI_CRT1Table[index].CR[5];
-	HDE = (XGI330_RefIndex[RefreshRateTableIndex].XRes >> 3);
+	HDE = XGI330_RefIndex[RefreshRateTableIndex].XRes >> 3;
 	cr_data = XGI_CRT1Table[index].CR[3];
@@ -1011,8 +1011,8 @@ static int XGIfb_do_set_var(struct fb_var_screeninfo *var, int isactive,
 			       XGIbios_mode[xgifb_info->mode_idx].mode_no);
 			return -EINVAL;
-		info->fix.line_length = ((info->var.xres_virtual
-				* info->var.bits_per_pixel) >> 6);
+		info->fix.line_length = (info->var.xres_virtual
+				* info->var.bits_per_pixel) >> 6;
 		xgifb_reg_set(XGISR, IND_SIS_PASSWORD, SIS_PASSWORD);
BtrLinux
Privacy Overview
