staging: wlan-ng: remove unused variable
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch removes variables that were simply used to
store the return value of a function call before
returning it.
The issue was detected and resolved using the following
coccinelle script:
identifier len,f;
-int len;
 ... when != len
     when strict
-len =
+return
        f(...);
-return len;
Signed-off-by: Aya Mahfouz
 drivers/staging/wlan-ng/prism2mib.c | 11 ++---------
 1 file changed, 2 insertions(+), 9 deletions(-)
diff --git a/drivers/staging/wlan-ng/prism2mib.c b/drivers/staging/wlan-ng/prism2mib.c
index 0163e06..b4a15ef 100644
--- a/drivers/staging/wlan-ng/prism2mib.c
+++ b/drivers/staging/wlan-ng/prism2mib.c
@@ -582,8 +582,6 @@ static int prism2mib_privacyinvoked(struct mibrec *mib,
 				    struct p80211msg_dot11req_mibset *msg,
 				    void *data)
-	int result;
 	if (wlandev->hostwep & HOSTWEP_DECRYPT) {
 			mib->parm2 |= HFA384x_WEPFLAGS_DISABLE_RXCRYPT;
@@ -591,9 +589,7 @@ static int prism2mib_privacyinvoked(struct mibrec *mib,
 			mib->parm2 |= HFA384x_WEPFLAGS_DISABLE_TXCRYPT;
-	result = prism2mib_flag(mib, isget, wlandev, hw, msg, data);
-	return result;
+	return prism2mib_flag(mib, isget, wlandev, hw, msg, data);
@@ -628,11 +624,8 @@ static int prism2mib_excludeunencrypted(struct mibrec *mib,
 					void *data)
-	int result;
-	return result;
