staging: wlan-ng: Remove unnecessary macro
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
Remove unnecessary macro SUBMIT_URB by replacing it with a direct call
to usb_submit_urb()
This change was made with the help of the following Coccinelle semantic
patch:
identifier f,g;
* #define f(...) g(...)
Signed-off-by: Amitoj Kaur Chawla
drivers/staging/wlan-ng/hfa384x_usb.c | 8 +++-----
1 file changed, 3 insertions(+), 5 deletions(-)
diff --git a/drivers/staging/wlan-ng/hfa384x_usb.c b/drivers/staging/wlan-ng/hfa384x_usb.c
index 09b4b2c..602c3f3 100644
--- a/drivers/staging/wlan-ng/hfa384x_usb.c
+++ b/drivers/staging/wlan-ng/hfa384x_usb.c
@@ -126,8 +126,6 @@
#include <linux/usb.h>
#include <linux/byteorder/generic.h>
-#define SUBMIT_URB(u, f) usb_submit_urb(u, f)
#include "p80211types.h"
#include "p80211hdr.h"
#include "p80211mgmt.h"
@@ -346,7 +344,7 @@ static int submit_rx_urb(hfa384x_t *hw, gfp_t memflags)
result = -ENOLINK;
if (!hw->wlandev->hwremoved &&
!test_bit(WORK_RX_HALT, &hw->usb_flags)) {
- result = SUBMIT_URB(&hw->rx_urb, memflags);
+ result = usb_submit_urb(&hw->rx_urb, memflags);
/* Check whether we need to reset the RX pipe */
if (result == -EPIPE) {
@@ -395,7 +393,7 @@ static int submit_tx_urb(hfa384x_t *hw, struct urb *tx_urb, gfp_t memflags)
if (netif_running(netdev)) {
!test_bit(WORK_TX_HALT, &hw->usb_flags)) {
- result = SUBMIT_URB(tx_urb, memflags);
+ result = usb_submit_urb(tx_urb, memflags);
/* Test whether we need to reset the TX pipe */
@@ -2925,7 +2923,7 @@ static void hfa384x_usbctlxq_run(hfa384x_t *hw)
hw->ctlx_urb.transfer_flags |= USB_QUEUE_BULK;
/* Now submit the URB and update the CTLX's state */
- result = SUBMIT_URB(&hw->ctlx_urb, GFP_ATOMIC);
+ result = usb_submit_urb(&hw->ctlx_urb, GFP_ATOMIC);
if (result == 0) {
/* This CTLX is now running on the active queue */
head->state = CTLX_REQ_SUBMITTED; |
@@ -126,8 +126,6 @@
result = -ENOLINK;
if (result == 0) {
