staging: wlags49_h2: wl_priv: Remove useless return variables
Author: Peter Senna Tschudin <peter.senna@gmail.com>
This patch remove variables that are initialized with a constant,
are never updated, and are only used as parameter of return.
Return the constant instead of using a variable.
Verified by compilation only.
The coccinelle script that find and fixes this issue is:
type T;
constant C;
identifier ret;
- T ret = C;
... when != ret
- return ret;
+ return C;
Signed-off-by: Peter Senna Tschudin
 drivers/staging/wlags49_h2/wl_priv.c | 14 ++++----------
 1 file changed, 4 insertions(+), 10 deletions(-)
diff --git a/drivers/staging/wlags49_h2/wl_priv.c b/drivers/staging/wlags49_h2/wl_priv.c
index 41f3324..aff9273 100644
--- a/drivers/staging/wlags49_h2/wl_priv.c
+++ b/drivers/staging/wlags49_h2/wl_priv.c
@@ -179,8 +179,6 @@ int wvlan_uil(struct uilreq *urq, struct wl_private *lp)
 int wvlan_uil_connect(struct uilreq *urq, struct wl_private *lp)
-	int result = 0;
 	if (!(lp->flags & WVLAN2_UIL_CONNECTED)) {
 		lp->flags |= WVLAN2_UIL_CONNECTED;
 		urq->hcfCtx = &(lp->hcfCtx);
@@ -190,7 +188,7 @@ int wvlan_uil_connect(struct uilreq *urq, struct wl_private *lp)
 		urq->result = UIL_ERR_IN_USE;
-	return result;
+	return 0;
 } /* wvlan_uil_connect */
@@ -218,8 +216,6 @@ int wvlan_uil_connect(struct uilreq *urq, struct wl_private *lp)
 int wvlan_uil_disconnect(struct uilreq *urq, struct wl_private *lp)
-	int result = 0;
 	if (urq->hcfCtx == &(lp->hcfCtx)) {
 		if (lp->flags & WVLAN2_UIL_CONNECTED) {
 			lp->flags &= ~WVLAN2_UIL_CONNECTED;
@@ -238,7 +234,7 @@ int wvlan_uil_disconnect(struct uilreq *urq, struct wl_private *lp)
 		urq->result = UIL_ERR_WRONG_IFB;
-	return result;
+	return 0;
 } /* wvlan_uil_disconnect */
@@ -1580,7 +1576,6 @@ int wvlan_set_netname(struct net_device *dev,
 	struct wl_private *lp = wl_priv(dev);
 	unsigned long flags;
-	int ret = 0;
 	wl_lock(lp, &flags);
@@ -1591,7 +1586,7 @@ int wvlan_set_netname(struct net_device *dev,
 	wl_apply(lp);
 	wl_unlock(lp, &flags);
-	return ret;
+	return 0;
 } /* wvlan_set_netname */
@@ -1683,7 +1678,6 @@ int wvlan_set_station_nickname(struct net_device *dev,
 	size_t len;
-	int         ret = 0;
@@ -1695,7 +1689,7 @@ int wvlan_set_station_nickname(struct net_device *dev,
 	wl_apply(lp);
-	return ret;
+	return 0;
 } /* wvlan_set_station_nickname */
BtrLinux
Privacy Overview
