staging: winbond: Change variable type to bool
Author: Peter Senna Tschudin <peter.senna@gmail.com>
The variable Trigger is only assigned the values true and false.
Change its type to bool.
The simplified semantic patch that find this problem is as
follows (http://coccinelle.lip6.fr/):
@exists@
type T;
identifier b;
- T
+ bool
  b = ...;
  ... when any
  b = \(true\|false\)
Signed-off-by: Peter Senna Tschudin
Acked-by: Pavel Machek
 drivers/staging/winbond/wb35tx.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/winbond/wb35tx.c b/drivers/staging/winbond/wb35tx.c
index 30a77cc..708c5b0 100644
--- a/drivers/staging/winbond/wb35tx.c
+++ b/drivers/staging/winbond/wb35tx.c
@@ -180,7 +180,7 @@ void Wb35Tx_CurrentTime(struct wbsoft_priv *adapter, u32 TimeCount)
 	struct hw_data *pHwData = &adapter->sHwData;
 	struct wb35_tx *pWb35Tx = &pHwData->Wb35Tx;
-	unsigned char Trigger = false;
+	bool Trigger = false;
 	if (pWb35Tx->TxTimer > TimeCount)
 		Trigger = true;
BtrLinux
Privacy Overview
