staging: wilc1000: wilc_wfi_cfgoperations: remove cast on void pointers
Author: Alison Schofield <amsfield22@gmail.com>
Remove cast on void pointers. C programming language guarantees
the conversion from void pointer to any other pointer type.
Coccinelle patch:
@r@
expression x;
void* e;
type T;
identifier f;
  *((T *)e)
  ((T *)x)[...]
  ((T *)x)->f
- (T *)
  e
Signed-off-by: Alison Schofield
 drivers/staging/wilc1000/wilc_wfi_cfgoperations.c | 12 ++++++------
 1 file changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/wilc1000/wilc_wfi_cfgoperations.c b/drivers/staging/wilc1000/wilc_wfi_cfgoperations.c
index 97d1b80..81a2ee9 100644
--- a/drivers/staging/wilc1000/wilc_wfi_cfgoperations.c
+++ b/drivers/staging/wilc1000/wilc_wfi_cfgoperations.c
@@ -228,7 +228,7 @@ static void refresh_scan(void *user_void, u8 all, bool direct_scan)
 	int i;
 	int rssi = 0;
-	priv = (struct wilc_priv *)user_void;
+	priv = user_void;
 	wiphy = priv->dev->ieee80211_ptr->wiphy;
 	for (i = 0; i < last_scanned_cnt; i++) {
@@ -404,7 +404,7 @@ static void CfgScanResult(enum scan_event scan_event,
 	struct ieee80211_channel *channel;
 	struct cfg80211_bss *bss = NULL;
+	priv = user_void;
 	if (priv->bCfgScanning) {
 		if (scan_event == SCAN_EVENT_NETWORK_FOUND) {
@@ -525,7 +525,7 @@ static void CfgConnectResult(enum conn_event enuConnDisconnEvent,
 	wilc_connecting = 0;
-	priv = (struct wilc_priv *)pUserVoid;
+	priv = pUserVoid;
 	dev = priv->dev;
 	vif = netdev_priv(dev);
 	wl = vif->wilc;
@@ -1713,7 +1713,7 @@ void WILC_WFI_p2p_rx (struct net_device *dev, u8 *buff, u32 size)
 static void WILC_WFI_mgmt_tx_complete(void *priv, int status)
-	struct p2p_mgmt_data *pv_data = (struct p2p_mgmt_data *)priv;
+	struct p2p_mgmt_data *pv_data = priv;
 	kfree(pv_data->buff);
@@ -1724,7 +1724,7 @@ static void WILC_WFI_RemainOnChannelReady(void *pUserVoid)
 	struct wilc_priv *priv;
+	priv = pUserVoid;
 	priv->bInP2PlistenState = true;
@@ -1739,7 +1739,7 @@ static void WILC_WFI_RemainOnChannelExpired(void *pUserVoid, u32 u32SessionID)
+	priv = pUserVoid;
 	if (u32SessionID == priv->strRemainOnChanParams.u32ListenSessionID) {
 		priv->bInP2PlistenState = false;
BtrLinux
Privacy Overview
