staging: wilc1000: Return correct error codes
Author: Amitoj Kaur Chawla <amitoj1606@gmail.com>
This change has been made with the goal that kernel functions should
return something more descriptive than -1 on failure.
The return value on an alloc_etherdev failure should be -ENOMEM,
and not -1.
This was found using Coccinelle. A simplified version of the semantic
patch used is:
expression *e;
identifier l1;
e = alloc_etherdev(...);
if (e == NULL) {
return
- -1
+ -ENOMEM
Reviewed-by: Arnd Bergmann
drivers/staging/wilc1000/linux_wlan.c | 9 +++++----
1 file changed, 5 insertions(+), 4 deletions(-)
diff --git a/drivers/staging/wilc1000/linux_wlan.c b/drivers/staging/wilc1000/linux_wlan.c
index a731b46..274f468 100644
--- a/drivers/staging/wilc1000/linux_wlan.c
+++ b/drivers/staging/wilc1000/linux_wlan.c
@@ -1312,7 +1312,7 @@ EXPORT_SYMBOL_GPL(wilc_netdev_cleanup);
int wilc_netdev_init(struct wilc **wilc, struct device *dev, int io_type,
int gpio, const struct wilc_hif_func *ops)
- int i;
+ int i, ret;
struct wilc_vif *vif;
struct net_device *ndev;
struct wilc *wl;
@@ -1333,7 +1333,7 @@ int wilc_netdev_init(struct wilc **wilc, struct device *dev, int io_type,
for (i = 0; i < NUM_CONCURRENT_IFC; i++) {
ndev = alloc_etherdev(sizeof(struct wilc_vif));
if (!ndev)
- return -1;
+ return -ENOMEM;
vif = netdev_priv(ndev);
memset(vif, 0, sizeof(struct wilc_vif));
@@ -1372,8 +1372,9 @@ int wilc_netdev_init(struct wilc **wilc, struct device *dev, int io_type,
vif->netstats.tx_bytes = 0;
- if (register_netdev(ndev))
- return -1;
+ ret = register_netdev(ndev);
+ if (ret)
+ return ret;
vif->iftype = STATION_MODE;
vif->mac_opened = 0; |
- int i;
+ int i, ret;
struct wilc *wl;
if (!ndev)
- return -1;
+ return -ENOMEM;
- return -1;
+ if (ret)
+ return ret;
