Staging: wilc1000: Replace memset with eth_zero_addr
Author: Vaishali Thakkar <vthakkar1994@gmail.com>
Use eth_zero_addr to assign the zero address to the given address
array instead of memset when second argument is address of zero.
The Coccinelle semantic patch that makes this change is as follows:
@eth_zero_addr@
expression e;
-memset(e,0x00,ETH_ALEN);
+eth_zero_addr(e);
Signed-off-by: Vaishali Thakkar
 drivers/staging/wilc1000/linux_mon.c | 2 +-
 1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/wilc1000/linux_mon.c b/drivers/staging/wilc1000/linux_mon.c
index f5296f5..2a3d875 100644
--- a/drivers/staging/wilc1000/linux_mon.c
+++ b/drivers/staging/wilc1000/linux_mon.c
@@ -495,7 +495,7 @@ static void WILC_WFI_mon_setup(struct net_device *dev)
 	ether_setup(dev);
 	dev->tx_queue_len = 0;
 	dev->type = ARPHRD_IEEE80211_RADIOTAP;
-	memset(dev->dev_addr, 0, ETH_ALEN);
+	eth_zero_addr(dev->dev_addr);
 	#ifdef USE_WIRELESS
BtrLinux
Privacy Overview
