staging: wilc1000: Modification in code to use ARRAY_SIZE macro
Author: Chaitanya Dhere <cvijaydh@visteon.com>
In this patch, ARRAY_SIZE() macro is used to determine the
size. This change was detected with the help of coccinelle
tool.
Signed-off-by: Chaitanya Dhere
drivers/staging/wilc1000/linux_wlan.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/wilc1000/linux_wlan.c b/drivers/staging/wilc1000/linux_wlan.c
index b033eb8..592b8ae 100644
--- a/drivers/staging/wilc1000/linux_wlan.c
+++ b/drivers/staging/wilc1000/linux_wlan.c
@@ -1737,7 +1737,7 @@ static int linux_wlan_read_mac_addr(void *vp)
mm_segment_t old_fs;
loff_t pos = 0;
int index;
- int array_size = sizeof(path_string) / sizeof(path_string[0]);
+ int array_size = ARRAY_SIZE(path_string);
/* change to KERNEL_DS address limit */
old_fs = get_fs(); |
loff_t pos = 0;
int index;
old_fs = get_fs();
