staging: wilc1000: host_interface: remove cast on void pointers
Author: Alison Schofield <amsfield22@gmail.com>
Remove cast on void pointers. C programming language guarantees
the conversion from void pointer to any other pointer type.
Coccinelle patch:
@r@
expression x;
void* e;
type T;
identifier f;
*((T *)e)
((T *)x)[...]
((T *)x)->f
- (T *)
e
Signed-off-by: Alison Schofield
drivers/staging/wilc1000/host_interface.c | 4 ++--
1 file changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/wilc1000/host_interface.c b/drivers/staging/wilc1000/host_interface.c
index a6bc8a4..069fac1 100644
--- a/drivers/staging/wilc1000/host_interface.c
+++ b/drivers/staging/wilc1000/host_interface.c
@@ -953,7 +953,7 @@ static s32 Handle_Connect(struct wilc_vif *vif,
return result;
- ptstrJoinBssParam = (struct join_bss_param *)pstrHostIFconnectAttr->params;
+ ptstrJoinBssParam = pstrHostIFconnectAttr->params;
if (!ptstrJoinBssParam) {
PRINT_ER("Required BSSID not found\n");
result = -ENOENT;
@@ -2675,7 +2675,7 @@ static int hostIFthread(void *pvArg)
u32 u32Ret;
struct host_if_msg msg;
- struct wilc *wilc = (struct wilc*)pvArg;
+ struct wilc *wilc = pvArg;
struct wilc_vif *vif;
memset(&msg, 0, sizeof(struct host_if_msg)); |
return result;
result = -ENOENT;
u32 u32Ret;
