staging: wilc1000: avoid NULL pointer dereference on error
Author: Vincent Stehlé <vincent.stehle@laposte.net>
The host_int_init() function can dereference the pstrWFIDrv pointer
while it is NULL on its error path. Jump directly to the _fail_ error
label in the end of the error handling path to avoid that.
By doing that we also skip stopping our kthread and destroying
our message queue, but they were not started or created yet in that case
anyway.
This fixes the following coccinelle error:
drivers/staging/wilc1000/host_interface.c:6100:17-33: ERROR: pstrWFIDrv is NULL but dereferenced.
Signed-off-by: Vincent Stehlé
Cc: Johnny Kim
Cc: Rachel Kim
Cc: Dean Lee
Cc: Chris Park
Cc: Nicolas Ferre
Cc: Greg Kroah-Hartman
drivers/staging/wilc1000/host_interface.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/wilc1000/host_interface.c b/drivers/staging/wilc1000/host_interface.c
index ba1d05d..bb833d3 100644
--- a/drivers/staging/wilc1000/host_interface.c
+++ b/drivers/staging/wilc1000/host_interface.c
@@ -5861,7 +5861,7 @@ s32 host_int_init(tstrWILC_WFIDrv **phWFIDrv)
pstrWFIDrv = kzalloc(sizeof(tstrWILC_WFIDrv), GFP_KERNEL);
if (!pstrWFIDrv) {
result = -ENOMEM;
- goto _fail_timer_2;
+ goto _fail_;
*phWFIDrv = pstrWFIDrv;
err = add_handler_in_list(pstrWFIDrv); |
if (!pstrWFIDrv) {
result = -ENOMEM;
+ goto _fail_;
