staging: vt6656: replace explicit NULL comparison with ! operator
Author: Alison Schofield <amsfield22@gmail.com>
Replace explicit NULL comparison with ! operator to simplify code.
Found with Coccinelle:
expression e;
statement s0, s1;
if (
e
- == NULL
 ) s0 else s1
Signed-off-by: Alison Schofield
Acked-by: Julia Lawall
 drivers/staging/vt6656/main_usb.c | 10 +++++-----
 drivers/staging/vt6656/usbpipe.c  |  2 +-
 2 files changed, 6 insertions(+), 6 deletions(-)
diff --git a/drivers/staging/vt6656/main_usb.c b/drivers/staging/vt6656/main_usb.c
index a2f23ae..05f86ff 100644
--- a/drivers/staging/vt6656/main_usb.c
+++ b/drivers/staging/vt6656/main_usb.c
@@ -431,7 +431,7 @@ static bool vnt_alloc_bufs(struct vnt_private *priv)
 	for (ii = 0; ii < priv->num_tx_context; ii++) {
 		tx_context = kmalloc(sizeof(struct vnt_usb_send_context),
 								GFP_KERNEL);
-		if (tx_context == NULL)
+		if (!tx_context)
 			goto free_tx;
 		priv->tx_context[ii] = tx_context;
@@ -462,13 +462,13 @@ static bool vnt_alloc_bufs(struct vnt_private *priv)
 		/* allocate URBs */
 		rcb->urb = usb_alloc_urb(0, GFP_ATOMIC);
-		if (rcb->urb == NULL) {
+		if (!rcb->urb) {
 			dev_err(&priv->usb->dev, "Failed to alloc rx urb\n");
 			goto free_rx_tx;
 		rcb->skb = dev_alloc_skb(priv->rx_buf_sz);
-		if (rcb->skb == NULL)
+		if (!rcb->skb)
 			goto free_rx_tx;
 		rcb->in_use = false;
@@ -479,13 +479,13 @@ static bool vnt_alloc_bufs(struct vnt_private *priv)
 	priv->interrupt_urb = usb_alloc_urb(0, GFP_ATOMIC);
-	if (priv->interrupt_urb == NULL) {
+	if (!priv->interrupt_urb) {
 		dev_err(&priv->usb->dev, "Failed to alloc int urb\n");
 		goto free_rx_tx;
 	priv->int_buf.data_buf = kmalloc(MAX_INTERRUPT_SIZE, GFP_KERNEL);
-	if (priv->int_buf.data_buf == NULL) {
+	if (!priv->int_buf.data_buf) {
 		usb_free_urb(priv->interrupt_urb);
 		goto free_rx_tx;
diff --git a/drivers/staging/vt6656/usbpipe.c b/drivers/staging/vt6656/usbpipe.c
index 351a99f..bec5baf 100644
--- a/drivers/staging/vt6656/usbpipe.c
+++ b/drivers/staging/vt6656/usbpipe.c
@@ -210,7 +210,7 @@ int vnt_submit_rx_urb(struct vnt_private *priv, struct vnt_rcb *rcb)
 	struct urb *urb;
 	urb = rcb->urb;
-	if (rcb->skb == NULL) {
+	if (!rcb->skb) {
 		dev_dbg(&priv->usb->dev, "rcb->skb is null\n");
 		return status;
BtrLinux
Résumé de la politique de confidentialité
Ce site utilise des cookies afin que nous puissions vous fournir la meilleure expérience utilisateur possible. Les informations sur les cookies sont stockées dans votre navigateur et remplissent des fonctions telles que vous reconnaître lorsque vous revenez sur notre site Web et aider notre équipe à comprendre les sections du site que vous trouvez les plus intéressantes et utiles.
