Staging: vt6656: Merges two lines of code and removes unused variable
Author: Mahati Chamarthy <mahati.chamarthy@gmail.com>
This patch merges an assignment with an immediately following return of
the assigned variable.The following Coccinelle semantic patch was used to make this transformation:
expression ret;
identifier f;
-ret =
+return
f(...);
-return ret;
A variable that became unused due to this transformation was also removed.
Signed-off-by: Mahati Chamarthy
Acked-by: Julia Lawall
drivers/staging/vt6656/key.c | 5 +----
1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/staging/vt6656/key.c b/drivers/staging/vt6656/key.c
index 22f2961..181745d 100644
--- a/drivers/staging/vt6656/key.c
+++ b/drivers/staging/vt6656/key.c
@@ -37,17 +37,14 @@
int vnt_key_init_table(struct vnt_private *priv)
- int ret;
u8 i;
u8 data[MAX_KEY_TABLE];
for (i = 0; i < MAX_KEY_TABLE; i++)
data[i] = i;
- ret = vnt_control_out(priv, MESSAGE_TYPE_CLRKEYENTRY,
+ return vnt_control_out(priv, MESSAGE_TYPE_CLRKEYENTRY,
0, 0, ARRAY_SIZE(data), data);
- return ret;
static int vnt_set_keymode(struct ieee80211_hw *hw, u8 *mac_addr, |
@@ -37,17 +37,14 @@
- int ret;
u8 i;
data[i] = i;
- return ret;
