Staging: vt6656: Merge two lines of code into one
Author: Rajbinder Brar <brar.rajbinder@gmail.com>
This patch merges an assignment with an immediately following return of
the assigned variable. The following Coccinelle semantic patch was used
to make this transformation:
expression ret;
identifier f;
-ret=
+return
	f(...);
-return ret;
A variable that became unused due to this transformation was also
removed.
Signed-off-by: Rajbinder Brar
Acked-by: Julia Lawall
 drivers/staging/vt6656/rf.c | 5 +----
 1 file changed, 1 insertion(+), 4 deletions(-)
diff --git a/drivers/staging/vt6656/rf.c b/drivers/staging/vt6656/rf.c
index c0edcae..c42cde5 100644
--- a/drivers/staging/vt6656/rf.c
+++ b/drivers/staging/vt6656/rf.c
@@ -623,7 +623,6 @@ int vnt_rf_write_embedded(struct vnt_private *priv, u32 data)
 /* Set Tx power by rate and channel number */
 int vnt_rf_setpower(struct vnt_private *priv, u32 rate, u32 channel)
-	int ret = true;
 	u8 power = priv->cck_pwr;
 	if (channel == 0)
@@ -653,9 +652,7 @@ int vnt_rf_setpower(struct vnt_private *priv, u32 rate, u32 channel)
 		break;
-	ret = vnt_rf_set_txpower(priv, power, rate);
-	return ret;
+	return vnt_rf_set_txpower(priv, power, rate);
 static u8 vnt_rf_addpower(struct vnt_private *priv)
BtrLinux
Privacy Overview
