staging: vt6656: Change variable type to bool
Author: Peter Senna Tschudin <peter.senna@gmail.com>
The variables bMultiBand and bKeyTableFull are only assigned the
values true and false. Change its type to bool.
The simplified semantic patch that find this problem is as
follows (http://coccinelle.lip6.fr/):
@exists@
type T;
identifier b;
- T
+ bool
  b = ...;
  ... when any
  b = \(true\|false\)
Signed-off-by: Peter Senna Tschudin
 drivers/staging/vt6656/channel.c | 2 +-
 drivers/staging/vt6656/hostap.c  | 2 +-
 2 files changed, 2 insertions(+), 2 deletions(-)
diff --git a/drivers/staging/vt6656/channel.c b/drivers/staging/vt6656/channel.c
index 5158ff4..e430b35 100644
--- a/drivers/staging/vt6656/channel.c
+++ b/drivers/staging/vt6656/channel.c
@@ -403,7 +403,7 @@ exit:
 void CHvInitChannelTable(struct vnt_private *pDevice)
-	int bMultiBand = false;
+	bool bMultiBand = false;
 	int ii;
     for (ii = 1; ii <= CB_MAX_CHANNEL; ii++)
diff --git a/drivers/staging/vt6656/hostap.c b/drivers/staging/vt6656/hostap.c
index c699a30..7d96fe7 100644
--- a/drivers/staging/vt6656/hostap.c
+++ b/drivers/staging/vt6656/hostap.c
@@ -414,7 +414,7 @@ static int hostap_set_encryption(struct vnt_private *pDevice,
 	int ret = 0;
 	s32 iNodeIndex = -1;
 	int ii;
-	int bKeyTableFull = false;
+	bool bKeyTableFull = false;
 	u16 wKeyCtl = 0;
 	param->u.crypt.err = 0;
BtrLinux
Privacy Overview
