Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch focuses on fixing the following warning generated
by checkpatch.pl for the file wmgr.c :
Prefer ether_addr_copy() over memcpy() if the Ethernet addresses
are __aligned(2)
The changes were applied using the following coccinelle rule:
@@ expression e1, e2; @@
- memcpy(e1, e2, ETH_ALEN);
+ ether_addr_copy(e1, e2);
According to ether_addr_copy() description and functionality,
all Ethernet addresses should align to the u16 datatype.
To maintain that the array abyCurrBSSID in tagSMgmtObject is aligned,
it was placed after the int uCurrChannel in the struct definition.
This was done in wmgr.h
Here is the output of pahole for the relevant datastructures:
struct sockaddr {
sa_family_t sa_family; /* 0 2 */
char sa_data[14]; /* 2 14 */
/* size: 16, cachelines: 1, members: 2 */
/* last cacheline: 16 bytes */
struct tagSMgmtObject {
void * pAdapter; /* 0 4 */
unsigned char abyMACAddr[6]; /* 4 6 */
/* XXX 2 bytes hole, try to pack */
WMAC_CONFIG_MODE eConfigMode; /* 12 4 */
CARD_PHY_TYPE eCurrentPHYMode; /* 16 4 */
CARD_PHY_TYPE eConfigPHYMode; /* 20 4 */
WMAC_CURRENT_MODE eCurrMode; /* 24 4 */
WMAC_BSS_STATE eCurrState; /* 28 4 */
PKnownBSS pCurrBSS; /* 32 4 */
unsigned char byCSSGK; /* 36 1 */
unsigned char byCSSPK; /* 37 1 */
unsigned int uCurrChannel; /* 40 4 */
unsigned char abyCurrBSSID[6]; /* 44 6 */
unsigned char abyCurrSuppRates[19]; /* 50 19 */
/* --- cacheline 1 boundary (64 bytes) was 5 bytes ago --- */
unsigned char abyCurrExtSuppRates[19]; /* 69 19 */
unsigned char abyCurrSSID[35]; /* 88 35 */
/* XXX 1 byte hole, try to pack */
short unsigned int wCurrCapInfo; /* 124 2 */
short unsigned int wCurrAID; /* 126 2 */
/* --- cacheline 2 boundary (128 bytes) --- */
short unsigned int wCurrATIMWindow; /* 128 2 */
short unsigned int wCurrBeaconPeriod; /* 130 2 */
bool bIsDS; /* 132 1 */
unsigned char byERPContext; /* 133 1 */
CMD_STATE eCommandState; /* 136 4 */
unsigned int uScanChannel; /* 140 4 */
unsigned char abyDesireSSID[35]; /* 144 35 */
unsigned char abyDesireBSSID[6]; /* 179 6 */
short unsigned int wIBSSBeaconPeriod; /* 186 2 */
short unsigned int wIBSSATIMWindow; /* 188 2 */
/* --- cacheline 3 boundary (192 bytes) --- */
unsigned int uIBSSChannel; /* 192 4 */
unsigned char abyIBSSSuppRates[19]; /* 196 19 */
unsigned char byAPBBType; /* 215 1 */
unsigned char abyWPAIE[64]; /* 216 64 */
/* --- cacheline 4 boundary (256 bytes) was 24 bytes ago --- */
short unsigned int wWPAIELen; /* 280 2 */
unsigned int uAssocCount; /* 284 4 */
bool bMoreData; /* 288 1 */
/* XXX 3 bytes hole, try to pack */
WMAC_SCAN_STATE eScanState; /* 292 4 */
WMAC_SCAN_TYPE eScanType; /* 296 4 */
unsigned int uScanStartCh; /* 300 4 */
unsigned int uScanEndCh; /* 304 4 */
short unsigned int wScanSteps; /* 308 2 */
unsigned int uScanBSSType; /* 312 4 */
unsigned char abyScanSSID[35]; /* 316 35 */
/* --- cacheline 5 boundary (320 bytes) was 31 bytes ago --- */
unsigned char abyScanBSSID[6]; /* 351 6 */
WMAC_AUTHENTICATION_MODE eAuthenMode; /* 360 4 */
WMAC_ENCRYPTION_MODE eEncryptionMode; /* 364 4 */
bool bShareKeyAlgorithm; /* 368 1 */
unsigned char abyChallenge[128]; /* 369 128 */
/* --- cacheline 7 boundary (448 bytes) was 49 bytes ago --- */
bool bPrivacyInvoked; /* 497 1 */
bool bInTIM; /* 498 1 */
bool bMulticastTIM; /* 499 1 */
unsigned char byDTIMCount; /* 500 1 */
unsigned char byDTIMPeriod; /* 501 1 */
WMAC_POWER_MODE ePSMode; /* 504 4 */
short unsigned int wListenInterval; /* 508 2 */
short unsigned int wCountToWakeUp; /* 510 2 */
/* --- cacheline 8 boundary (512 bytes) --- */
bool bInTIMWake; /* 512 1 */
unsigned char * pbyPSPacketPool; /* 516 4 */
unsigned char byPSPacketPool[36]; /* 520 36 */
bool bRxBeaconInTBTTWake; /* 556 1 */
unsigned char abyPSTxMap[65]; /* 557 65 */
/* --- cacheline 9 boundary (576 bytes) was 48 bytes ago --- */
unsigned int uCmdBusy; /* 624 4 */
unsigned int uCmdHostAPBusy; /* 628 4 */
unsigned char * pbyMgmtPacketPool; /* 632 4 */
unsigned char byMgmtPacketPool[2352]; /* 636 2352 */
/* --- cacheline 46 boundary (2944 bytes) was 44 bytes ago --- */
struct timer_list sTimerSecondCallback; /* 2988 52 */
/* --- cacheline 47 boundary (3008 bytes) was 32 bytes ago --- */
SRxMgmtPacket sRxPacket; /* 3040 28 */
KnownBSS sBSSList[42]; /* 3068 57288 */
/* --- cacheline 943 boundary (60352 bytes) was 4 bytes ago --- */
KnownNodeDB sNodeDBTable[65]; /* 60356 20800 */
/* --- cacheline 1268 boundary (81152 bytes) was 4 bytes ago --- */
/* Bitfield combined with previous fields */
SPMKIDCache gsPMKIDCache; /* 0 356 */
bool bRoaming; /* 0 1 */
SAssocInfo sAssocInfo; /* 0 7064 */
bool b11hEnable; /* 0 1 */
bool bSwitchChannel; /* 0 1 */
unsigned char byNewChannel; /* 0 1 */
PWLAN_IE_MEASURE_REP pCurrMeasureEIDRep; /* 0 4 */
unsigned int uLengthOfRepEIDs; /* 0 4 */
unsigned char abyCurrentMSRReq[2352]; /* 0 2352 */
unsigned char abyCurrentMSRRep[2352]; /* 0 2352 */
unsigned char abyIECountry[2340]; /* 0 2340 */
unsigned char abyIBSSDFSOwner[6]; /* 0 6 */
unsigned char byIBSSDFSRecovery; /* 0 1 */
struct sk_buff skb; /* 0 192 */
/* XXX last struct has 4 bytes of padding */
/* --- cacheline 1497 boundary (95808 bytes) was 32 bytes ago --- */
/* size: 95840, cachelines: 1498, members: 81 */
/* sum members: 95813, holes: 13, sum holes: 27 */
/* padding: 30112 */
/* paddings: 1, sum paddings: 4 */
/* last cacheline: 32 bytes */
/* BRAIN FART ALERT! 95840 != 95813 + 27(holes), diff = 0 */
struct pmkid_candidate {
NDIS_802_11_MAC_ADDRESS BSSID; /* 0 6 */
long unsigned int Flags; /* 8 4 */
/* size: 12, cachelines: 1, members: 2 */
/* sum members: 10, holes: 1, sum holes: 2 */
/* last cacheline: 12 bytes */
Signed-off-by: Aya Mahfouz
drivers/staging/vt6655/wmgr.c | 5 +++--
drivers/staging/vt6655/wmgr.h | 2 +-
2 files changed, 4 insertions(+), 3 deletions(-)
diff --git a/drivers/staging/vt6655/wmgr.c b/drivers/staging/vt6655/wmgr.c
index c73c39d..a1bada1 100644
--- a/drivers/staging/vt6655/wmgr.c
+++ b/drivers/staging/vt6655/wmgr.c
@@ -1022,7 +1022,8 @@ s_vMgrRxAssocResponse(
memset(&wrqu, 0, sizeof(wrqu));
- memcpy(wrqu.ap_addr.sa_data, &pMgmt->abyCurrBSSID[0], ETH_ALEN);
+ ether_addr_copy(wrqu.ap_addr.sa_data,
+ &pMgmt->abyCurrBSSID[0]);
wrqu.ap_addr.sa_family = ARPHRD_ETHER;
wireless_send_event(pDevice->dev, SIOCGIWAP, &wrqu, NULL);
@@ -4419,7 +4420,7 @@ bAdd_PMKID_Candidate(
else
pCandidateList->Flags &= ~(NDIS_802_11_PMKID_CANDIDATE_PREAUTH_ENABLED);
- memcpy(pCandidateList->BSSID, pbyBSSID, ETH_ALEN);
+ ether_addr_copy(pCandidateList->BSSID, pbyBSSID);
pDevice->gsPMKIDCandidate.NumCandidates++;
pr_debug("NumCandidates:%d\n",
(int)pDevice->gsPMKIDCandidate.NumCandidates);
diff --git a/drivers/staging/vt6655/wmgr.h b/drivers/staging/vt6655/wmgr.h
index ce939b3..a00652b 100644
--- a/drivers/staging/vt6655/wmgr.h
+++ b/drivers/staging/vt6655/wmgr.h
@@ -204,10 +204,10 @@ typedef struct tagSMgmtObject {
// Current state vars
+ unsigned char abyCurrBSSID[WLAN_BSSID_LEN];
unsigned char abyCurrSuppRates[WLAN_IEHDR_LEN + WLAN_RATES_MAXLEN + 1];
unsigned char abyCurrExtSuppRates[WLAN_IEHDR_LEN + WLAN_RATES_MAXLEN + 1];
unsigned char abyCurrSSID[WLAN_IEHDR_LEN + WLAN_SSID_MAXLEN + 1];
- unsigned char abyCurrBSSID[WLAN_BSSID_LEN];
unsigned short wCurrCapInfo;
unsigned short wCurrAID;
unsigned short wCurrATIMWindow; |
else
