staging: vt6655: remove unneeded semicolon
Author: Teodora Baluta <teobaluta@gmail.com>
This patch deletes any unneeded semicolons in driver vt6655 as detected
by coccinelle.
Signed-off-by: Teodora Baluta
 drivers/staging/vt6655/bssdb.c |  2 +-
 drivers/staging/vt6655/card.c  |  2 +-
 drivers/staging/vt6655/dpc.c   |  6 +++---
 drivers/staging/vt6655/iwctl.c |  2 +-
 drivers/staging/vt6655/power.c |  2 +-
 drivers/staging/vt6655/rxtx.c  |  4 ++--
 drivers/staging/vt6655/wmgr.c  | 12 ++++++------
 7 files changed, 15 insertions(+), 15 deletions(-)
diff --git a/drivers/staging/vt6655/bssdb.c b/drivers/staging/vt6655/bssdb.c
index 3b39cb2..5995dc2 100644
--- a/drivers/staging/vt6655/bssdb.c
+++ b/drivers/staging/vt6655/bssdb.c
@@ -1221,7 +1221,7 @@ start:
 				bScheduleCommand((void *)pDevice, WLAN_CMD_BSSID_SCAN, NULL);
 				bScheduleCommand((void *)pDevice, WLAN_CMD_SSID, NULL);
 				pDevice->uAutoReConnectTime = 0;
 		if (pMgmt->eCurrState == WMAC_STATE_JOINTED) {
 			if (pDevice->bUpdateBBVGA)
diff --git a/drivers/staging/vt6655/card.c b/drivers/staging/vt6655/card.c
index e95ecca..db38ca0 100644
--- a/drivers/staging/vt6655/card.c
+++ b/drivers/staging/vt6655/card.c
@@ -2013,7 +2013,7 @@ QWORD CARDqGetTSFOffset(unsigned char byRxRate, QWORD qwTSF1, QWORD qwTSF2)
 		HIDWORD(qwTSFOffset) = HIDWORD(qwTSF1) - HIDWORD(qwTSF2) - 1;
 	} else {
 		HIDWORD(qwTSFOffset) = HIDWORD(qwTSF1) - HIDWORD(qwTSF2);
 	return qwTSFOffset;
diff --git a/drivers/staging/vt6655/dpc.c b/drivers/staging/vt6655/dpc.c
index c60f3e6..0a29c90 100644
--- a/drivers/staging/vt6655/dpc.c
+++ b/drivers/staging/vt6655/dpc.c
@@ -169,7 +169,7 @@ s_vProcessRxMACHeader(PSDevice pDevice, unsigned char *pbyRxBufferAddr,
 	} else {
 		cbHeaderSize += WLAN_HDR_ADDR3_LEN;
 	pbyRxBuffer = (unsigned char *)(pbyRxBufferAddr + cbHeaderSize);
 	if (ether_addr_equal(pbyRxBuffer, pDevice->abySNAP_Bridgetunnel)) {
@@ -263,7 +263,7 @@ s_vGetDASA(unsigned char *pbyRxBufferAddr, unsigned int *pcbHeaderSize,
 				psEthHeader->abySrcAddr[ii] = pMACHeader->abyAddr2[ii];
 	*pcbHeaderSize = cbHeaderSize;
@@ -592,7 +592,7 @@ device_receive_frame(
 		} else {
 			// Control Frame
 		return false;
 	} else {
 		if (pMgmt->eCurrMode == WMAC_MODE_ESS_AP) {
diff --git a/drivers/staging/vt6655/iwctl.c b/drivers/staging/vt6655/iwctl.c
index 4bff8aa..2db4bc8 100644
--- a/drivers/staging/vt6655/iwctl.c
+++ b/drivers/staging/vt6655/iwctl.c
@@ -1632,7 +1632,7 @@ int iwctl_giwsens(struct net_device *dev,
 		wrq->value = ldBm;
 	} else {
 		wrq->value = 0;
 	wrq->disabled = (wrq->value == 0);
 	wrq->fixed = 1;
diff --git a/drivers/staging/vt6655/power.c b/drivers/staging/vt6655/power.c
index 3da2838..4bd1ccb 100644
--- a/drivers/staging/vt6655/power.c
+++ b/drivers/staging/vt6655/power.c
@@ -260,7 +260,7 @@ PSvSendPSPOLL(
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "Send PS-Poll packet failed..\n");
 	} else {
 //        DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "Send PS-Poll packet success..\n");
 	return;
diff --git a/drivers/staging/vt6655/rxtx.c b/drivers/staging/vt6655/rxtx.c
index 182c53e..6affd6e 100644
--- a/drivers/staging/vt6655/rxtx.c
+++ b/drivers/staging/vt6655/rxtx.c
@@ -2212,7 +2212,7 @@ CMD_STATUS csMgmt_xmit(PSDevice pDevice, PSTxMgmtPacket pPacket) {
 	else {
 		bNeedACK = true;
 		pTxBufHead->wFIFOCtl |= FIFOCTL_NEEDACK;
 	if ((pMgmt->eCurrMode == WMAC_MODE_ESS_AP) ||
 	    (pMgmt->eCurrMode == WMAC_MODE_IBSS_STA)) {
@@ -2686,7 +2686,7 @@ vDMA0_tx_80211(PSDevice  pDevice, struct sk_buff *skb, unsigned char *pbMPDU, un
 		bNeedACK = true;
diff --git a/drivers/staging/vt6655/wmgr.c b/drivers/staging/vt6655/wmgr.c
index a1eff7e..5200a2a 100644
--- a/drivers/staging/vt6655/wmgr.c
+++ b/drivers/staging/vt6655/wmgr.c
@@ -1719,7 +1719,7 @@ s_vMgrRxDeauthentication(
 		/* else, ignore it.  TODO: IBSS authentication service
 		   would be implemented here */
 	return;
@@ -2092,10 +2092,10 @@ s_vMgrRxBeacon(
 					pMgmt->bInTIM = sFrame.pTIM->byVirtBitMap[uLocateByteIndex] & byTIMBitOn ? true : false;
 				} else {
 					pMgmt->bInTIM = false;
 			} else {
 			if (pMgmt->bInTIM ||
 			    (pMgmt->bMulticastTIM && (pMgmt->byDTIMCount == 0))) {
@@ -2671,7 +2671,7 @@ vMgrJoinBSSBegin(
 			DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "End of Join AP -- A/B/G Action\n");
 		} else {
 			pMgmt->eCurrState = WMAC_STATE_IDLE;
 	} else {
 		// ad-hoc mode BSS
@@ -2740,8 +2740,8 @@ vMgrJoinBSSBegin(
 			bMgrPrepareBeaconToSend((void *)pDevice, pMgmt);
 		} else {
 	return;
BtrLinux
Privacy Overview
