staging: vt6655: delete explicit comparison to bool
Author: Teodora Baluta <teobaluta@gmail.com>
This patch fixes the following type of coccinelle detected warnings for
driver vt6655:
WARNING: Comparison to bool
Signed-off-by: Teodora Baluta
 drivers/staging/vt6655/baseband.c    |   4 +-
 drivers/staging/vt6655/card.c        |   8 +--
 drivers/staging/vt6655/channel.c     |  16 ++---
 drivers/staging/vt6655/datarate.c    |   8 +--
 drivers/staging/vt6655/device_main.c |  60 +++++++++----------
 drivers/staging/vt6655/dpc.c         |  34 +++++------
 drivers/staging/vt6655/hostap.c      |  12 ++--
 drivers/staging/vt6655/key.c         |  44 +++++++-------
 drivers/staging/vt6655/mac.c         |   4 +-
 drivers/staging/vt6655/power.c       |   7 +--
 drivers/staging/vt6655/rf.c          |   2 +-
 drivers/staging/vt6655/vntwifi.c     |   6 +-
 drivers/staging/vt6655/wcmd.c        |  22 +++----
 drivers/staging/vt6655/wctl.c        |   6 +-
 drivers/staging/vt6655/wmgr.c        | 109 +++++++++++++++++------------------
 drivers/staging/vt6655/wpa.c         |   2 +-
 drivers/staging/vt6655/wpa2.c        |   4 +-
 drivers/staging/vt6655/wpactl.c      |  12 ++--
 18 files changed, 176 insertions(+), 184 deletions(-)
diff --git a/drivers/staging/vt6655/baseband.c b/drivers/staging/vt6655/baseband.c
index 959568a..fa14659 100644
--- a/drivers/staging/vt6655/baseband.c
+++ b/drivers/staging/vt6655/baseband.c
@@ -1865,7 +1865,7 @@ BBvCalculateParameter(
 		break;
 	case RATE_5M:
-		if (bCCK == false)
+		if (!bCCK)
 			cbBitCount++;
 		cbUsCount = (cbBitCount * 10) / 55;
 		cbTmp = (cbUsCount * 55) / 10;
@@ -1879,7 +1879,7 @@ BBvCalculateParameter(
 	case RATE_11M:
+		if (!bCCK)
 			cbBitCount++;
 		cbUsCount = cbBitCount / 11;
 		cbTmp = cbUsCount * 11;
diff --git a/drivers/staging/vt6655/card.c b/drivers/staging/vt6655/card.c
index fbf18e2..e95ecca 100644
--- a/drivers/staging/vt6655/card.c
+++ b/drivers/staging/vt6655/card.c
@@ -1053,7 +1053,7 @@ CARDbAdd_PMKID_Candidate(
 	for (ii = 0; ii < pDevice->gsPMKIDCandidate.NumCandidates; ii++) {
 		pCandidateList = &pDevice->gsPMKIDCandidate.CandidateList[ii];
 		if (!memcmp(pCandidateList->BSSID, pbyBSSID, ETH_ALEN)) {
-			if ((bRSNCapExist == true) && (wRSNCap & BIT0)) {
+			if (bRSNCapExist && (wRSNCap & BIT0)) {
 				pCandidateList->Flags |= NDIS_802_11_PMKID_CANDIDATE_PREAUTH_ENABLED;
 			} else {
 				pCandidateList->Flags &= ~(NDIS_802_11_PMKID_CANDIDATE_PREAUTH_ENABLED);
@@ -1064,7 +1064,7 @@ CARDbAdd_PMKID_Candidate(
 	// New Candidate
 	pCandidateList = &pDevice->gsPMKIDCandidate.CandidateList[pDevice->gsPMKIDCandidate.NumCandidates];
 	} else {
@@ -1190,7 +1190,7 @@ CARDbStartMeasure(
 	} while (pDevice->uNumOfMeasureEIDs != 0);
-	if (bExpired == false) {
+	if (!bExpired) {
 		MACvSelectPage1(pDevice->PortOffset);
 		VNSvOutPortD(pDevice->PortOffset + MAC_REG_MSRSTART, LODWORD(qwStartTSF));
 		VNSvOutPortD(pDevice->PortOffset + MAC_REG_MSRSTART + 4, HIDWORD(qwStartTSF));
@@ -1280,7 +1280,7 @@ CARDbSetQuiet(
 	PSDevice    pDevice = (PSDevice) pDeviceHandler;
 	unsigned int ii = 0;
-	if (bResetQuiet == true) {
+	if (bResetQuiet) {
 		MACvRegBitsOff(pDevice->PortOffset, MAC_REG_MSRCTL, (MSRCTL_QUIETTXCHK | MSRCTL_QUIETEN));
 		for (ii = 0; ii < MAX_QUIET_COUNT; ii++) {
 			pDevice->sQuiet[ii].bEnable = false;
diff --git a/drivers/staging/vt6655/channel.c b/drivers/staging/vt6655/channel.c
index ba9481f..3198a31 100644
--- a/drivers/staging/vt6655/channel.c
+++ b/drivers/staging/vt6655/channel.c
@@ -441,8 +441,8 @@ void init_channel_table(void *pDeviceHandler)
 		break;
-	if ((pDevice->dwDiagRefCount != 0) || (pDevice->b11hEnable == true)) {
-		if (bMultiBand == true) {
+	if ((pDevice->dwDiagRefCount != 0) || pDevice->b11hEnable) {
+		if (bMultiBand) {
 			for (ii = 0; ii < CARD_MAX_CHANNEL_TBL; ii++) {
 				sChannelTbl[ii + 1].bValid = true;
 				pDevice->abyRegPwr[ii + 1] = pDevice->abyOFDMDefaultPwr[ii + 1];
@@ -463,7 +463,7 @@ void init_channel_table(void *pDeviceHandler)
 	} else if (pDevice->byZoneType <= CCODE_MAX) {
+		if (bMultiBand) {
 				if (ChannelRuleTab[pDevice->byZoneType].bChannelIdxList[ii] != 0) {
@@ -531,7 +531,7 @@ bool set_channel(void *pDeviceHandler, unsigned int uConnectionChannel)
 		return bResult;
-	if (sChannelTbl[uConnectionChannel].bValid == false) {
+	if (!sChannelTbl[uConnectionChannel].bValid) {
 		return false;
@@ -557,7 +557,7 @@ bool set_channel(void *pDeviceHandler, unsigned int uConnectionChannel)
 	bResult &= RFbSelectChannel(pDevice->PortOffset, pDevice->byRFType, (unsigned char)uConnectionChannel);
 	// Init Synthesizer Table
-	if (pDevice->bEnablePSMode == true)
+	if (pDevice->bEnablePSMode)
 		RFvWriteWakeProgSyn(pDevice->PortOffset, pDevice->byRFType, uConnectionChannel);
 	//DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "CARDbSetMediaChannel: %d\n", (unsigned char)uConnectionChannel);
@@ -766,7 +766,7 @@ unsigned char auto_channel_select(void *pDeviceHandler, CARD_PHY_TYPE ePHYType)
 	if (ePHYType == PHY_TYPE_11A) {
 		for (ii = CB_MAX_CHANNEL_24G + 1; ii <= CB_MAX_CHANNEL; ii++) {
-			if (sChannelTbl[ii].bValid == true) {
+			if (sChannelTbl[ii].bValid) {
 				if (byOptionChannel == 0) {
 					byOptionChannel = (unsigned char) ii;
@@ -780,7 +780,7 @@ unsigned char auto_channel_select(void *pDeviceHandler, CARD_PHY_TYPE ePHYType)
 	} else {
 		byOptionChannel = 0;
 		for (ii = 1; ii <= CB_MAX_CHANNEL_24G; ii++) {
 				if (sChannelTbl[ii].byMAP == 0) {
 					aiWeight[ii] += 100;
 				} else if (sChannelTbl[ii].byMAP & 0x01) {
@@ -807,7 +807,7 @@ unsigned char auto_channel_select(void *pDeviceHandler, CARD_PHY_TYPE ePHYType)
-			if ((sChannelTbl[ii].bValid == true) &&
+			if (sChannelTbl[ii].bValid &&
 			    (aiWeight[ii] > aiWeight[byOptionChannel])) {
diff --git a/drivers/staging/vt6655/datarate.c b/drivers/staging/vt6655/datarate.c
index e7b6bc7..c9a89cd 100644
--- a/drivers/staging/vt6655/datarate.c
+++ b/drivers/staging/vt6655/datarate.c
@@ -218,8 +218,7 @@ RATEvParseMaxRate(
 	for (ii = 0; ii < uRateLen; ii++) {
 		byRate = (unsigned char)(pItemRates->abyRates[ii]);
-		if (WLAN_MGMT_IS_BASICRATE(byRate) &&
-		    (bUpdateBasicRate == true))  {
+		if (WLAN_MGMT_IS_BASICRATE(byRate) && bUpdateBasicRate)  {
 			// Add to basic rate set, update pDevice->byTopCCKBasicRate and pDevice->byTopOFDMBasicRate
 			CARDbAddBasicRate((void *)pDevice, wGetRateIdx(byRate));
 			DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "ParseMaxRate AddBasicRate: %d\n", wGetRateIdx(byRate));
@@ -329,7 +328,7 @@ RATEvTxRateFallBack(
 	for (ii = 0; ii < MAX_RATE; ii++) {
 		if (psNodeDBTable->wSuppRate & (0x0001<<ii)) {
-			if (bAutoRate[ii] == true) {
+			if (bAutoRate[ii]) {
 				wIdxUpRate = (unsigned short) ii;
 		} else {
@@ -354,8 +353,7 @@ RATEvTxRateFallBack(
 	wIdxDownRate = psNodeDBTable->wTxDataRate;
 	for (ii = psNodeDBTable->wTxDataRate; ii > 0;) {
 		ii--;
-		if ((dwThroughputTbl[ii] > dwThroughput) &&
-		    (bAutoRate[ii] == true)) {
+		if ((dwThroughputTbl[ii] > dwThroughput) && bAutoRate[ii]) {
 			dwThroughput = dwThroughputTbl[ii];
 			wIdxDownRate = (unsigned short) ii;
diff --git a/drivers/staging/vt6655/device_main.c b/drivers/staging/vt6655/device_main.c
index e93fdc8..68cbaee 100644
--- a/drivers/staging/vt6655/device_main.c
+++ b/drivers/staging/vt6655/device_main.c
@@ -561,7 +561,7 @@ static void device_init_registers(PSDevice pDevice, DEVICE_INIT_TYPE InitType)
 			pDevice->byTxAntennaMode = ANT_B;
 			pDevice->dwTxAntennaSel = 1;
 			pDevice->dwRxAntennaSel = 1;
-			if (pDevice->bTxRxAntInv == true)
+			if (pDevice->bTxRxAntInv)
 				pDevice->byRxAntennaMode = ANT_A;
 			else
 				pDevice->byRxAntennaMode = ANT_B;
@@ -578,13 +578,13 @@ static void device_init_registers(PSDevice pDevice, DEVICE_INIT_TYPE InitType)
 			pDevice->dwRxAntennaSel = 0;
 			if (byValue & EEP_ANTENNA_AUX) {
 				pDevice->byTxAntennaMode = ANT_A;
 				else
 			} else {
 				else
@@ -635,7 +635,7 @@ static void device_init_registers(PSDevice pDevice, DEVICE_INIT_TYPE InitType)
 		pDevice->byRFType &= RF_MASK;
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "pDevice->byRFType = %x\n", pDevice->byRFType);
-		if (pDevice->bZoneRegExist == false) {
+		if (!pDevice->bZoneRegExist) {
 			pDevice->byZoneType = pDevice->abyEEPROM[EEP_OFS_ZONETYPE];
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "pDevice->byZoneType = %x\n", pDevice->byZoneType);
@@ -742,7 +742,7 @@ static void device_init_registers(PSDevice pDevice, DEVICE_INIT_TYPE InitType)
 			if (!(pDevice->byGPIO & GPIO0_DATA)) { pDevice->bHWRadioOff = false; }
-		if ((pDevice->bRadioControlOff == true)) {
+		if (pDevice->bRadioControlOff) {
 			CARDbRadioPowerOff(pDevice);
 		} else  CARDbRadioPowerOn(pDevice);
 #else
@@ -751,7 +751,7 @@ static void device_init_registers(PSDevice pDevice, DEVICE_INIT_TYPE InitType)
 			pDevice->bHWRadioOff = true;
-	if ((pDevice->bHWRadioOff == true) || (pDevice->bRadioControlOff == true)) {
+	if (pDevice->bHWRadioOff || pDevice->bRadioControlOff) {
@@ -809,7 +809,7 @@ static bool device_release_WPADEV(PSDevice pDevice)
 	int ii = 0;
 	// wait_queue_head_t	Set_wait;
 	//send device close to wpa_supplicnat layer
-	if (pDevice->bWPADEVUp == true) {
+	if (pDevice->bWPADEVUp) {
 		wpahdr = (viawget_wpa_header *)pDevice->skb->data;
 		wpahdr->type = VIAWGET_DEVICECLOSE_MSG;
 		wpahdr->resp_ie_len = 0;
@@ -826,7 +826,7 @@ static bool device_release_WPADEV(PSDevice pDevice)
 		//wait release WPADEV
 		//    init_waitqueue_head(&Set_wait);
 		//    wait_event_timeout(Set_wait, ((pDevice->wpadev==NULL)&&(pDevice->skb == NULL)),5*HZ);    //1s wait
-		while ((pDevice->bWPADEVUp == true)) {
+		while (pDevice->bWPADEVUp) {
 			set_current_state(TASK_UNINTERRUPTIBLE);
 			schedule_timeout(HZ / 20);          //wait 50ms
 			ii++;
@@ -892,7 +892,7 @@ vt6655_probe(struct pci_dev *pcid, const struct pci_device_id *ent)
 #ifdef	DEBUG
 	printk("Before get pci_info memaddr is %x\n", pDevice->memaddr);
 #endif
-	if (device_get_pci_info(pDevice, pcid) == false) {
+	if (!device_get_pci_info(pDevice, pcid)) {
 		printk(KERN_ERR DEVICE_NAME ": Failed to find PCI device.\n");
 		device_free_info(pDevice);
 		return -ENODEV;
@@ -1633,7 +1633,7 @@ static int device_tx_srv(PSDevice pDevice, unsigned int uIdx) {
 			bFull = true;
 			DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO " AC0DMA is Full = %d\n", pDevice->iTDUsed[uIdx]);
-		if (netif_queue_stopped(pDevice->dev) && (bFull == false)) {
+		if (netif_queue_stopped(pDevice->dev) && !bFull) {
 			netif_wake_queue(pDevice->dev);
@@ -1798,7 +1798,7 @@ static int  device_open(struct net_device *dev) {
 	pDevice->byReAssocCount = 0;
 	pDevice->bWPADEVUp = false;
 	// Patch: if WEP key already set by iwconfig but device not yet open
-	if ((pDevice->bEncryptionEnable == true) && (pDevice->bTransmitKey == true)) {
+	if (pDevice->bEncryptionEnable && pDevice->bTransmitKey) {
 		KeybSetDefaultKey(&(pDevice->sKey),
 				  (unsigned long)(pDevice->byKeyIndex | (1 << 31)),
 				  pDevice->uKeyLength,
@@ -1895,7 +1895,7 @@ static int device_dma0_tx_80211(struct sk_buff *skb, struct net_device *dev) {
 		return 0;
-	if (pDevice->bStopTx0Pkt == true) {
+	if (pDevice->bStopTx0Pkt) {
 		dev_kfree_skb_irq(skb);
 		spin_unlock_irq(&pDevice->lock);
 		return 0;
@@ -1924,7 +1924,7 @@ bool device_dma0_xmit(PSDevice pDevice, struct sk_buff *skb, unsigned int uNodeI
 	SKeyItem        STempKey;
 //    unsigned char byKeyIndex = 0;
 		return false;
@@ -1993,14 +1993,14 @@ bool device_dma0_xmit(PSDevice pDevice, struct sk_buff *skb, unsigned int uNodeI
 	} else if (pDevice->eCurrentPHYType == PHY_TYPE_11A) {
 		byPktType = PK_TYPE_11A;
 	} else {
-		if (pDevice->bProtectMode == true) {
+		if (pDevice->bProtectMode) {
 			byPktType = PK_TYPE_11GB;
 		} else {
 			byPktType = PK_TYPE_11GA;
-	if (pDevice->bEncryptionEnable == true)
+	if (pDevice->bEncryptionEnable)
 		bNeedEncryption = true;
 	if (pDevice->bEnableHostWEP) {
@@ -2076,7 +2076,7 @@ static int  device_xmit(struct sk_buff *skb, struct net_device *dev) {
 	bool bNodeExist = false;
 	spin_lock_irq(&pDevice->lock);
-	if (pDevice->bLinkPass == false) {
+	if (!pDevice->bLinkPass) {
 		return 0;
@@ -2130,7 +2130,7 @@ static int  device_xmit(struct sk_buff *skb, struct net_device *dev) {
-		if (bNodeExist == false) {
+		if (!bNodeExist) {
 			DBG_PRT(MSG_LEVEL_DEBUG, KERN_DEBUG "Unknown STA not found in node DB \n");
@@ -2149,7 +2149,7 @@ static int  device_xmit(struct sk_buff *skb, struct net_device *dev) {
 		cbFrameBodySize += 8;
-	if (pDevice->bEncryptionEnable == true) {
+	if (pDevice->bEncryptionEnable) {
 		// get Transmit key
 		do {
@@ -2196,7 +2196,7 @@ static int  device_xmit(struct sk_buff *skb, struct net_device *dev) {
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_DEBUG "acdma0: STA index %d\n", uNodeIndex);
 			pTransmitKey = &STempKey;
 			pTransmitKey->byCipherSuite = pMgmt->sNodeDBTable[uNodeIndex].byCipherSuite;
 			pTransmitKey->dwKeyIndex = pMgmt->sNodeDBTable[uNodeIndex].dwKeyIndex;
@@ -2286,7 +2286,7 @@ static int  device_xmit(struct sk_buff *skb, struct net_device *dev) {
 	} else {
 		} else {
@@ -2297,7 +2297,7 @@ static int  device_xmit(struct sk_buff *skb, struct net_device *dev) {
 //	printk("FIX RATE:CurrentRate is %d");
 //#endif
-	if (bNeedEncryption == true) {
+	if (bNeedEncryption) {
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "ntohs Pkt Type=%04x\n", ntohs(pDevice->sTxEthHeader.wType));
 		if ((pDevice->sTxEthHeader.wType) == TYPE_PKT_802_1x) {
 			bNeedEncryption = false;
@@ -2306,7 +2306,7 @@ static int  device_xmit(struct sk_buff *skb, struct net_device *dev) {
 				if (pTransmitKey == NULL) {
 					DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "Don't Find TX KEY\n");
 				} else {
-					if (bTKIP_UseGTK == true) {
+					if (bTKIP_UseGTK) {
 						DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "error: KEY is GTK!!~~\n");
 					} else {
 						DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "Find PTK [%lX]\n", pTransmitKey->dwKeyIndex);
@@ -2493,7 +2493,7 @@ static  irqreturn_t  device_intr(int irq,  void *dev_instance) {
 				MACvSelectPage0(pDevice->PortOffset);
 				//xxxx
 				// WCMDbFlushCommandQueue(pDevice->pMgmt, true);
-				if (set_channel(pDevice, pDevice->pCurrMeasureEID->sReq.byChannel) == true) {
+				if (set_channel(pDevice, pDevice->pCurrMeasureEID->sReq.byChannel)) {
 					pDevice->bMeasureInProgress = true;
 					MACvRegBitsOn(pDevice->PortOffset, MAC_REG_MSRCTL, MSRCTL_READY);
@@ -2544,12 +2544,12 @@ static  irqreturn_t  device_intr(int irq,  void *dev_instance) {
 			if (pDevice->dwIsr & ISR_QUIETSTART) {
 				do {
-				} while (CARDbStartQuiet(pDevice) == false);
+				} while (!CARDbStartQuiet(pDevice));
 		if (pDevice->dwIsr & ISR_TBTT) {
-			if (pDevice->bEnableFirstQuiet == true) {
+			if (pDevice->bEnableFirstQuiet) {
 				pDevice->byQuietStartCount--;
 				if (pDevice->byQuietStartCount == 0) {
 					pDevice->bEnableFirstQuiet = false;
@@ -2558,7 +2558,7 @@ static  irqreturn_t  device_intr(int irq,  void *dev_instance) {
-			if ((pDevice->bChannelSwitch == true) &&
+			if (pDevice->bChannelSwitch &&
 			    (pDevice->eOPMode == OP_MODE_INFRASTRUCTURE)) {
 				pDevice->byChannelSwitchCount--;
 				if (pDevice->byChannelSwitchCount == 0) {
@@ -2575,7 +2575,7 @@ static  irqreturn_t  device_intr(int irq,  void *dev_instance) {
 			if (pDevice->eOPMode == OP_MODE_ADHOC) {
 				//pDevice->bBeaconSent = false;
 			} else {
-				if ((pDevice->bUpdateBBVGA) && (pDevice->bLinkPass == true) && (pDevice->uCurrRSSI != 0)) {
+				if ((pDevice->bUpdateBBVGA) && pDevice->bLinkPass && (pDevice->uCurrRSSI != 0)) {
 					long            ldBm;
 					RFvRSSITodBm(pDevice, (unsigned char) pDevice->uCurrRSSI, &ldBm);
@@ -2642,7 +2642,7 @@ static  irqreturn_t  device_intr(int irq,  void *dev_instance) {
 			pDevice->bBeaconSent = true;
-			if (pDevice->bChannelSwitch == true) {
+			if (pDevice->bChannelSwitch) {
 					pDevice->bChannelSwitch = false;
@@ -3237,7 +3237,7 @@ static int  device_ioctl(struct net_device *dev, struct ifreq *rq, int cmd) {
 			netif_stop_queue(pDevice->dev);
 #ifdef WPA_SUPPLICANT_DRIVER_WEXT_SUPPORT
 			pMgmt->eScanType = WMAC_SCAN_ACTIVE;
-			if (pDevice->bWPASuppWextEnabled != true)
+			if (!pDevice->bWPASuppWextEnabled)
 #endif
 				bScheduleCommand((void *)pDevice, WLAN_CMD_BSSID_SCAN, pMgmt->abyDesireSSID);
 			bScheduleCommand((void *)pDevice, WLAN_CMD_SSID, NULL);
@@ -3373,7 +3373,7 @@ viawget_resume(struct pci_dev *pcid)
 		MACvRestoreContext(pDevice->PortOffset, pDevice->abyMacContext);
 		device_init_registers(pDevice, DEVICE_INIT_DXPL);
-		if (pMgmt->sNodeDBTable[0].bActive == true) { // Assoc with BSS
+		if (pMgmt->sNodeDBTable[0].bActive) { // Assoc with BSS
 			pMgmt->sNodeDBTable[0].bActive = false;
 			pDevice->bLinkPass = false;
 			if (pMgmt->eCurrMode == WMAC_MODE_IBSS_STA) {
diff --git a/drivers/staging/vt6655/dpc.c b/drivers/staging/vt6655/dpc.c
index 0ff51cb..c60f3e6 100644
--- a/drivers/staging/vt6655/dpc.c
+++ b/drivers/staging/vt6655/dpc.c
@@ -379,7 +379,7 @@ device_receive_frame(
 	pMACHeader = (PS802_11Header)((unsigned char *)(skb->data) + 8);
 //PLICE_DEBUG<-
-	if (pDevice->bMeasureInProgress == true) {
+	if (pDevice->bMeasureInProgress) {
 		if ((*pbyRsr & RSR_CRCOK) != 0) {
 			pDevice->byBasicMap |= 0x01;
@@ -436,7 +436,7 @@ device_receive_frame(
 	if (pMgmt->eCurrMode == WMAC_MODE_ESS_AP) {
-		if (s_bAPModeRxCtl(pDevice, pbyFrame, iSANodeIndex) == true) {
+		if (s_bAPModeRxCtl(pDevice, pbyFrame, iSANodeIndex)) {
 			return false;
@@ -608,8 +608,7 @@ device_receive_frame(
 		} else {
 			// discard DATA packet while not associate || BSSID error
-			if ((pDevice->bLinkPass == false) ||
-			    !(*pbyRsr & RSR_BSSIDOK)) {
+			if (!pDevice->bLinkPass || !(*pbyRsr & RSR_BSSIDOK)) {
 				if (bDeFragRx) {
 					if (!device_alloc_frag_buf(pDevice, &pDevice->sRxDFCB[pDevice->uCurrentDFCBIdx])) {
 						DBG_PRT(MSG_LEVEL_ERR, KERN_ERR "%s: can not alloc more frag bufs\n",
@@ -658,7 +657,7 @@ device_receive_frame(
 	// Now it only supports 802.11g Infrastructure Mode, and support rate must up to 54 Mbps
 	if (pDevice->bDiversityEnable && (FrameSize > 50) &&
 	    (pDevice->eOPMode == OP_MODE_INFRASTRUCTURE) &&
-	    (pDevice->bLinkPass == true)) {
+	    pDevice->bLinkPass) {
 		BBvAntennaDiversity(pDevice, s_byGetRateIdx(*pbyRxRate), 0);
@@ -683,7 +682,7 @@ device_receive_frame(
-	if ((pMgmt->eCurrMode == WMAC_MODE_ESS_AP) && (pDevice->bEnable8021x == true)) {
+	if ((pMgmt->eCurrMode == WMAC_MODE_ESS_AP) && pDevice->bEnable8021x) {
 		unsigned char abyMacHdr[24];
 		// Only 802.1x packet incoming allowed
@@ -698,7 +697,7 @@ device_receive_frame(
 		if (wEtherType == ETH_P_PAE) {
 			skb->dev = pDevice->apdev;
-			if (bIsWEP == true) {
+			if (bIsWEP) {
 				// strip IV header(8)
 				memcpy(&abyMacHdr[0], (skb->data + 4), 24);
 				memcpy((skb->data + 4 + cbIVOffset), &abyMacHdr[0], 24);
@@ -770,8 +769,9 @@ device_receive_frame(
 			//DBG_PRN_GRP12(("LocalL: %lx, LocalR: %lx\n", dwLocalMIC_L, dwLocalMIC_R));
 			//DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "dwMICKey0= %lx,dwMICKey1= %lx \n", dwMICKey0, dwMICKey1);
-			if ((cpu_to_le32(*pdwMIC_L) != dwLocalMIC_L) || (cpu_to_le32(*pdwMIC_R) != dwLocalMIC_R) ||
-			    (pDevice->bRxMICFail == true)) {
+			if ((cpu_to_le32(*pdwMIC_L) != dwLocalMIC_L) ||
+			    (cpu_to_le32(*pdwMIC_R) != dwLocalMIC_R) ||
+			    pDevice->bRxMICFail) {
 				DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "MIC comparison is fail!\n");
 				pDevice->bRxMICFail = false;
 				//pDevice->s802_11Counter.TKIPLocalMICFailures.QuadPart++;
@@ -894,13 +894,13 @@ device_receive_frame(
 		return false;
-		if (s_bAPModeRxData(pDevice,
+		if (!s_bAPModeRxData(pDevice,
 				    skb,
 				    FrameSize,
 				    cbHeaderOffset,
 				    iSANodeIndex,
 				    iDANodeIndex
-) == false) {
 			if (bDeFragRx) {
@@ -1123,7 +1123,7 @@ static bool s_bHandleRxEncryption(
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "pKey == NULL\n");
 		if (byDecMode == KEY_CTL_WEP) {
 //            pDevice->s802_11Counter.WEPUndecryptableCount.QuadPart++;
-		} else if (pDevice->bLinkPass == true) {
+		} else if (pDevice->bLinkPass) {
 //            pDevice->s802_11Counter.DecryptFailureCount.QuadPart++;
 		return false;
@@ -1131,7 +1131,7 @@ static bool s_bHandleRxEncryption(
 	if (byDecMode != pKey->byCipherSuite) {
 		*pKeyOut = NULL;
@@ -1234,7 +1234,7 @@ static bool s_bHostWepRxEncryption(
 		return false;
@@ -1245,7 +1245,7 @@ static bool s_bHostWepRxEncryption(
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "byDecMode == KEY_CTL_WEP \n");
 		if ((pDevice->byLocalID <= REV_ID_VT3253_A1) ||
 		    (((PSKeyTable)(pKey->pvKeyTable))->bSoftWEP == true) ||
-		    (bOnFly == false)) {
+		    !bOnFly) {
 			// Software WEP
 			// 1. 3253A
 			// 2. WEP 256
@@ -1277,7 +1277,7 @@ static bool s_bHostWepRxEncryption(
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "TSC0_15: %x\n", *pwRxTSC15_0);
 		if (byDecMode == KEY_CTL_TKIP) {
-			if ((pDevice->byLocalID <= REV_ID_VT3253_A1) || (bOnFly == false)) {
+			if ((pDevice->byLocalID <= REV_ID_VT3253_A1) || !bOnFly) {
 				// Software TKIP
 				// 1. 3253 A
 				// 2. NotOnFly
@@ -1297,7 +1297,7 @@ static bool s_bHostWepRxEncryption(
 		if (byDecMode == KEY_CTL_CCMP) {
-			if (bOnFly == false) {
+			if (!bOnFly) {
 				// Software CCMP
 				// NotOnFly
 				DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "soft KEY_CTL_CCMP\n");
diff --git a/drivers/staging/vt6655/hostap.c b/drivers/staging/vt6655/hostap.c
index aab0012..3d30a43 100644
--- a/drivers/staging/vt6655/hostap.c
+++ b/drivers/staging/vt6655/hostap.c
@@ -494,11 +494,11 @@ static int hostap_set_encryption(PSDevice pDevice,
 	DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO " hostap_set_encryption: alg %d \n", param->u.crypt.alg);
 	if (param->u.crypt.alg == WPA_ALG_NONE) {
-		if (pMgmt->sNodeDBTable[iNodeIndex].bOnFly == true) {
-			if (KeybRemoveKey(&(pDevice->sKey),
+		if (pMgmt->sNodeDBTable[iNodeIndex].bOnFly) {
+			if (!KeybRemoveKey(&(pDevice->sKey),
 					  param->sta_addr,
 					  pMgmt->sNodeDBTable[iNodeIndex].dwKeyIndex,
-					  pDevice->PortOffset) == false) {
+					  pDevice->PortOffset)) {
 				DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "KeybRemoveKey fail \n");
 			pMgmt->sNodeDBTable[iNodeIndex].bOnFly = false;
@@ -556,7 +556,7 @@ static int hostap_set_encryption(PSDevice pDevice,
 				       (unsigned char *)abyKey,
 				       KEY_CTL_WEP,
-				       pDevice->byLocalID) == true) {
+				       pDevice->byLocalID)) {
 				pMgmt->sNodeDBTable[iNodeIndex].bOnFly = true;
 			} else {
@@ -623,7 +623,7 @@ static int hostap_set_encryption(PSDevice pDevice,
 			       byKeyDecMode,
 		} else {
@@ -635,7 +635,7 @@ static int hostap_set_encryption(PSDevice pDevice,
-	if (bKeyTableFull == true) {
+	if (bKeyTableFull) {
 		wKeyCtl &= 0x7F00;              // clear all key control filed
 		wKeyCtl |= (byKeyDecMode << 4);
 		wKeyCtl |= (byKeyDecMode);
diff --git a/drivers/staging/vt6655/key.c b/drivers/staging/vt6655/key.c
index 04c1304..eab3b41 100644
--- a/drivers/staging/vt6655/key.c
+++ b/drivers/staging/vt6655/key.c
@@ -64,13 +64,12 @@ s_vCheckKeyTableValid(PSKeyManagement pTable, unsigned long dwIoBase)
 	int i;
 	for (i = 0; i < MAX_KEY_TABLE; i++) {
-		if ((pTable->KeyTable[i].bInUse == true) &&
-		    (pTable->KeyTable[i].PairwiseKey.bKeyValid == false) &&
-		    (pTable->KeyTable[i].GroupKey[0].bKeyValid == false) &&
-		    (pTable->KeyTable[i].GroupKey[1].bKeyValid == false) &&
-		    (pTable->KeyTable[i].GroupKey[2].bKeyValid == false) &&
-		    (pTable->KeyTable[i].GroupKey[3].bKeyValid == false)
+		if (pTable->KeyTable[i].bInUse &&
+		    !pTable->KeyTable[i].PairwiseKey.bKeyValid &&
+		    !pTable->KeyTable[i].GroupKey[0].bKeyValid &&
+		    !pTable->KeyTable[i].GroupKey[1].bKeyValid &&
+		    !pTable->KeyTable[i].GroupKey[2].bKeyValid &&
+		    !pTable->KeyTable[i].GroupKey[3].bKeyValid) {
 			pTable->KeyTable[i].bInUse = false;
 			pTable->KeyTable[i].wKeyCtl = 0;
 			pTable->KeyTable[i].bSoftWEP = false;
@@ -140,17 +139,17 @@ bool KeybGetKey(
 	*pKey = NULL;
 		    ether_addr_equal(pTable->KeyTable[i].abyBSSID, pbyBSSID)) {
 			if (dwKeyIndex == 0xFFFFFFFF) {
-				if (pTable->KeyTable[i].PairwiseKey.bKeyValid == true) {
+				if (pTable->KeyTable[i].PairwiseKey.bKeyValid) {
 					*pKey = &(pTable->KeyTable[i].PairwiseKey);
 					return true;
 				} else {
 					return false;
 			} else if (dwKeyIndex < MAX_GROUP_KEY) {
-				if (pTable->KeyTable[i].GroupKey[dwKeyIndex].bKeyValid == true) {
+				if (pTable->KeyTable[i].GroupKey[dwKeyIndex].bKeyValid) {
 					*pKey = &(pTable->KeyTable[i].GroupKey[dwKeyIndex]);
 					return true;
 				} else {
@@ -202,12 +201,11 @@ bool KeybSetKey(
 	j = (MAX_KEY_TABLE-1);
 	for (i = 0; i < (MAX_KEY_TABLE - 1); i++) {
-		if ((pTable->KeyTable[i].bInUse == false) &&
-		    (j == (MAX_KEY_TABLE-1))) {
+		if (!pTable->KeyTable[i].bInUse && (j == (MAX_KEY_TABLE-1))) {
 			// found empty table
 			j = i;
 			// found table already exist
 			if ((dwKeyIndex & PAIRWISE_KEY) != 0) {
@@ -384,7 +382,7 @@ bool KeybRemoveKey(
 				pTable->KeyTable[i].PairwiseKey.bKeyValid = false;
@@ -428,7 +426,7 @@ bool KeybRemoveAllKey(
 	int i, u;
 			for (u = 0; u < MAX_GROUP_KEY; u++) {
@@ -461,7 +459,7 @@ void KeyvRemoveWEPKey(
 	if ((dwKeyIndex & 0x000000FF) < MAX_GROUP_KEY) {
-		if (pTable->KeyTable[MAX_KEY_TABLE-1].bInUse == true) {
+		if (pTable->KeyTable[MAX_KEY_TABLE-1].bInUse) {
 			if (pTable->KeyTable[MAX_KEY_TABLE-1].GroupKey[dwKeyIndex & 0x000000FF].byCipherSuite == KEY_CTL_WEP) {
 				pTable->KeyTable[MAX_KEY_TABLE-1].GroupKey[dwKeyIndex & 0x000000FF].bKeyValid = false;
 				if ((dwKeyIndex & 0x7FFFFFFF) == (pTable->KeyTable[MAX_KEY_TABLE-1].dwGTKeyIndex & 0x7FFFFFFF)) {
@@ -511,10 +509,10 @@ bool KeybGetTransmitKey(
 	*pKey = NULL;
 			if (dwKeyType == PAIRWISE_KEY) {
 					DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "KeybGetTransmitKey:");
@@ -535,7 +533,7 @@ bool KeybGetTransmitKey(
 					DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "ERROR: dwGTKeyIndex == 0 !!!\n");
 					return false;
-				if (pTable->KeyTable[i].GroupKey[(pTable->KeyTable[i].dwGTKeyIndex&0x000000FF)].bKeyValid == true) {
+				if (pTable->KeyTable[i].GroupKey[(pTable->KeyTable[i].dwGTKeyIndex&0x000000FF)].bKeyValid) {
 					*pKey = &(pTable->KeyTable[i].GroupKey[(pTable->KeyTable[i].dwGTKeyIndex&0x000000FF)]);
@@ -583,8 +581,8 @@ bool KeybCheckPairewiseKey(
 	*pKey = NULL;
-		    (pTable->KeyTable[i].PairwiseKey.bKeyValid == true)) {
+		    pTable->KeyTable[i].PairwiseKey.bKeyValid) {
 			return true;
@@ -657,7 +655,7 @@ bool KeybSetDefaultKey(
 		pTable->KeyTable[MAX_KEY_TABLE-1].wKeyCtl |= 0x4000;              // disable on-fly disable address match
 		pTable->KeyTable[MAX_KEY_TABLE-1].bSoftWEP = true;
 	} else {
-		if (pTable->KeyTable[MAX_KEY_TABLE-1].bSoftWEP == false)
+		if (!pTable->KeyTable[MAX_KEY_TABLE-1].bSoftWEP)
 			pTable->KeyTable[MAX_KEY_TABLE-1].wKeyCtl |= 0xC000;          // enable on-fly disable address match
@@ -740,7 +738,7 @@ bool KeybSetAllGroupKey(
 	for (i = 0; i < MAX_KEY_TABLE - 1; i++) {
-		if (pTable->KeyTable[i].bInUse == true) {
+		if (pTable->KeyTable[i].bInUse) {
 			// Group key
 			pKey = &(pTable->KeyTable[i].GroupKey[dwKeyIndex & 0x000000FF]);
diff --git a/drivers/staging/vt6655/mac.c b/drivers/staging/vt6655/mac.c
index 001d15c..21bd8a1 100644
--- a/drivers/staging/vt6655/mac.c
+++ b/drivers/staging/vt6655/mac.c
@@ -957,13 +957,13 @@ bool MACbSafeStop(unsigned long dwIoBase)
 	MACvRegBitsOff(dwIoBase, MAC_REG_TCR, TCR_AUTOBCNTX);
-	if (MACbSafeRxOff(dwIoBase) == false) {
+	if (!MACbSafeRxOff(dwIoBase)) {
 		DBG_PORT80(0xA1);
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO " MACbSafeRxOff == false)\n");
 		MACbSafeSoftwareReset(dwIoBase);
 		return false;
-	if (MACbSafeTxOff(dwIoBase) == false) {
+	if (!MACbSafeTxOff(dwIoBase)) {
 		DBG_PORT80(0xA2);
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO " MACbSafeTxOff == false)\n");
diff --git a/drivers/staging/vt6655/power.c b/drivers/staging/vt6655/power.c
index 2340d2f..3da2838 100644
--- a/drivers/staging/vt6655/power.c
+++ b/drivers/staging/vt6655/power.c
@@ -284,16 +284,15 @@ PSbSendNullPacket(
 	PSMgmtObject        pMgmt = pDevice->pMgmt;
 	unsigned int uIdx;
 		return false;
 #ifdef TxInSleep
-	if ((pDevice->bEnablePSMode == false) &&
-	    (pDevice->fTxDataInSleep == false)) {
+	if (!pDevice->bEnablePSMode && !pDevice->fTxDataInSleep) {
 		return false;
 #else
-	if (pDevice->bEnablePSMode == false) {
+	if (!pDevice->bEnablePSMode) {
 		return false;
 #endif
diff --git a/drivers/staging/vt6655/rf.c b/drivers/staging/vt6655/rf.c
index ce173cc..edb1b27 100644
--- a/drivers/staging/vt6655/rf.c
+++ b/drivers/staging/vt6655/rf.c
@@ -976,7 +976,7 @@ bool RFbSetPower(
 	bResult = RFbRawSetPower(pDevice, byPwr, uRATE);
-	if (bResult == true) {
+	if (bResult) {
 		pDevice->byCurPwr = byPwr;
 	return bResult;
diff --git a/drivers/staging/vt6655/vntwifi.c b/drivers/staging/vt6655/vntwifi.c
index d2bdb71..e78aedf 100644
--- a/drivers/staging/vt6655/vntwifi.c
+++ b/drivers/staging/vt6655/vntwifi.c
@@ -494,7 +494,7 @@ VNTWIFIvUpdateNodeTxCounter(
 	pMgmt->sNodeDBTable[uNodeIndex].uTxAttempts++;
-	if (bTxOk == true) {
+	if (bTxOk) {
 		// transmit success, TxAttempts at least plus one
 		pMgmt->sNodeDBTable[uNodeIndex].uTxOk[MAX_RATE]++;
 		pMgmt->sNodeDBTable[uNodeIndex].uTxOk[wRate]++;
@@ -584,7 +584,7 @@ VNTWIFIbyGetKeyCypher(
 	PSMgmtObject    pMgmt = (PSMgmtObject)pMgmtHandle;
-	if (bGroupKey == true) {
+	if (bGroupKey) {
 		return pMgmt->byCSSGK;
 	} else {
 		return pMgmt->byCSSPK;
@@ -731,7 +731,7 @@ VNTWIFIbMeasureReport(
 		pMgmt->uLengthOfRepEIDs += (2 + pMgmt->pCurrMeasureEIDRep->len);
 		pMgmt->pCurrMeasureEIDRep = (PWLAN_IE_MEASURE_REP) pbyCurrentEID;
-	if (bEndOfReport == true) {
+	if (bEndOfReport) {
 		IEEE11hbMSRRepTx(pMgmt);
 	//spin_unlock_irq(&pDevice->lock);
diff --git a/drivers/staging/vt6655/wcmd.c b/drivers/staging/vt6655/wcmd.c
index 9c57eef..72caaa2 100644
--- a/drivers/staging/vt6655/wcmd.c
+++ b/drivers/staging/vt6655/wcmd.c
@@ -317,7 +317,7 @@ vCommandTimer(
 	if (pDevice->dwDiagRefCount != 0)
 		return;
-	if (pDevice->bCmdRunning != true)
+	if (!pDevice->bCmdRunning)
 		return;
@@ -326,7 +326,7 @@ vCommandTimer(
 	case WLAN_CMD_SCAN_START:
-		if (pDevice->bRadioOff == true) {
+		if (pDevice->bRadioOff) {
 			s_bCommandComplete(pDevice);
 			return;
@@ -393,7 +393,7 @@ vCommandTimer(
 			vAdHocBeaconStop(pDevice);
-			if (set_channel(pMgmt->pAdapter, pMgmt->uScanChannel) == true) {
+			if (set_channel(pMgmt->pAdapter, pMgmt->uScanChannel)) {
 				DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "SCAN Channel: %d\n", pMgmt->uScanChannel);
 			} else {
 				DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "SET SCAN Channel Fail: %d\n", pMgmt->uScanChannel);
@@ -408,7 +408,7 @@ vCommandTimer(
-			if ((pMgmt->b11hEnable == false) ||
+			if (!pMgmt->b11hEnable ||
 			    (pMgmt->uScanChannel < CB_MAX_CHANNEL_24G)) {
 				s_vProbeChannel(pDevice);
@@ -498,7 +498,7 @@ vCommandTimer(
 	case WLAN_CMD_SSID_START:
 			return;
@@ -659,7 +659,7 @@ vCommandTimer(
 #ifdef TxInSleep
-			if (pDevice->IsTxDataTrigger != false)   {    //TxDataTimer is not triggered at the first time
+			if (pDevice->IsTxDataTrigger) {    //TxDataTimer is not triggered at the first time
 				del_timer(&pDevice->sTimerTxData);
 				init_timer(&pDevice->sTimerTxData);
 				pDevice->sTimerTxData.data = (unsigned long) pDevice;
@@ -694,7 +694,7 @@ vCommandTimer(
 			pMgmt->eCurrState = WMAC_STATE_IDLE;
 			pMgmt->eCurrMode = WMAC_MODE_STANDBY;
-			if (pDevice->bEnableHostWEP == true)
+			if (pDevice->bEnableHostWEP)
 				BSSvClearNodeDBTable(pDevice, 1);
 			else
 				BSSvClearNodeDBTable(pDevice, 0);
@@ -776,7 +776,7 @@ vCommandTimer(
 	case WLAN_CMD_RADIO_START:
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "eCommandState == WLAN_CMD_RADIO_START\n");
-		if (pDevice->bRadioCmd == true)
+		if (pDevice->bRadioCmd)
 		else
@@ -948,7 +948,7 @@ bool bScheduleCommand(
 	ADD_ONE_WITH_WRAP_AROUND(pDevice->uCmdEnqueueIdx, CMD_Q_SIZE);
 	pDevice->cbFreeCmdQueue--;
-	if (pDevice->bCmdRunning == false) {
+	if (!pDevice->bCmdRunning) {
 	} else {
@@ -1031,8 +1031,8 @@ BSSvSecondTxData(
 #if 1
-	if (((pDevice->bLinkPass == true) && (pMgmt->eAuthenMode < WMAC_AUTH_WPA)) ||  //open && sharekey linking
-	   (pDevice->fWPA_Authened == true)) {   //wpa linking
+	if ((pDevice->bLinkPass && (pMgmt->eAuthenMode < WMAC_AUTH_WPA)) ||  //open && sharekey linking
+	    pDevice->fWPA_Authened) {   //wpa linking
 #else
 #endif
diff --git a/drivers/staging/vt6655/wctl.c b/drivers/staging/vt6655/wctl.c
index f05f9f5..950039f 100644
--- a/drivers/staging/vt6655/wctl.c
+++ b/drivers/staging/vt6655/wctl.c
@@ -110,7 +110,7 @@ unsigned int WCTLuSearchDFCB(PSDevice pDevice, PS802_11Header pMACHeader)
 	unsigned int ii;
 	for (ii = 0; ii < pDevice->cbDFCB; ii++) {
-		if ((pDevice->sRxDFCB[ii].bInUse == true) &&
+		if (pDevice->sRxDFCB[ii].bInUse &&
 		    ether_addr_equal(pDevice->sRxDFCB[ii].abyAddr2,
 				     pMACHeader->abyAddr2)) {
@@ -141,7 +141,7 @@ unsigned int WCTLuInsertDFCB(PSDevice pDevice, PS802_11Header pMACHeader)
 	if (pDevice->cbFreeDFCB == 0)
 		return pDevice->cbDFCB;
-		if (pDevice->sRxDFCB[ii].bInUse == false) {
+		if (!pDevice->sRxDFCB[ii].bInUse) {
 			pDevice->cbFreeDFCB--;
 			pDevice->sRxDFCB[ii].uLifetime = pDevice->dwMaxReceiveLifetime;
 			pDevice->sRxDFCB[ii].bInUse = true;
@@ -174,7 +174,7 @@ bool WCTLbHandleFragment(PSDevice pDevice, PS802_11Header pMACHeader, unsigned i
 	unsigned int uHeaderSize;
-	if (bWEP == true) {
+	if (bWEP) {
 		uHeaderSize = 28;
 		if (bExtIV)
 			// ExtIV
diff --git a/drivers/staging/vt6655/wmgr.c b/drivers/staging/vt6655/wmgr.c
index ed4b32b..40bb900 100644
--- a/drivers/staging/vt6655/wmgr.c
+++ b/drivers/staging/vt6655/wmgr.c
@@ -468,15 +468,15 @@ vMgrAssocBeginSta(
 	// ERP Phy (802.11g) should support short preamble.
 	if (pMgmt->eCurrentPHYMode == PHY_TYPE_11G) {
 		pMgmt->wCurrCapInfo |= WLAN_SET_CAP_INFO_SHORTPREAMBLE(1);
-		if (CARDbIsShorSlotTime(pMgmt->pAdapter) == true) {
+		if (CARDbIsShorSlotTime(pMgmt->pAdapter)) {
 			pMgmt->wCurrCapInfo |= WLAN_SET_CAP_INFO_SHORTSLOTTIME(1);
 	} else if (pMgmt->eCurrentPHYMode == PHY_TYPE_11B) {
-		if (CARDbIsShortPreamble(pMgmt->pAdapter) == true) {
+		if (CARDbIsShortPreamble(pMgmt->pAdapter)) {
-	if (pMgmt->b11hEnable == true)
+	if (pMgmt->b11hEnable)
 		pMgmt->wCurrCapInfo |= WLAN_SET_CAP_INFO_SPECTRUMMNG(1);
 	/* build an assocreq frame and send it */
@@ -539,15 +539,15 @@ vMgrReAssocBeginSta(
 	pTxPacket = s_MgrMakeReAssocRequest
@@ -736,7 +736,7 @@ s_vMgrRxAssocRequest(
 			pDevice->bProtectMode = true;
 			pDevice->bNonERPPresent = true;
-		if (pMgmt->sNodeDBTable[uNodeIndex].bShortPreamble == false) {
+		if (!pMgmt->sNodeDBTable[uNodeIndex].bShortPreamble) {
 			pDevice->bBarkerPreambleMd = true;
@@ -891,7 +891,7 @@ s_vMgrRxReAssocRequest(
@@ -1837,7 +1837,7 @@ s_vMgrRxBeacon(
 		bChannelHit = true;
 //2008-0730-01<Add>by MikeLiu
-	if (ChannelExceedZoneType(pDevice, byCurrChannel) == true)
+	if (ChannelExceedZoneType(pDevice, byCurrChannel))
 		return;
 	if (sFrame.pERP != NULL) {
@@ -1957,9 +1957,9 @@ s_vMgrRxBeacon(
-	if ((WLAN_GET_CAP_INFO_ESS(*sFrame.pwCapInfo) == true) &&
-	    (bIsBSSIDEqual == true) &&
-	    (bIsSSIDEqual == true) &&
+	if (WLAN_GET_CAP_INFO_ESS(*sFrame.pwCapInfo) &&
+	    bIsBSSIDEqual &&
+	    bIsSSIDEqual &&
 	    (pMgmt->eCurrMode == WMAC_MODE_ESS_STA) &&
 	    (pMgmt->eCurrState == WMAC_STATE_ASSOC)) {
 		// add state check to prevent reconnect fail since we'll receive Beacon
@@ -2001,7 +2001,7 @@ s_vMgrRxBeacon(
 					  &(pMgmt->sNodeDBTable[0].byTopCCKBasicRate),
 					  &(pMgmt->sNodeDBTable[0].byTopOFDMBasicRate)
-			if (bUpdatePhyParameter == true) {
+			if (bUpdatePhyParameter) {
 				CARDbSetPhyParameter(pMgmt->pAdapter,
 						     pMgmt->eCurrentPHYMode,
 						     pMgmt->wCurrCapInfo,
@@ -2023,7 +2023,7 @@ s_vMgrRxBeacon(
 						   sFrame.pIE_CHSW->byCount
-			} else if (bIsChannelEqual == false) {
+			} else if (!bIsChannelEqual) {
 				set_channel(pMgmt->pAdapter, pBSSList->uChannel);
@@ -2067,12 +2067,12 @@ s_vMgrRxBeacon(
 	// if infra mode
-	if (bIsAPBeacon == true) {
+	if (bIsAPBeacon) {
 		// Infra mode: Local TSF always follow AP's TSF if Difference huge.
 		if (bTSFLargeDiff)
 			bUpdateTSF = true;
-		if ((pDevice->bEnablePSMode == true) && (sFrame.pTIM != 0)) {
+		if (pDevice->bEnablePSMode && (sFrame.pTIM != 0)) {
 			// deal with DTIM, analysis TIM
 			pMgmt->bMulticastTIM = WLAN_MGMT_IS_MULTICAST_TIM(sFrame.pTIM->byBitMapCtl) ? true : false;
 			pMgmt->byDTIMCount = sFrame.pTIM->byDTIMCount;
@@ -2110,7 +2110,7 @@ s_vMgrRxBeacon(
 			} else {
 				pMgmt->bInTIMWake = false;
 				DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "BCN: Not In TIM..\n");
-				if (pDevice->bPWBitOn == false) {
+				if (!pDevice->bPWBitOn) {
 					DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "BCN: Send Null Packet\n");
 					if (PSbSendNullPacket(pDevice))
 						pDevice->bPWBitOn = true;
@@ -2480,7 +2480,7 @@ vMgrCreateOwnIBSS(
 		pMgmt->wCurrCapInfo &= (~WLAN_SET_CAP_INFO_SHORTPREAMBLE(1));
-	if ((pMgmt->b11hEnable == true) &&
+	if (pMgmt->b11hEnable &&
 	    (pMgmt->eCurrentPHYMode == PHY_TYPE_11A)) {
 	} else {
@@ -2530,7 +2530,7 @@ vMgrJoinBSSBegin(
 	unsigned char byTopOFDMBasicRate = RATE_1M;
 	for (ii = 0; ii < MAX_BSS_NUM; ii++) {
-		if (pMgmt->sBSSList[ii].bActive == true)
+		if (pMgmt->sBSSList[ii].bActive)
 			break;
@@ -2656,7 +2656,7 @@ vMgrJoinBSSBegin(
 			if (pMgmt->eAuthenMode == WMAC_AUTH_WPA2) {
 				bool bResult = bAdd_PMKID_Candidate((void *)pDevice, pMgmt->abyCurrBSSID, &pCurr->sRSNCapObj);
 				DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "bAdd_PMKID_Candidate: 1(%d)\n", bResult);
-				if (bResult == false) {
+				if (!bResult) {
 					vFlush_PMKID_Candidate((void *)pDevice);
 					DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "vFlush_PMKID_Candidate: 4\n");
@@ -2677,13 +2677,13 @@ vMgrJoinBSSBegin(
 		// ad-hoc mode BSS
 		if (pMgmt->eAuthenMode == WMAC_AUTH_WPANONE) {
 			if (pDevice->eEncryptionStatus == Ndis802_11Encryption2Enabled) {
-				if (WPA_SearchRSN(0, WPA_TKIP, pCurr) == false) {
+				if (!WPA_SearchRSN(0, WPA_TKIP, pCurr)) {
 					// encryption mode error
 					return;
 			} else if (pDevice->eEncryptionStatus == Ndis802_11Encryption3Enabled) {
-				if (WPA_SearchRSN(0, WPA_AESCCMP, pCurr) == false) {
+				if (!WPA_SearchRSN(0, WPA_AESCCMP, pCurr)) {
 					return;
@@ -2776,10 +2776,10 @@ s_vMgrSynchBSS(
 	*pStatus = CMD_STATUS_FAILURE;
-	if (s_bCipherMatch(pCurr,
+	if (!s_bCipherMatch(pCurr,
 			   pDevice->eEncryptionStatus,
 			   &(pMgmt->byCSSPK),
-			   &(pMgmt->byCSSGK)) == false) {
+			   &(pMgmt->byCSSGK))) {
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "s_bCipherMatch Fail .......\n");
 		return;
@@ -2869,18 +2869,17 @@ s_vMgrSynchBSS(
 		CARDbSetBSSID(pMgmt->pAdapter, pCurr->abyBSSID, OP_MODE_ADHOC);
-	if (CARDbSetPhyParameter(pMgmt->pAdapter,
+	if (!CARDbSetPhyParameter(pMgmt->pAdapter,
 				 ePhyType,
 				 pCurr->wCapInfo,
 				 pCurr->sERP.byERP,
 				 pMgmt->abyCurrSuppRates,
-				 pMgmt->abyCurrExtSuppRates
-		    ) != true) {
+				 pMgmt->abyCurrExtSuppRates)) {
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "<----s_bSynchBSS Set Phy Mode Fail [%d]\n", ePhyType);
 		return;
 	// set channel and clear NAV
-	if (set_channel(pMgmt->pAdapter, pCurr->uChannel) == false) {
+	if (!set_channel(pMgmt->pAdapter, pCurr->uChannel)) {
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "<----s_bSynchBSS Set Channel [%d]\n", pCurr->uChannel);
 		return;
@@ -2924,7 +2923,7 @@ static void  Encyption_Rebuild(
 	if ((pMgmt->eAuthenMode == WMAC_AUTH_WPAPSK) ||           //networkmanager 0.7.0 does not give the pairwise-key selection,
 	    (pMgmt->eAuthenMode == WMAC_AUTH_WPA2PSK)) {         // so we need re-select it according to real pairwise-key info.
-		if (pCurr->bWPAValid == true)  {   //WPA-PSK
+		if (pCurr->bWPAValid)  {   //WPA-PSK
 			pMgmt->eAuthenMode = WMAC_AUTH_WPAPSK;
 			if (pCurr->abyPKType[0] == WPA_TKIP) {
 				pDevice->eEncryptionStatus = Ndis802_11Encryption2Enabled;    //TKIP
@@ -2933,7 +2932,7 @@ static void  Encyption_Rebuild(
 				pDevice->eEncryptionStatus = Ndis802_11Encryption3Enabled;    //AES
 				PRINT_K("Encyption_Rebuild--->ssid reset config to [WPAPSK-AES]\n");
-		} else if (pCurr->bWPA2Valid == true) {  //WPA2-PSK
+		} else if (pCurr->bWPA2Valid) {  //WPA2-PSK
 			pMgmt->eAuthenMode = WMAC_AUTH_WPA2PSK;
 			if (pCurr->abyCSSPK[0] == WLAN_11i_CSS_TKIP) {
@@ -3150,8 +3149,7 @@ s_MgrMakeBeacon(
-	    (pMgmt->eCurrentPHYMode == PHY_TYPE_11A)) {
+	if (pMgmt->b11hEnable && (pMgmt->eCurrentPHYMode == PHY_TYPE_11A)) {
 		// Country IE
 		pbyBuffer = (unsigned char *)(sFrame.pBuf + sFrame.len);
 		set_country_IE(pMgmt->pAdapter, pbyBuffer);
@@ -3164,7 +3162,7 @@ s_MgrMakeBeacon(
 		((PWLAN_IE_PW_CONST) pbyBuffer)->byPower = 0;
 		pbyBuffer += (1) + WLAN_IEHDR_LEN;
 		uLength += (1) + WLAN_IEHDR_LEN;
-		if (pMgmt->bSwitchChannel == true) {
+		if (pMgmt->bSwitchChannel) {
 			// Channel Switch IE
 			((PWLAN_IE_CH_SW) pbyBuffer)->byElementID = WLAN_EID_CH_SWITCH;
 			((PWLAN_IE_CH_SW) pbyBuffer)->len = 3;
@@ -3193,7 +3191,7 @@ s_MgrMakeBeacon(
 			pbyBuffer += (7) + WLAN_IEHDR_LEN;
 			uLength += (7) + WLAN_IEHDR_LEN;
 			for (ii = CB_MAX_CHANNEL_24G+1; ii <= CB_MAX_CHANNEL; ii++) {
-				if (get_channel_map_info(pMgmt->pAdapter, ii, pbyBuffer, pbyBuffer+1) == true) {
+				if (get_channel_map_info(pMgmt->pAdapter, ii, pbyBuffer, pbyBuffer+1)) {
 					pbyBuffer += 2;
 					uLength += 2;
 					pIBSSDFS->len += 2;
@@ -3209,11 +3207,11 @@ s_MgrMakeBeacon(
 		sFrame.pERP->byElementID = WLAN_EID_ERP;
 		sFrame.pERP->len = 1;
 		sFrame.pERP->byContext = 0;
 			sFrame.pERP->byContext |= WLAN_EID_ERP_USE_PROTECTION;
-		if (pDevice->bNonERPPresent == true)
+		if (pDevice->bNonERPPresent)
 			sFrame.pERP->byContext |= WLAN_EID_ERP_NONERP_PRESENT;
-		if (pDevice->bBarkerPreambleMd == true)
+		if (pDevice->bBarkerPreambleMd)
 			sFrame.pERP->byContext |= WLAN_EID_ERP_BARKER_MODE;
 	if (((PWLAN_IE_SUPP_RATES)pCurrExtSuppRates)->len != 0) {
@@ -3225,7 +3223,7 @@ s_MgrMakeBeacon(
 	// hostapd wpa/wpa2 IE
-	if ((pMgmt->eCurrMode == WMAC_MODE_ESS_AP) && (pDevice->bEnableHostapd == true)) {
+	if ((pMgmt->eCurrMode == WMAC_MODE_ESS_AP) && pDevice->bEnableHostapd) {
 			if (pMgmt->wWPAIELen != 0) {
 				sFrame.pRSN = (PWLAN_IE_RSN)(sFrame.pBuf + sFrame.len);
@@ -3338,16 +3336,15 @@ s_MgrMakeProbeResponse(
 		// Country IE
@@ -3360,7 +3357,7 @@ s_MgrMakeProbeResponse(
@@ -3389,7 +3386,7 @@ s_MgrMakeProbeResponse(
 					pbyBuffer += 2;
 					uLength += 2;
 					pIBSSDFS->len += 2;
@@ -3409,7 +3406,7 @@ s_MgrMakeProbeResponse(
@@ -3507,7 +3504,7 @@ s_MgrMakeAssocRequest(
 	pbyIEs += pCurrRates->len + WLAN_IEHDR_LEN;
 	// for 802.11h
-	if (pMgmt->b11hEnable == true) {
+	if (pMgmt->b11hEnable) {
 		if (sFrame.pCurrPowerCap == NULL) {
 			sFrame.pCurrPowerCap = (PWLAN_IE_PW_CAP)(sFrame.pBuf + sFrame.len);
 			sFrame.len += (2 + WLAN_IEHDR_LEN);
@@ -3650,7 +3647,7 @@ s_MgrMakeAssocRequest(
 		sFrame.pRSN->len += 6;
 		// RSN Capabilities
-		if (pMgmt->pCurrBSS->sRSNCapObj.bRSNCapExist == true) {
+		if (pMgmt->pCurrBSS->sRSNCapObj.bRSNCapExist) {
 			memcpy(&sFrame.pRSN->abyRSN[16], &pMgmt->pCurrBSS->sRSNCapObj.wRSNCap, 2);
 		} else {
 			sFrame.pRSN->abyRSN[16] = 0;
@@ -3658,7 +3655,7 @@ s_MgrMakeAssocRequest(
 		sFrame.pRSN->len += 2;
-		if ((pDevice->gsPMKID.BSSIDInfoCount > 0) && (pDevice->bRoaming == true) && (pMgmt->eAuthenMode == WMAC_AUTH_WPA2)) {
+		if ((pDevice->gsPMKID.BSSIDInfoCount > 0) && pDevice->bRoaming && (pMgmt->eAuthenMode == WMAC_AUTH_WPA2)) {
 			// RSN PMKID
 			pbyRSN = &sFrame.pRSN->abyRSN[18];
 			pwPMKID = (unsigned short *)pbyRSN; // Point to PMKID count
@@ -3896,7 +3893,7 @@ s_MgrMakeReAssocRequest(
 		// RSN Capabilities
 		} else {
@@ -3904,7 +3901,7 @@ s_MgrMakeReAssocRequest(
 			// RSN PMKID
@@ -4141,7 +4138,7 @@ s_vMgrRxProbeResponse(
 		return;
@@ -4578,7 +4575,7 @@ bAdd_PMKID_Candidate(
-			if ((psRSNCapObj->bRSNCapExist == true) && (psRSNCapObj->wRSNCap & BIT0)) {
+			if (psRSNCapObj->bRSNCapExist && (psRSNCapObj->wRSNCap & BIT0)) {
 			} else {
@@ -4589,7 +4586,7 @@ bAdd_PMKID_Candidate(
 	// New Candidate
 	} else {
@@ -4650,7 +4647,7 @@ s_bCipherMatch(
 	if ((WLAN_GET_CAP_INFO_PRIVACY(pBSSNode->wCapInfo) != 0) &&
-	    (pBSSNode->bWPA2Valid == true) &&
+	    pBSSNode->bWPA2Valid &&
 	    //20080123-01,<Add> by Einsn Liu
 	    ((EncStatus == Ndis802_11Encryption3Enabled) || (EncStatus == Ndis802_11Encryption2Enabled))) {
 		//WPA2
@@ -4684,7 +4681,7 @@ s_bCipherMatch(
 	} else if ((WLAN_GET_CAP_INFO_PRIVACY(pBSSNode->wCapInfo) != 0) &&
-		   (pBSSNode->bWPAValid == true) &&
+		   pBSSNode->bWPAValid &&
 		//WPA
 		// check Group Key Cipher
diff --git a/drivers/staging/vt6655/wpa.c b/drivers/staging/vt6655/wpa.c
index b697fa6..990ea0f 100644
--- a/drivers/staging/vt6655/wpa.c
+++ b/drivers/staging/vt6655/wpa.c
@@ -241,7 +241,7 @@ WPA_SearchRSN(
 	int ii;
 	unsigned char byPKType = WPA_NONE;
-	if (pBSSList->bWPAValid == false)
+	if (!pBSSList->bWPAValid)
 		return false;
 	switch (byCmd) {
diff --git a/drivers/staging/vt6655/wpa2.c b/drivers/staging/vt6655/wpa2.c
index a7e33c0..2013122 100644
--- a/drivers/staging/vt6655/wpa2.c
+++ b/drivers/staging/vt6655/wpa2.c
@@ -192,7 +192,7 @@ WPA2vParseRSN(
 					break;
 			} //for
-			if (bUseGK == true) {
+			if (bUseGK) {
 				if (j != 1) {
 					// invalid CSS, This should be only PK CSS.
 					return;
@@ -335,7 +335,7 @@ WPA2uSetIEs(
 		pRSNIEs->len += 2;
 		if ((pMgmt->gsPMKIDCache.BSSIDInfoCount > 0) &&
-		    (pMgmt->bRoaming == true) &&
+		    pMgmt->bRoaming &&
 			// RSN PMKID
 			pwPMKID = (unsigned short *)(&pRSNIEs->abyRSN[18]);  // Point to PMKID count
diff --git a/drivers/staging/vt6655/wpactl.c b/drivers/staging/vt6655/wpactl.c
index 044368a..ee83704 100644
--- a/drivers/staging/vt6655/wpactl.c
+++ b/drivers/staging/vt6655/wpactl.c
@@ -341,22 +341,22 @@ int wpa_set_keys(PSDevice pDevice, void *ctx, bool fcpfkernel)
 		// If is_broadcast_ether_addr, set the key as every key entry's group key.
 		DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "Groupe Key Assign.\n");
-		if ((KeybSetAllGroupKey(&(pDevice->sKey),
+		if (KeybSetAllGroupKey(&(pDevice->sKey),
 					dwKeyIndex,
 					param->u.wpa_key.key_len,
 					(PQWORD) &(KeyRSC),
 					byKeyDecMode,
-					pDevice->byLocalID) == true) &&
-		    (KeybSetDefaultKey(&(pDevice->sKey),
+					pDevice->byLocalID) &&
+		    KeybSetDefaultKey(&(pDevice->sKey),
 				       dwKeyIndex,
 				       (PQWORD) &(KeyRSC),
 				       byKeyDecMode,
-				       pDevice->byLocalID) == true)) {
 			DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "GROUP Key Assign.\n");
 		} else {
@@ -389,7 +389,7 @@ int wpa_set_keys(PSDevice pDevice, void *ctx, bool fcpfkernel)
 			       byKeyDecMode,
 			DBG_PRT(MSG_LEVEL_DEBUG, KERN_INFO "Pairwise Key Set\n");
 		} else {
@@ -804,7 +804,7 @@ static int wpa_set_associate(PSDevice pDevice,
 	else
 		pDevice->bEncryptionEnable = false;
 	if (!((pMgmt->eAuthenMode == WMAC_AUTH_SHAREKEY) ||
-	      ((pMgmt->eAuthenMode == WMAC_AUTH_OPEN) && (bWepEnabled == true))))  //DavidWang  //20080717-06,<Modify> by chester//Not to initial WEP
+	      ((pMgmt->eAuthenMode == WMAC_AUTH_OPEN) && bWepEnabled)))  //DavidWang  //20080717-06,<Modify> by chester//Not to initial WEP
 		KeyvInitTable(&pDevice->sKey, pDevice->PortOffset);
BtrLinux
Privacy Overview
