staging: vt6655: card.c: replace memcpy() by ether_addr_copy() using coccinelle
Author: Aya Mahfouz <mahfouz.saif.elyazal@gmail.com>
This patch focuses on fixing the following warning generated
by checkpatch.pl for the file rxtx.c :
Prefer ether_addr_copy() over memcpy() if the Ethernet addresses
are __aligned(2)
The changes were applied using the following coccinelle rule:
@@ expression e1, e2; @@
- memcpy(e1, e2, ETH_ALEN);
+ ether_addr_copy(e1, e2);
According to ether_addr_copy() description and functionality,
all Ethernet addresses should align to the u16 datatype.
Here is the output of pahole for the relevant datastructures:
struct pmkid_candidate {
NDIS_802_11_MAC_ADDRESS BSSID; /* 0 6 */
/* XXX 2 bytes hole, try to pack */
long unsigned int Flags; /* 8 4 */
/* size: 12, cachelines: 1, members: 2 */
/* sum members: 10, holes: 1, sum holes: 2 */
/* last cacheline: 12 bytes */
Signed-off-by: Aya Mahfouz
drivers/staging/vt6655/card.c | 2 +-
1 file changed, 1 insertion(+), 1 deletion(-)
diff --git a/drivers/staging/vt6655/card.c b/drivers/staging/vt6655/card.c
index 5a69502..f2a33a9 100644
--- a/drivers/staging/vt6655/card.c
+++ b/drivers/staging/vt6655/card.c
@@ -1000,7 +1000,7 @@ CARDbAdd_PMKID_Candidate(
else
pCandidateList->Flags &= ~(NDIS_802_11_PMKID_CANDIDATE_PREAUTH_ENABLED);
- memcpy(pCandidateList->BSSID, pbyBSSID, ETH_ALEN);
+ ether_addr_copy(pCandidateList->BSSID, pbyBSSID);
pDevice->gsPMKIDCandidate.NumCandidates++;
pr_debug("NumCandidates:%d\n",
(int)pDevice->gsPMKIDCandidate.NumCandidates); |
else
